Valentin Petkov / valyonpz/
Re: Valentin Petkov / valyonpz/
« Reply #25, on July 16th, 2019, 02:06 AM »Last edited on July 16th, 2019, 07:29 PM
Presenting Water electrolysis
RESONANCE
with a
INVERTED SIGNED
« Reply #26, on July 16th, 2019, 06:51 AM »Last edited on July 16th, 2019, 08:35 AM
the Water Electrolysis Waveform From Stephen  explained further
« Reply #27, on July 16th, 2019, 11:08 AM »Last edited on July 16th, 2019, 11:38 AM
Stanley A Meyer Basic Principles of Voltrolysis
« Reply #28, on July 16th, 2019, 07:12 PM »Last edited on July 16th, 2019, 07:27 PM
Stan Meyer's 8XA circuit has one serious drawback - if network frequency (110 Volts / 60 Hz) is change,  "Step Charge" settings too changing. As you know, the network frequency is vary!
For High Efficient Electrolysis, Stan Meyer use three basic principle:
1. "Beat Frequencies" for creating "Step charge effect"
2. "Gated signal" for Decreasing current leak, but keep voltage between the Cell electrodes !!!!!
3. Two or more serial connected Water Fuel Cells - "Еxcitor Array" for Decreasing current leak.
If use 25.1 Hz, effects is produced both !
(Supply frequency 50 Hz / 220 Volts, after 4-diode rectifier 100 Hz)
Stan Meyer's Patent 4.798.661:
The pulsed d.c. voltage, the duty cycle pulses, the resistor from negative to ground, the serial connections of the exciters, and the plate resistor in series with a variable resistor between the negative plate and ground, is a sequence of circuits that counteract the electron leakage with increased voltage. Similarly, the same sequence individually and in combination are equally applicable with respect to the variation of plate spacing to vary the rate of generation of the gasses but yet, to restrict electron leakage. The voltage levels from 0 volts upward will be dependent on the physical parameters of the apparatus. In one typical structure of the apparatus the voltage was varied from zero (0) volts to 45 volts. In a smaller structure, the voltage levels of FIG. 8 were utilized.
« Reply #29, on July 16th, 2019, 07:28 PM »Last edited on July 28th, 2019, 11:20 PM
Stan Meyer's 8XA circuit without 4-Diode Bridge Rectifier.
The circuit work like Stan Meyer's VIC - "Half-wave rectification":
http://en.wikipedia.org/wiki/Rectifier
"Gated" Generator is tuned to 51 Hz ! (Supply frequency 50 Hz / 220 Volts)
My modifying 8XA circuit with Half-wave rectification and 180 degree control:
(Zener Diode is added)
A rectifier is an electrical device that converts alternating current (AC), which periodically reverses direction, to direct current (DC), which flows in only one direction.
The process is known as rectification, since it "straightens" the direction of current. Physically, rectifiers take a number of forms, including vacuum tube diodes, mercury-arc valves, stacks of copper and selenium oxide plates, semiconductor diodes, silicon-controlled rectifiers and other silicon-based semiconductor switches. Historically, even synchronous electromechanical switches and motors have been used. Early radio receivers, called crystal radios, used a "cat's whisker" of fine wire pressing on a crystal of galena (lead sulfide) to serve as a point-contact rectifier or "crystal detector".
Rectifiers have many uses, but are often found serving as components of DC power supplies and high-voltage direct current power transmission systems. Rectification may serve in roles other than to generate direct current for use as a source of power. As noted, detectors of radio signals serve as rectifiers. In gas heating systems flame rectification is used to detect presence of a flame.
Depending on the type of alternating current supply and the arrangement of the rectifier circuit, the output voltage may require additional smoothing to produce a uniform steady voltage. Many applications of rectifiers, such as power supplies for radio, television and computer equipment, require a steady constant DC voltage (as would be produced by a battery). In these applications the output of the rectifier is smoothed by an electronic filter, which may be a capacitor, choke, or set of capacitors, chokes and resistors, possibly followed by a voltage regulator to produce a steady voltage.
