Open - Source - Research => Open-Source Research => Topic started by: Forum Administrator on April 3rd, 2011, 03:01 PM
Title: Lenz Lawless Generator V1
Post by: Forum Administrator on April 3rd, 2011, 03:01 PM
This is my take on the idea of the lawlessness generator.
The -9 zero free Lenz lawless generator v1
(http://rwgresearch.com/wp-content/uploads/2011/04/9_Zero-_Free_Genarater_V1-2.jpg)
(http://rwgresearch.com/wp-content/uploads/2011/04/9_Zero-_Free_Genarater_V1-3.jpg)
Here is the sketchup file:
http://www.ringsbyruss.com/youtube/-9_Zero%20_Free_Genarater_V1.skp
(http://rwgresearch.com/wp-content/uploads/2011/04/IMG_3759.jpg)
(http://rwgresearch.com/wp-content/uploads/2011/04/IMG_3760.jpg)
Building process of my work:
https://www.youtube.com/watch?v=EBbKOVGZ6Rw
Title: RE: Lenz Lawless Generator V1
Post by: txqNL on June 4th, 2011, 07:13 AM
Thats a very nice design looks a bit muller and others see;
http://www.weareonline.com.au/freeenergy/index.php?page=10
http://www.totallyamped.net/adams/  (page8)
http://home.mchsi.com/~actt2/index.html
These generators need special drive pulse sequencing, or like Ismael says;
- 1 Charge
- 2 Dischange to load
- 3 Save
https://www.youtube.com/watch?v=rv7C7YOetDY (~17:13)
Rotating magnatic generators could be controlled with the PulseFire code with external clock from encoder wheel.
With the ppm_data per output for custom pulse data.
Post by: Plengo on October 27th, 2012, 09:31 AM
Hello Russ,
what is the software you are using for the design?
You said in the video that "you cannot" take current from the generator and still be Lenz lawless?
Fausto.
Post by: Matt Watts on October 27th, 2012, 10:07 AM
Quote from Plengo on October 27th, 2012, 09:31 AM
I believe Russ used Google SketchUp(https://support.google.com/sketchup/?hl=en).
Low Lenz tends to mean the effect of pulling energy away is reduced not zeroed.  If you can reduce the Lenz effect to the point where you can pull enough energy away to power the drive motor, then you have accomplished unity, COP = 1, which is a great place to start.
Also keep in mind, MuMetal is magnet.  It will disperse the magnetic flux by being attracted to it, so you'll want the magnets and the MuMetal to be fixed relative to their motion.
Post by: ~Russ on October 29th, 2012, 09:46 PM
Quote from Dog-One on October 27th, 2012, 10:07 AM
yes  Google SketchUp(https://support.google.com/sketchup/?hl=en). a fantastic free simple drawing program...
the switching magmatic field indeed is not strong enough to pull hardly any current... it just will not deliver.
hope this helps! thanks!! ~Russ
