Petlov Post some very Cool
Videos Suggest you all Watch Save and Not them as you replicate These
Warm Regards as we see the New year on the Horizon
Video 1
https://youtu.be/ehl_8nsR_ZU
The key to understand Stanley Meyer's technology, is a "Resonant waveform", presented in the Patent US 2005/0246059 A1, of Stephen Meyer (Stanley Meyer's twin brother).
Stephen Meyer`s Patent US 2005/0246059 A1:
https://drive.google.com/file/d/1_0f5IMXdbvjAktE0L1-bT3uyWZcMCxtr/view?usp=drive_open
My Circuit diagram:
https://drive.google.com/file/d/14sEYf1eV2dOQTc32VA6fMT3kRzxU_WWT/view
Used values:
Resonant frequency - 789 kHz !!!! (This is not a joke)
Gate frequency - 31.5 kHz !!!
Gate "Duty/cycle" - 28 %
Bifilar inductor - 2 x 100 turns, 0,5mm., copper wire on ferrite core.
The Signal to the Primary coil is "Inversed" Pulse train" !!!! (like at Meyer`s VIC!)
The Self Resonant frequency of the Bifilar inductor, at "1:1 Resonance" is about 43 kHz.
Very important!!!
Note, that the "Gate generator" (Low frequency generator) must be tuned to the "Self Resonant frequency" of the Bifilar inductor, or it`s harmonic frequency!!! Then, "High frequency generator", may be at 500 kHz to 1,5 MHz !!!! !!!!!!!!!!!!!
Stephen Meyer`s Used values:
Resonant frequency - 13,5 kHz
Gate frequency - 496,9 Hz
Gate "Duty/cycle" - about 40 %
The the Internet, ago has info that Stanley Meyer uses the following values:
Resonant frequency - 42.8 kHz
Gate frequency - 600 Hz
Gate "Duty / cycle" - 50%
And, a very interesting fact:
"Recently we learned that the Water Disrupting Spark Plug promoted around 1994 by Stan Meyers was in fact suggested to him by Dale Pond at a conference in Switzerland back in 1989. The idea was you should be able to use Keely's 42.8khz emitted from a spark plug to instantly dissociate the water molecule to hydrogen and oxygen which would then be exploded to drive the piston."
Another, successful replication of the Stephen Meyer`s Waveform, from Tony Woodside:
https://www.youtube.com/watch?v=cX6yY...
Stanley Meyer's WO 92/07861:
http://www.rexresearch.com/meyerhy/wo...
"In the invention, the adjustable frequency generator (Figure 12) /Gated generator/, tunes into the resonant condition of the circuit including the water cell and the water therein."!!!!!
"Shape and size of the resonant cavity may vary. Larger resonant cavities and higher rates of consumption of water in the conversion process require higher frequencies such as up to 50 KHz and above. The pulsing rate, to sustain such high rates of conversion must be correspondingly increased."!!!
"Also, at a resonant condition harmonic effects occur. In a typical operation of the cell with a representative water capacitor described below, at a frequency of about 5 KHz at unipolar pulses from 0 to 650 volts at a sensed resonant condition into the resonant cavity, conversion of about 5 gallons of water per hour into a fuel gas will occur on average. "!!!
Video 1
My Circuit diagram:
Used values:
Very important!!!