More complex circuitry that performs the opposite function, converting DC to AC, is called an inverter.
A rectifier diode (silicon controlled rectifier) and associated mounting hardware. The heavy threaded stud attaches the device to a heatsink to dissipate heat.
« Reply #30, on July 17th, 2019, 09:15 AM »
"Gated" Generator is tuned to 52 Hz ! (Supply frequency 50 Hz / 220 Volts)
« Reply #31, on July 17th, 2019, 09:17 AM »
Generator is created with LM 566 - VCO (Voltage Controlled Oscillator)
For prevent overheating resistors, Ultra High Power SCR is controled by other Low Power SCR - Darlington cirquit
My modifying 8XA circuit:
« Reply #32, on July 17th, 2019, 11:39 PM »Last edited on July 17th, 2019, 11:46 PM
has one serious drawback - if network frequency (110 Volts / 60 Hz, or 220 Volts / 50 Hz) is change,
This is my new circuit!
"Step Charge" time is constant.
  • Output Driver power is over 30000 Watts - over, over, over...more than need!
    "Frequency Adjust" - tune "Step Charge" time.
    "Maximum Voltage Adjust" - tune maximal voltage limit.
    "Positive Ramp Offset Adjust" - coordinate triangle waveform to optocoupler.
    "Minimum Voltage Adjust" - tune the minimum voltage at which water molecule is Breakdown - "Water Breakdown Point"
    "Step Charge" vary between Voltage "Water Breakdown Point" and "Maximal Voltage"!
« Reply #33, on July 18th, 2019, 12:03 AM »
How is looks 120 Volts / 4 Amps to a single 4 inch HHO Tube Cell
« Reply #34, on July 19th, 2019, 07:43 AM »Last edited on July 19th, 2019, 07:52 AM
Stanley Meyer`s Hydrogen Gas Gun
How to ensure a good corona discharge?
How to prevent an electrical break between the electrodes?
Here I use as an insulator several layers of plastic film and a glass tube.
« Reply #35, on July 19th, 2019, 08:00 AM »
Stan Meyer`s Step Charge
Stan Meyer`s VIC:
CORE MATERIAL - Core from Standard 50 Hz transformer (with ferrite core from Flyback transformer not working !!!!!)
Primary coil - 200 turns / 1 mm. copper wire
Secondary coil - 200 turns / 1 mm. copper wire
(Primary and Secondary coils are wind bifilar (together with two wires) on one spool for best transfer !!!!!)
Resonant choke C1 - 33 turns / 1 mm. copper wire
Resonant choke C2 - 33 turns / 1mm. copper wire
!!! Necessarily remove the diode, connected to the primary coil !!!
!!! If the Primary coil terminals are "reversed", Step Charge not occur !!!
Using voltage to Primary coil - 40 Volts / 2 Amps
Output Voltage to the Cell - +30 Vpp to -25 Vpp / 0.5 Amps
C1 / C2 - 2 x 25 turns:
C1 / C2 - 2 x 33 turns:
C1 / C2 - 2 x 50 turns:
How look Hysteresis loop figure:
If C1 and C2 are wind with more than 2 x 200 turns, Step Charge does not occur.
If C1 and C2 are wind with more than 2 x 100 turns, output Voltage to the Cell is only with positive polarity, but thus not produce effect "Rotation moment of the proton magnetic moment":
"This sets up a rotation moment of the proton magnetic moment which one can clearly see on the XY plot of an oscilloscope, as an hysteresis loop figure. However, it is noted that this hysteresis loop does not appear in the liquid water sample until all the parameters of the three components have been adjusted to the configuration which is the novel basis of this device. The hysteresis loop gives us a vivid portrayal of the nuclear magnetic relaxation cycle of the proton in water."
The last step - Amplitude modulation of the Voltage to the Primary coil with extreme low frequency:
Stan Meyer`s 9XA circuit diagram:
To Primary coil Stan Meyer not use 12 Vots!
