rss
  • Search
  • Member List
  • Calendar
Hello There, Guest! Login Register
open-source-energy.org › OPEN-SOURCE-ENERGY.ORG › RWGRESEARCH.COM v
« Previous 1 2 3 4 5 6 Next »
EPG Testing sequential pulsar using the Arduino
Untitled Document Click here to go back to RWGresearch
Pages (12): « Previous 1 ... 8 9 10 11 12
Post Reply
Thread Rating:
  • 1 Votes - 5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Threaded Mode | Linear Mode
03-25-2012, 12:40 PM
Post: #221
Jean-Alexandre Offline
Junior Member
RE: EPG Testing sequential pulsar using the Arduino
(03-25-2012 10:51 AM)txqNL Wrote:
(03-20-2012 06:16 PM)Jean-Alexandre Wrote:  I have a problem for connect a lcd 2x16 (lmb162abc)
In interface pulsefire lcd size is disconnect.
someone have a idea ?
a last question!
what s different between atmega328p-006, atmega328p-006-isp
and between atmega328p-xxx ?
i have arduino duemilanove and lmb162abc lcd
HI Alex thanks for checking out pulsefire, if the lcd size drop down stay on 'disconnected' after connecting to the chip then the firmware in the chip is one without lcd support. The lmb162abc looks like normal lcd and should work.
The makefile is a bit messy as I'm not really good in makefiles.
But the difference between atmega328p-006, atmega328p-006-isp is todo development on one fireware at once and flash it to test it without compiling all firewares every time.
As for the multiple images pulsefire has different features and connect configurations for one chip.
So these images are provided in the gui as precompiled multiple images to choose based one enabled options flags.
This is not yet complete but currently its like this;
atmega328p-001 - No lcd support but 6 analog inputs.
atmega328p-002 - lcd, connections like first schemetic.
atmega328p-003 - lcd on 74xx595 chip.
atmega328p-004 - lcd 595, 8 out on 595
atmega328p-005 - lcd 595, 2*8 out 595
atmega328p-006 - lcd 595, 2*8 out 595, 74xx153 multiplex digital in to 8 in.
atmega328p-007 - lcd 595, 2*8 out 595, dic on 153, 8 digital output on 595.
atmega328p-020 - no lcd, 8 out on 595
atmega328p-021 - no lcd, 2*8 out 595
atmega328p-022 - TEST no lcd,no pwm,no ppm
There are two schematics on http://pulsefire.nongnu.org/schematic.html the fist one is for atmega328p-002 and the second one is for the others.
Tank you so much txqNL
I used the first. and it s work. I just a small problem on configure a trigger for change the frequency. I do not know how.
Find all posts by this user
Quote this message in a reply
03-26-2012, 01:43 AM
Post: #222
Muxar Offline
Member
Is this spark the energy that we want to catch with the EPG?
http://www.youtube.com/watch?v=ORLnfr3EcxE
interesting effect anyway...
03-26-2012, 06:55 AM
Post: #223
firepinto Offline
Moderator
(03-26-2012 01:43 AM)Muxar Wrote:  Is this spark the energy that we want to catch with the EPG?
I've seen this effect while vacuuming very dry fine sand with a vacuum hose. The charges about through me on my rear. I think the spark gap was almost an inch.
Ideas are bullet proof.
[Image: sig.php?id=1286]
04-29-2012, 02:29 AM (This post was last modified: 04-29-2012 03:14 AM by Dogs.)
Post: #224
Dogs Offline
Junior Member
I deleted my post regard ElectroStatic Pulsing over Magnetic Pulsing.
After reviewing the thread below...
/showthread.php?tid=400&pid=4658#pid4658
I understand now that using magnetics is the ideal mode of use of the EPG, but requires the Argon/Cobalt/Nickel, magnetically polarized gas matrix.
I also, reviewed the "House meeting in New Zealand" video where Stan talks about the EPG and the magnetized gas.
I thought for sure that Stan talks about water propulsion on some video...
Maybe I just mis-understood what he was talking about...
Just reviewed the 3rd video of the "House meeting in New Zealand", where he covers the fact that when using laser light within the EPG (He does this to increase the mass of the atomic gas matrix), then, you no-longer need to motivate the gas, because it's the shock wave of the light itself that causes the electrical field generation (which is then caught by the pickup coils), as the electrons move away from the atomic nucleus, which then results is a higher magnetic energy in the gas. Thus, powering all of New Zealand with a single EPG, and entering the relm of OU.
Fascinating...
Now, back to the Magnetic Gas Lattice...
