open-source-energy.org
rss
  • Search
  • Member List
  • Calendar
Hello There, Guest! Login Register
open-source-energy.org › OPEN-SOURCE-ENERGY.ORG › RWGRESEARCH.COM v
« Previous 1 2 3 4 5 6 Next »
The Fastest Way (for me) to Build Stan's Circuit and to Create a WFC kit
Untitled Document Click here to go back to RWGresearch
Pages (4): « Previous 1 2 3 4
Post Reply
Thread Rating:
  • 0 Votes - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Threaded Mode | Linear Mode
06-24-2012, 03:47 AM
Post: #61
Amsy Offline
Member
RE: The Fastest Way (for me) to Build Stan's Circuit and to Create a WFC kit
(06-22-2012 08:18 PM)Faisca Wrote:
(06-22-2012 01:57 PM)Amsy Wrote:  In the very beginning of my tests, I tried to produce the step charging effect in the simulation, after hours of simulating it was clear for me, that the "Step Charging" characteristic is nearly 100% of the loading characteristic of the inductor. Not of the capacity. Because the capacity is very small in comparison to the L.
So when pulsing the inductor it takes a litte time, then the full amount of current can go through. (like real DC). (Attachment 1) It looks like the C would load in steps, but thats the inductor, which will react like that.
This curve can be manipulated with the L, the frequency and the R of the WFC. But, the voltage is smaller as the input voltage, and the current will rise after a few pulses.
Depending on the voltage source, the resistance of the water will be more or less.
I used the equivalent circuit diagramm of Stanley Meyers Patent. But the only factor which change something is the resistance in the water. But I know always, that a simulation can never be like a real WFC/Circuit. it´s nearly impossible to bring in all values of the WFC. Also my consideration about the C in the WFC was, that the C -when the WFC is in action- will never be constant because of the flowing of the HHO bubbles. So is another factor, which can not be simulated.... better to test on real circuits.
I only can say, that the behaviour of the circuit is like normal electrotechnical behaviour. Also in my test, all electrotechnical laws are valid.
see it!
In their simulation, the result of "cell", is wave "sawtooth" nothing to do with what I showed.
This is important, let's stop dreaming of fantasies, and take what we have. There is no charge capacitor / inductor without energy, there's always a cost. So this waveform I show, is very important, it represents a great strength Instantané, at low cost. Can be compared to an ignition system ("CDI") or a modulator radar (microwave), or an echo sounder (pulses of short duration with 10kW. At a cost of less than 20W.).
In a conventional electrolysis, we can have 2V with 20A continuous. With the same energy cost (= 40VA), can (with resonant pulses) to 100V with 50A or more by instantaneous pulses (=> 5000VA). I know they are very narrow and separate pulses (greater period without power), but the equal of the examples I cited above, all work.
Think about it ..... or better yet, try it!
I see now what happend. I misunderstood the waveform of your drawings. But thats no big deal because it also shows, that with every puls the voltage will be bigger on the WFC.
By the way, I stopped dreaming, since I have usable measurments of my tests which cost a lot of time and money. Wink
Find all posts by this user
Quote this message in a reply
06-26-2012, 10:33 AM
Post: #62
Faisca Offline
Member
see it!
What I have shown, no big deal?
This is the strangest thing, I noticed in all the experiments conducted by myself. And this is a result which is only obtained with an inductor and a cell where it is clear that the cell is a different component of a capacitor, is unique.
Note carefully: the load curve, describing an arc upward exponentially. not a logarithmic curve, where the continuation of the load, tends to infinite in the horizontal, in this case, the continuation of the load tends to infinity vertically.
I forgot to comment on one thing: in this case, the bubbles appear in the middle of the gap, not the walls of the tubes.
You know what the speed of the ions in the water? I'm not sure, but a gap = 1 mm. is somewhere around 3 seconds (for a Amper). This reminds Puharich something?
« Next Oldest | Next Newest »
Post Reply
Possibly Related Threads...
Thread: Author Replies: Views: Last Post
  WATER FUEL CELL Technical Brief (Building, Testing and Understanding Stan's Work) gpssonar 595 27,959 Yesterday 01:38 PM
Last Post: kcrawford
  Stan Meyer pat WO92-07861 V Tesla pat 593,138 nav 42 1,243 06-13-2013 02:57 AM
Last Post: bussi04
  Step by step VIC build phil 419 102,408 06-11-2013 08:11 AM
Last Post: Dog-One
  • View a Printable Version
  • Send this Thread to a Friend
  • Subscribe to this thread
Forum Jump:
User(s) browsing this thread: 1 Guest(s)
  • Contact Us
  • open-source-energy.org
  • Return to Top
  • Lite (Archive) Mode
  • RSS Syndication
  • Help
Current time: 06-19-2013, 03:52 AM Powered By MyBB, © 2002-2013 MyBB Group. Theme Modified for RWGreasearch.com by open-source-research.com