Meyer use 120 Volts !!!! See Figure 1-14 from Memo WFC 420:
« Reply #36, on July 19th, 2019, 08:03 AM »Last edited on July 19th, 2019, 08:10 AM
Stanley Meyer's 9XA Waveform !!!!
Primary coil - 300 turns / 1 mm. copper wire
Secondary coil - 300 turns / 1 mm. copper wire
In this case - without Resonant chokes C1 and C2 !!!!
Using voltage to Primary coil: 24 Volts / 0.3 Amps (After 4 diode bridge Graetz, has a filtering capacitor 10000 uF). (Note that at terminals of the primary winding is not connected diode).
Output Voltage to the Cell: +24 Vpp / 0.3 Amps
High frequency - 1 kHz
Gated frequency - 50 Hz
« Reply #37, on July 19th, 2019, 08:12 AM »Last edited on July 22nd, 2019, 11:40 AM
the first circuit to build , no gate  you can note the signal difference between this 8xa and the above 9xa
8XA circuit is Stanley Meyer's invention.
But how it`s work?
Basic principle 8XA circuit is a "Beat Frequencies".
The frequency from the network is 50 Hz (Sinusoidal waveform)
After diode bridge "Graetz" frequency is 100 Hz (Pulse waveform)
Generator is tuned at 101 Hz !!!!!! (Square waveform, 50% Duty cycle)
"Beat" frequency is 1 Hz.
If Generator is tuned at 99 Hz, "Energizing front" is not correct:
- 101 Hz - create "Increasing Voltage" - OK !
- 99 Hz - create "Decreasing Voltage" - Wrong !
Real direction of Bifilar Chokes:
 8XA - Full circuit diagram:
8XA - Circuit diagram without variac transformer:
8XA - Circuit diagram with Car alternator:
« Reply #38, on July 19th, 2019, 09:50 AM »Last edited on July 19th, 2019, 10:07 AM
Stan Meyer's Electron Extraction Circuit
Used for the Gas Processor and or the Cell can also be adapted for other areas like water tank and egr
even from the block if positive earthed .
How to Create Electron Extraction Circuit?
Why Stan Meyer use Gated Signal?
Why "Gate" is "over" Zero level?
Read Stan Meyer's Patent 4798661 - Gas Generator Voltage Control Circuit:
Gas generator voltage control circuit
Abstract
1)
A power supply in a system utilizing as a source of fuel a generator for separating hydrogen and oxygen gasses from natural water and having the capabilities to control the production of gasses by varying the amplitude of the voltage and/or the pulse repetition rate of the voltage pulses applied to a pair of plate exciters in a vessel of natural water, comprising a sequence of circuitry operative to limit the current of a d.c. potential to a minimum value relative to the magnitude of the voltage applied to the plate exciters.
2)
 The circuits each function up to a given magnitude of voltage to inhibit and curtail the flow of electrons from the plate exciter having the negative voltage potential applied thereto.
3)
The first circuit operative from a first magnitude of voltage comprises converting the voltage potential applied to the plate exciters to a unipolar pulse voltage d.c. of a repetitive frequency.
4)
 The next circuit varies the duty cycle of the unipolar pulse voltage d.c.; followed by rearranging the application of the voltage to the exciters to individual exciters each having the voltage applied thereto independently of the other plate exciters in the generator.
5)
The next circuit comprises an electron inhibitor that prevents the flow of electrons; the circuit being in the terminal line between the negative plate exciter and ground. In those applications of the generator wherein excessively high voltage is to be applied to the plate exciters for a very high yield of gasses, a second electron inhibitor of a unique structure is serially connected with the first electron inhibiter.
6)
The second named inhibiter having a relatively fixed value and the first inhibiter connected in series is variable to fine tune the circuits to eliminate current flow.
« Reply #39, on July 19th, 2019, 10:14 AM »Last edited on July 19th, 2019, 11:41 AM
WATER FUEL - Stanley Meyer's STEAM RESONATOR
Alot of thinking has gone into understanding this simply thing .
