Post Reply
Thread Rating:
  • 0 Votes - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
God Driven Mechnics
08-05-2012, 03:07 AM
Post: #1
God Driven Mechnics
[Image: DaSValve.png]Building Instruction. Pipe. Pipe reducer. Squash ball. two one way valve.
Low presure PVC pipe and glue.
Mid pressure water pipe and screw or weld.
High presure line pipe and weld.
Works at any temperature above 1* Celsius.
Works on any liquid gassing at heat or any gas.
CO2 trialed it being Refrigerant R744 that flash cools upon exit of escape cylinder into capture box from where it is venturied into the drive cylinder.
Pulse is removed if required by installation of pressure pot.
Hydro turbine is by choice 60% to 90% efficient dependant upon type.
Piston force of 300 PSI compression Diesel at best burn (1,200*) Celsius is 100 bar. CO2 force of temperature rising from 30* Celsius to 100* Celsius is 7,000 bar. At 30* Celsius it be 60 bar and reducing to minus 39* Celsius.
http://i1225.photobucket.com/albums/ee39...SValve.png
Find all posts by this user
Quote this message in a reply
Post Reply
Forum Jump:
User(s) browsing this thread: 1 Guest(s)
