Open - Source - Research => Open-Source Research => Moving Pulsed Systems / Radiant Energy / Tesla => Topic started by: jbignes5 on June 18th, 2016, 08:25 AM
Title: The real Tesla
Post by: jbignes5 on June 18th, 2016, 08:25 AM
 One very important question.
 What allows current to flow on the outside of the wire?
 If we look at high voltage discharges what is the spark?
 One clue a product inside of your body that allows the blood to flow is what?
 Answer: PLASMA
 Plasma is responsible for all energetic events outside of matter. Free flowing plasma that organizes to the voltage potential presented by the wire or antenna or anything else we use to electrify space. The plasma on volume around our planet and in space is responsible for it all. Gather or condense enough plasma and it will raise in density. This density change allows better conduction through space and dictates the discharge(conduction) level when driven to the level of density to facilitate conduction through space. Since plasma is a magnetic transmitter or magnetic friendly it makes perfect sense to equate the magnetic phenomena around all wires with plasma condensations around any potential high enough to trigger plasma condensing. With low level voltages the condensing is closer to the source of the voltage. With very high levels the conduction goes into overdrive due to the very high density of plasma carriers around the voltage source. ALL Induction through space is driven by plasma. This includes inside of matter. Although the density of plasma inside of matter (in the space between matter) is vastly displaced by matter and causes less transmission of current through that body of matter. This creates the skin effect and the magnetic field encircling the voltage source is a byproduct.
 Now what happens when the density of plasma around a device increases and condenses? Of course this allows better conduction for all our communication needs.
 Tesla figured this out through his High Voltage explorations. Tesla knew what gravity really was. I will tell you this much. when plasma has a density change it wants to be the same density. A vacuum is created by displacing the plasma with matter. Free plasma, which is all around our planet in a very high density is trying to seek a balance and tries to rush in to fill the vacuum. It of course can not do as such because matter displaces the plasma to a degree in matter. Gravity is nothing more then free plasma moving twords the vacuum that matter produces in the plasma. This has a slight effect on matter not connected to the matter that has attracted the free plasma around it. That effect is to draw free plasma twords the center of the body that is electrified. It's central apex where the voltage potential is highest. Walla you now know what gravity is. Free plasma with a base charge flowing twords the apex of displaced plasma withing the earth. The charge is not within our current abilities to detect except when you follow Tesla's examples. Lets look at voltage potential above ground level next.
 Tesla found out that if you connect one end of a wire to ground and placed a coil in line with that wire that the higher the free end of that wire goes the more voltage potential you can record across that coil. Why is that? There is a plethora of answers to that one question. One is the density of plasma around our planet. Of course since the planet is a sphere we conclude that plasma would layer due to it's density at set levels away from the source of potential in our planet. and the movement of less dense plasma as it rushes twords that source through differing layers.
 I like to make a case for the comparison of water to plasma. Since water is a good conductor as we are figuring out both in electrical and heat related methods we must conclude that the increased conduction is due to a very high plasma content. All effects we see around this planet including weather is driven for the most part due to this revelation. Tesla even talks about the ability to control the weather using his methods. Tesla talked about being able to turn the transmission of light off in an instant, even during the brightest day. This is because he figured out a way to condense or rarefy the plasma in effect turning off the ability of space due to ratification of the plasma field to reduce the conduction of space, this means even light. In his experiments he also found a way to create spontaneous pockets of light with no source apparent in a given space. This was done via his Transmitting system when used with impulses of high voltage potentials. Now I said Impulses not AC or RF but impulses.