We can Thank the Army of Home Builders and People determined to study every details to discover the training path .
Names like Tony  and Tony q Max Dan Petkov  Russ Alex Chris John Don and Zhu and Many Many more to many to mention
 Thank you  all every share every post every comment has made the difference.
Flat plates show to test the  dbb barrier working for the steam resonator.  Holds the skin effect on both sides
the pic show quartz to enhance skin effect but other mediums can be used as it is water heating not full gas breakdown
As Pic show.
« Reply #40, on July 20th, 2019, 08:24 AM »Last edited on July 20th, 2019, 08:27 AM
BUT WHAT IS THE EFFICIENCY
WATER FUEL - Continuous electrolysis - WFC 4 inch Tubes
Pulse DC - 100 Hz from rectifier
50 Volts / 4 Amps to two series connected Cells
Together we Change the World
« Reply #41, on July 20th, 2019, 08:41 AM »Last edited on July 22nd, 2019, 11:58 AM
WATER FUEL - Stanley Meyer`s Step-charging
Looking at the  Ways to Make a Simple Step Charge
Note
If the block is positive the center  negative
this would ring true as
outter of injector concentric is than positive inline will plans
Secrets of the art
White spark  if negative is the coil  placement
vs Blue Spark if the positive coil placement
« Reply #42, on July 22nd, 2019, 11:50 AM »
Voltrolysis PROVEN CORRECT
WATER FUEL - Voltage disassociation electrolysis - WFC 4 inch Tubes
Step-charge Voltage disassociation - HHO LIKE A SMOKE !!!!!!!!
10 Volts / 220 mA to two series connected Cells (5 volts to Cell)
High frequency - 17 kHz
"Gate" frequency - 3 Hz
GOD BLESS YOUR STANLEY A MEYER
WE GOT YOURS and The Worlds BACK
« Reply #43, on July 29th, 2019, 12:14 AM »Last edited on July 29th, 2019, 01:54 AM
Attach is the Document Pdf of this this suggest you all download and re up load to other places
YEs We See Many People Building and Making these Circuit now Lets post the boards here
The more we work together the faster we change the world
« Reply #44, on April 27th, 2020, 10:57 PM »Last edited on April 27th, 2020, 11:00 PM
I will go back and Try and Date the Series to help decifer
Stanley Meyer`s RESONANCE Water Electrolysis - DEMONSTRATION
431 views•Apr 25, 2020
blavatsky
« Reply #45, on September 27th, 2020, 02:56 AM »
Valentin Petkov has worked on resonance fractionation of water since ~2009.
In 2019 he seems to have consolidated a lot of principles in WFC technology.
I believe  IMO that Stan Meyer changed aspects of circuit diagrams to obfuscate the true
circuit.
Has anybody tried to make a Glossary of terms to make discussion of these topics easier to understand.
eg
Duty Cycle, Gate Frequency, Base Frequency, Resonant Frequency, variac, inductance, capacitance, resistance, power flow,
wire diameter, wire length, core diameter, core Number of Turns (cNOTs) , Inductor, Inductor Number of Turns (iNOTs), Transformer Number of Turns, MOFSET transistor, 68microFarad Capacitor, Water Dielectric constant etc
« Reply #46, on September 27th, 2020, 08:19 AM »
the work is open for people to discover alot is posted here anything to add helps ,
we have no reason to believe after many replications that stand changed any terms
blavatsky
« Reply #47, on September 27th, 2020, 05:00 PM »Last edited on September 28th, 2020, 03:01 PM
see below for links to virtual circuits
Evengravy
« Reply #49, on September 28th, 2020, 12:56 PM »
Hey. I'm new to the forum here, but wanted to point something out. Has anyone come across the website lbry.tv? The reason I mention it is that it's based on blockchain technology (like cryptocurrency) and, file storage wise, it's a safe as houses as the files are spread across the blockchain. Once they're there they're very difficult/next to impossible to get rid of. Worth thinking about, seems like very important info.
