The simple truth is there is no electron. Think of it as you will. We have never seen one and to believe there is one is a logical fallacy. That was my whole point.
We need something new. And charge balance fits the bill. Under natural circumstances all matter has bound charges inside of it and an absent of charges around it. This is what led me to the plasma as both structure and charge carriers. Two distinct kinds of plasma or two scales of plasma particles. The structure plasma is in between all matter. With the charge carriers being much smaller and virtual, meaning made up of smaller plasma particles. I say virtual because they add together to form the larger structure and can actually hold charges, even smaller plasma particles, inside of that virtual structure.
The larger particles have a higher surface area and hold little to no charges as the virtual particles. This makes them the conductor between all matter. The mere shape of the particles are geometric pyramids in both cases. With the larger particles being the guide to the virtual charge carriers. I like to call them the highway and vehicle particles.
The neutral space we see everywhere is a combination of both particles and can be separated by a higher potential, which sucks away the vehicle particles and forces that particle to become negative in a sense.
Again onepower you are the one who is believing in a fictitious electron. No one has seen one and no one ever will. If you have then show me the electron that you believe in. I on the other hand can show you plasma and it's ability to condense around a higher potential. At least we can agree on that. You keep saying truth. Well time to put it up then. Show us the electron and how it moves through and outside of a wire? Show us electrons flowing from the negative to the positive. Show us the truth.
i think we all agree that there is way more new things to discover and a lot better ways to view them...
I'm all in on your plasma thoughts.I have been doing a lot of thinking and came to the conclusion that where there is plasma. Things get way more energetic then otherwise. ( look at how electrical fires react... and shorts in systems...)
The reason why i look at electron theory is to think through the over view to get some hints as to whats going on.
my problem is that at 2VDC i cant see where any plasma would be. ( if we consider what the " electron cloud" is... that could be thought of as "plasma" i guess)
any hoo, lets keep searching for answers and lets let the bench tell us what is right.
so much more do so yet we have came so far...
