VIC coil winding positions from estate photos and their role in the setup
realtry
« on February 22nd, 2014, 09:54 AM »
Hello,
Stan Meyer estate photos
I am trying to identify the coil positions in the estate photo and the reason why they are placed in that position.
What i am trying to understand is the role of back emf, the order of magnetic field collapse/inductive kick in the transformer and their impact.
Could someone here point out these below things, i would really really appreciate your help,
1. what the yellow/green/blue coils are?
2. Why is their size like that? Green narrow & Blue wide while their height of winding and coil size seems similar.
3. Why are they positioned like that.
4. What could be the sequence of magnetic field collapse/inductive kick in these 5 coils. i.e during the pulsing interval which coil collapse first and the second one etc.
Thanks
Realtry
Re: VIC coil winding positions from estate photos and their role in the setup
« Reply #1, on March 6th, 2014, 09:23 PM »
www.secuesupplies.biz
You have alot to read.
Small coil are feed back pick up coils and we are  using other to amplify the voltage and frequency coming in from pwm and switch to vic to
create a step charge voltage charge up in the cell (water capacitor)  and a controlled rest and restrict the amps so it is is under 10 amp draw
but 5 kv up in the cell
This means we end up with a high voltage environment in the cell (water Capacitor)
and the circuits are constantly touching it up. to crack water with least amp draw possible and hit the cross section of frequencies in the cell
on water body between plates which is now polarized and ionized during that charge to create hydrogen with low input.
