Post Reply
Thread Rating:
  • 0 Votes - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Electric charge in SS tubing.
05-14-2012, 12:07 PM
OK, here's what I'd like some input on.
The basic setup would have two tubes shaped as a spiral,
one is the anode, the other is a cathode.
Now you pump a cooling fluid through the center of these charged tubes.
Like the electrolyte touching the exterior of these tubes, the fluid on the inside of these tubes should carry a current.
Any thoughts on the effects this may cause?
Find all posts by this user
Quote this message in a reply
05-14-2012, 07:54 PM (This post was last modified: 05-14-2012 07:55 PM by Jeff Nading.)
RE: Electric charge in SS tubing.
(05-14-2012 12:07 PM)Robert Twiss Wrote:  OK, here's what I'd like some input on.
Don't really understand your question Robert, is this something you are building, something you want to build or just a question about an idea you have? Do you have a photo of the item? Never have I seen a spiral tube setup before, maybe someone else has and could reply to you, better than I. Sorry , Jeff.Smile
As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.Big Grin
Visit this user's website Find all posts by this user
05-14-2012, 09:20 PM
Your idea poses a lot of questions. What kind of fluid? What is the temperature difference? Is the cooling fluid super cooled? What kind of container is it in? What direction is the cooling fluid running? What is the exterior fluid doing? Are the tubes powered/AC/DC/pulse/etc? What do you hope to accomplish with it? Are the tubes together or separate?
My suggestion is that you build something similar to what you have in your head and then post pictures, data and results.
My thought is that one of the tubes needs to be a different material, like copper. It is an interesting thought, but it needs some more fleshing out.
Happy hunting! Wink
-Jonathan Frisch
Let's take over the moon...
05-15-2012, 08:18 PM
Thanks guys,
The basic idea is to use tubing instead of wire or rod to create a sprial wet cell.
Most likely DC powered.
The tubing would allow you to pass liquid through the inside of the tube for a cooling liquid.
05-15-2012, 08:46 PM
(05-15-2012 08:18 PM)Robert Twiss Wrote:  Thanks guys,
There is really no need to cool the SS tubes because of using only 1/2 of an amp they don't get hot. You could pump water through them, just to move the HHO bubbles. Also how would you spiral a SS tube and get the inner tube the same as the outer tube, would not be cost effective to say the least, that's why Stan used SS tubing it was easy to get , he was looking for cheap ways to get it to market so to speak.Big Grin
05-15-2012, 09:15 PM
This is the basic idea.
05-15-2012, 10:41 PM
(05-15-2012 09:15 PM)Robert Twiss Wrote:  This is the basic idea.
Very interesting. Kind of looks like a transformer.
-Jonathan Frisch
05-16-2012, 01:11 AM
Post: #8
sounds like a good way to keep the water cool in the cell... but, you will need 2 different water baths or you will start to produce hho on the in side of the tubes ?!?!
"I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer
"We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997"
"If you believe, even tho you can not see, you will see." ~Russ Gries
05-16-2012, 07:16 AM
Post: #9
Very good point, are you saying one for the positive and one for the negative?
The actual design I am working has 4 spirals per cell and two connected cells to seperate the H and O. I was hoping to use a magnetic induction and tank circuits but I don't think I can induce a strong enough magnetic field in the internal coils which would have had heavy copper wire inside the SS tubes.
05-16-2012, 02:34 PM
Post: #10
This is a little more in depth of my concept.
This is the CORE of the HHO cell.
05-16-2012, 07:20 PM
Post: #11
My design is becoming more refined.
Initially I was going to use magnetic induction, now i plan to use a cooling concept, if i need it. I started to make a mock up but I has structual issues, the spacing was to close and created weak spots.
Changing the spacing gave me 3 conical spirals.
I was worried the cooling fluid would carry a current but Russ pointed out that it may also create HHO, that means I'll have to devise a recovery system.
This image was not created with a cad program, I used Corel DRAW.
The spirals will be made of 1/4" 316 SS Welded Tubing.
05-17-2012, 03:40 AM
Post: #12
(05-16-2012 07:20 PM)Robert Twiss Wrote:  My design is becoming more refined.
quite interesting! not sure what your thoughts are on the netrules but i would say in this application they would not make gas... the voltage would just bypass them... ??? i have know idea!
one can only try but this concept is very interesting.
cool beans! one can only try! Smile
PS. i will try to call you some time.
05-17-2012, 02:36 PM
Post: #13
I thought that the neutral spirals would act like the neutrals in a dry cell.
05-25-2012, 08:28 AM
Post: #14
Well from the looks of your design.. Conductivity of the liquid in the tubes, and the direction it flows might make a big difference in what actually happens when you fire it up. Not sayin it won't work. Exactly the opposite.. With proper flow(liquid flowing the same direction that the voltage flows in its respective tube).. It looks like it will do more than you expect. In a good way. Especially if the liquid has the same charge as its tube. Looks like you might be opening a door sir. Taking a concept usually applied to an "ethereal item" and applying to a "corporeal item". Shame you can't rotate the cell while its active. Plot it on a 3D graph. Rotate it on the x axis where all values of x stay constant. Y axis would change from the length of the cell (highest value) to the diameter of its base (lowest value) . With the z plotted in a circle. Just a thought.
05-25-2012, 02:09 PM
Post: #15
Very interesting reply, thank you.
It all looks good on paper, then there's reality.
A failure may only be the confirmation that the theory is not valid.
It does not mean that there is no solution.
To solve a problem, you must define it.
A High School Kid just solved a 300 year old mathematical conundrum involving trajectories.
07-11-2012, 01:05 AM
Post: #16
supple gas lines constructed of coated, corrugated stainless steel tubing (CSST) may be the culprit in some lightning-related fires and gas leaks in at least one dozen states, raising concerns about CSST use for gas lines.
Soldertools.net - leading exporter and manufacturer of Circuit Frame
Post Reply
Possibly Related Threads...
Thread: Author Replies: Views: Last Post
  Please help me. i want to charge two batteries 12v7a+12v7a=12v14a parallel kami_rock55 2 227 02-07-2013 10:57 PM
Last Post: waf77
  Electric Vehicle Discussion List - evdl dot org FloatyBoaty 33 2,943 06-23-2012 11:22 AM
Last Post: FloatyBoaty
Forum Jump:
User(s) browsing this thread: 1 Guest(s)