Argon (Lubricator, Non Electric, Non Magnetic)
Cobalt Ions
Nickel Ions
Cobalt Ions
Co^2+, Co^3+
Generate using HV to a pure Cobalt wire.
Nickel Ions
Ni^2+, Ni^3+
Generate using HV to a pure Nickel wire.
Iron Ions
Fe^2+, Fe^3+
Generate Cobalt and Nickel Ions using HV within an Argon filled chamber.
- Pass Gas Mixture through VIC and expose to laser energy.
- This destabilizes the Atomic Structures of the main elements in the Gas. So that that we can extract some electrons from them.
- Use electron extraction circuit to remove extra electrons. Now our atoms will be will to take on covalent bonds that they would normally never take on.
- Allow Unstable Gas to stabilize into the new Gas Matrix by making new covalent bonds.
Pump gases into EPG.
Test EPG for appropriate Magnetic Qualities of the Gas Lattice.
- Does pulsing it result in some energy output from the pickup coils?
*****! That boy was Brilliant!
- Not just theory, but applied science.
- Mechanics, Electronics, Chemistry, Nuclear Physics...
- Amazing stuff!
-Dogs
05-09-2012, 12:56 PM
Post: #225
Junior Member
Hello
HZ is set at 364.5 but never above.
With the multi meter I get about 5kHz.
LCD => 364HZ? => Multimeter 5kHz
I think we should configure the board to exceed the limit value of 5 kHz (364 LCD).
Someone does it the right configuration?
sorry for my english Sad
05-10-2012, 05:23 AM (This post was last modified: 05-10-2012 05:24 AM by ~Russ/Rwg42985.)
Post: #226
~Russ/Rwg42985 Offline
Administrator
(04-29-2012 02:29 AM)Dogs Wrote:  I deleted my post regard ElectroStatic Pulsing over Magnetic Pulsing.
Fascinating...
Cobalt Ions
Nickel Ions
Cobalt Ions
Co^2+, Co^3+
Nickel Ions
Ni^2+, Ni^3+
Iron Ions
Fe^2+, Fe^3+
- Amazing stuff!
-Dogs
goos stuff dogs, im posting this over at this thread:
http://open-source-energy.org/forum/show...06#pid4906
all, please post reply's there to this post!
"I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer
"We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997"
"If you believe, even tho you can not see, you will see." ~Russ Gries
Visit this user's website Find all posts by this user
05-17-2012, 11:11 AM
Post: #227
daristo Offline
Newbie
Hi Rush
PULSEFIRE To replicate your project, you could tell me please what is the schema and the code of the final program.
I followed the forum but can not find the final version shown in their videos.
See you soon.
05-17-2012, 04:35 PM (This post was last modified: 05-17-2012 04:37 PM by Jean-Alexandre.)
Post: #228
Junior Member
(05-17-2012 11:11 AM)daristo Wrote:  Hi Rush
See you soon.
You can get the last version here.
http://www.nongnu.org/pulsefire/source-repository.html
and here
http://open-source-energy.org/forum/show...hp?tid=440
Alex
05-17-2012, 10:23 PM
Post: #229
Jeff Nading Offline
Posting Freak
See you soon.
and here
Alex
Thanks Jean.Big Grin
As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.Big Grin
05-19-2012, 07:18 PM (This post was last modified: 05-20-2012 06:38 AM by Jean-Alexandre.)
Post: #230
Junior Member
Hello My realisation here
https://picasaweb.google.com/s/c/transpa...round.gif) no-repeat left">
Projet HHO
Alex
Post Reply
Possibly Related Threads...
Thread: Author Replies: Views: Last Post
  Arduino VIC resonator zchiotis 56 2,510 Yesterday 03:16 AM
Last Post: bussi04
Star Stanley Meyers EPG System admin 23 11,290 05-23-2013 12:08 PM
Last Post: securesupplies
  WATER FUEL CELL Technical Brief (Building, Testing and Understanding Stan's Work) gpssonar 573 24,585 05-09-2013 11:53 PM
Last Post: Dog-One
  • View a Printable Version
  • Send this Thread to a Friend
  • Subscribe to this thread
Forum Jump:
User(s) browsing this thread: 1 Guest(s)
  • Contact Us
  • open-source-energy.org
  • Return to Top
  • Lite (Archive) Mode
  • RSS Syndication
  • Help
Current time: 05-25-2013, 12:59 PM Powered By MyBB, © 2002-2013 MyBB Group. Theme Modified for RWGreasearch.com by open-source-research.com
