Stopped by to See Ohmasa and discuss a few things
Axil
Re: Stopped by to See Ohmasa and discuss a few things
« Reply #1,  »Last edited
Ohmasa adds LPG to O-gas as an octane booster. A more compatible engine to take advantage of the inherent nature of O-gas is a diesel engine. The Papp engine is the type of engine that is most compatible with the very low octane of O-gas. An O-gas shock wave will travels at the speed of light and needs to operate in the combustion chambers of a purpose built engine.
Without an octane booster, O-gas will blow a gasoline engine apart from explosive levels of knocking.
I would like to see O-gas used in a Popper like Bob Rohner has built to see if the Popper can handle the ignition power.
http://www.rgenergy.com/Projects.html
Maybe Russ can fire up his popper to run an experiment or two.
« Reply #2,  »Last edited
Ohmasa adds LPG to O-gas as an octane booster FALSE
he is using it to slow burn rate as he is not trained  in non combustible gas control
but has his own  very advanced ways to apply gas he invented
Ohmasa gas is gtnt depending on how you apply it
Spoken with him in person touched gas played with machines
doing project with him
« Reply #3,  »Last edited
doc
