Just a quick update, the control box is finished, got the wiper arm in, finished wiring it up and the toggle switches are in. Used high voltage transmission line from the positive choke to the SO239 to stop any arcing between the negative choke and the positive choke output.
Matt I wasn't sure how to configure the secondary so I build the secondary to Andrija Puharich's design of a bifilar with open ended configuration but if the left toggle switch is in the on position it switches the secondary into a Stan Meyer closed circuit design, I figured best of both worlds like you said. The other toggle switch when in the on position deploys the high speed diode but in the off position bypasses the diode and replicates Andrija Puharich's design. This way I can play with four different configurations with the two switches.