 The proper explanation of what an impulse is, is a tough fight among the current understanding. But I will try to flesh it out for you. An impulse is nothing more then the plasma charged to a high state going in one direction, even if that direction is a wave around a central point. When the impulse wave hits matter it raises the potential of that matter in a one way direction. If you allow the matter to exhale or radiate out properly it should strengthen the connection to the environment and all transfers to the space around that matter will become augmented and in fact increase the density of the plasma within the matter for a period of time till it exhales or radiates that density back into the space around the matter. In this event of increased plasma within matter it makes that matter better at conducting within its body and further increases conduction externally for a short period. But as with the disruptive discharge experiments show, if you raise the potential of matter to the point where the space increases beyond matters ability to stay together then you have a very bad situation about to happen. You can liken this to blowing a balloon up beyond it's ability to hold that volume. POP. Very bad things happen indeed. Tesla talks about this as he experimented with very thin wires carrying the impulses to ground. The thinnest section under test would Blow like the finest dynamite of that day. DYNAMITE. This is some very powerful and potentially dangerous information. One warning I will give you. When impulses are concerned is heavy gauge wiring and use sectioned shielding to better contain the impulses twords your intended target.
 Now how do we get impulses? Well Tesla had a method that was fully adjustable in period and filtered the impulses to be truly one way. Here is a link to the device:
 http://www.tfcbooks.com/images/lectures/1892-02-03/004.gif
 The link also leads you to his lectures and more background of how he learned to manipulate the conductor of space, Plasma.
 More to come.
P.S. I know this is highly disorganized. I admit that but this is the tools I have to work with. My mind works the same way and it shows in my writing. There is so much to show that it is impossible to condense this information into a logical order in a single post. This is my problem and I am aware of it but I can not seem to get it right. Maybe through successive attempts someone can organize this information into something coherent for others to learn from. I need your help guys. I need a group of like minded individuals who really want to understand Tesla and his methods in the way that I do.
 Thanks for your attention
 jbignes5
 John Bigness
 Please ask questions and maybe that will get the ball rolling so we can understand this information.
 Also Russ G. I can help you with Marko Rodins device. After Talking With Marko he suggested that I get in contact with you. I chose skype and sent a contact request.
Title: Re: The real Tesla
Post by: Lynx on June 18th, 2016, 02:33 PM
Quote from jbignes5 on June 18th, 2016, 08:25 AM
 jbignes5
 John Bigness
If you are out to describe the truth, leave elegance to the tailor.
- A. Einstein
Keep up the good work, maybe there's some goodness waiting to reveal itself in there :thumbsup:
Post by: jbignes5 on June 19th, 2016, 07:52 AM
The one thing that I always come back to is a simple reflection on our capabilities we have today.
 Example:
http://phys.org/news/2010-12-laser-3d-submicron.html
 Who is to say this is not possible from someone else's scale. We can do it on our scale. Why is it so impossible that someone else like a giant could not do it on our scale from their scale?
 Just something for you to think about.. A random hmmm moment...
Post by: jbignes5 on June 19th, 2016, 11:42 AM
 Ok so no questions so far. That is not good..
 Maybe my oending work with Russ will yield some better information for you guys. Both Tesla's work and Marko's parallels each other. Listen there is a good reason Tesla would work out Fluid dynamic systems. Just think of the designs for that using a fluid like energy carrier. Start applying fluid dynamics to this device and you might see how to tune this system better.
 Oh great now I got to look at the turbine designs and see if we can apply this to that system using impulse technology. Think of the jack hammer tech we have now. Imagine the power of a system like this could be.. Mass I bet of the elements is a big limitation factor here.. Unless we find a way to use nano or even plasma connections to the plasma network. Remember space is dividing constantly. It is the very mechanism that drives All biological life and growth. Right down to cellular division and decay. Every point in our Universe is connected and as Vast as the eye can see. Are we becomming smaller or is everything growing from spacial division. This division is due to plasma dividing and condensing into smaller and smaller scales or to be exact higher degrees of density. There is no stopping it. It is fractal in nature and expands all around us.
 The reason they looked to the stars and why you are so intimately connected to that moment is because that is where you were born. in that specific arraignment of stars.
 Got to go for now more later....
Post by: Matt Watts on June 19th, 2016, 11:11 PM
Everything one needs is right here in this patent, which of all the patents I've read, this is the only one I have read where it is stated three times, the output power exceeds the input power.
