ITR9608 (Everlight) — what it is + current pricing
Type: 5 mm slot, IR LED + phototransistor output (no logic inside; no built-in Schmitt trigger). That’s straight from the datasheet.
Typical unit pricing (USD, today):
Digi-Key – bulk table shows .5236 @270 pcs (not normally stocked; shows pricing tiers .
Mouser – page indicates regional availability issues; list pricing commonly around .70– .80/ea when in stock.
LCSC – .1380 starting price for ITR9608-F (Everlight), widely in stock; also XL-ITR9608 (Xinglight) from .0763.
Other retail/marketplaces: small packs on eBay/Amazon typically .20– .60 per piece equivalent.
Bottom line: If you want immediate, inexpensive supply for prototyping, LCSC has the best per-unit price right now. For North-America-centric BOMs, Digi-Key/Mouser are fine when stocked but cost more.
What a Schmitt trigger does (and why you might add one)
The bare ITR9608’s output is an analog phototransistor. As a slotted vane moves, the output voltage ramps and can chatter with vibration/EMI.
A Schmitt trigger (either built-in to some interrupters or added externally) converts that slope into a clean digital edge with hysteresis:
Two thresholds (V_T+ and V_T–): input must rise past the upper threshold to switch high and fall past the lower to switch low → noise immunity and no edge chatter.
Fast edges: better timing repeatability for your CCP/Timer scheduler.
Direct MCU/FPGA-friendly logic levels.
Some slotted sensors ship with internal amplifier + Schmitt (“Photo-IC output”). Examples you can drop in if you want an integrated digital output:
Omron EE-SX3081 / EE-SX4081 (5 mm slot, Photo-IC output, CMOS/TTL compatible).
OMRON Device & Module Solutions Website
Many EE-SX “3xx/4xx” families specifically call out integral Schmitt trigger/amplifier in the literature.
Your ITR9608 does not include that circuitry—it’s just LED + phototransistor (see datasheet). If you stick with ITR9608, add one of these externally:
Two easy conditioning options
Single-gate Schmitt buffer (cheap, fast, tiny)
TI/Nexperia 74LVC1G14 (1-channel, 1.65–5.5 V) or 74HC14/74HCT14 (6-channel).
Wire the phototransistor open-collector to MCU rail with a pull-up (e.g., 4.7–10 kΩ) → Schmitt input.
Optional RC (e.g., 1–4.7 kΩ with 1–10 nF) before the gate for extra de-glitch if your vane edges are slow.
Comparator with hysteresis (tunable thresholds)
E.g., MCP6561 or LMV331 with a feedback resistor to set ≈0.2–0.5 V hysteresis.
Useful if you run long cables or need specific thresholds/noise margins.
When to insist on a Schmitt stage
High-RPM pulsing with narrow slots (fast dV/dt and any wobble → chatter).
Long harnesses near ignition coils (EMI).
Dual-stack arrangements where you need crisp phase separation.
Quick pick list (so you can buy today)
Exact part: Everlight ITR9608-F — .52 @270 pcs (DK pricing), ~ .14 @ LCSC (spot pricing).
With built-in logic: Omron EE-SX3081/4081 (Photo-IC, 5 mm slot).
External Schmitt buffer: TI SN74LVC1G14 (single) or 74HC14 (hex). (Standard logic families; choose to match your 5 V or 3.3 V rail.)
Fast wiring note (for your PIC build)
ITR9608 phototransistor collector → MCU Vdd with 10 kΩ pull-up, emitter → GND.
Node → 74HC14 (or MCU pin if it has Schmitt inputs); if the PIC pin isn’t Schmitt-type, insert the 74HC14/74LVC1G14.
Add 100 nF decoupling at the sensor and a series 100–220 Ω in the LED drive line; drive LED around 10–20 mA per datasheet.
