Vortex Based Research - Coils & Testing (Part 2)
04-04-2011, 11:40 AM
(This post was last modified: 04-20-2011 01:22 AM by admin.)
The Coils and Testing Threads are really the same thing, just split to reduce load time.
(Part 2) This a a micro star-ship coil. it is 3/8" OD Here is a tiny Rodin coil. the wire is thinner than your hair! Here is a couple of 1" star-ships coils. i have made a bunch of these. Here is a couple of other starship coils i have made. Here is a big HVTWRC. Here is a HVTWABHAC, in this photo there is only 2 of 10 windings. This is a 3 point rodin style coil it has one wind on it. Here is a big fat starship coil. This is a star-challis coil, this one is a 36 point. This is a 12 point star-challis coil. Thanks, ~Russ Gries |
09-05-2011, 11:55 AM
RE: Vortex Based Research - Coils & Testing (Part 2)
Hey man, hopw life's treating you well! Have you done any more testing with the ABHA clad coil and the six-pilser yet? Im really exited to see how it will behave with sophisticated energizing
Peace.
09-05-2011, 01:28 PM
(09-05-2011 11:55 AM)Casper Wrote: Hey man, hopw life's treating you well! Have you done any more testing with the ABHA clad coil and the six-pilser yet? Im really exited to see how it will behave with sophisticated energizing well, with all the other projects the ABHA coil is on the shelf. but i have the Pulse Fire Box now to test the 6 channels with... so when i get time... i will try to finish it and see whats up! thanks! ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
05-11-2012, 05:44 PM
(This post was last modified: 05-11-2012 05:50 PM by simondodd.)
Hey guys, I have just built my first Star Chalice coil, (actually I built 2 but the first one wasn't tight enough.
I had a thought about bifiliar winding one of these... Do one layer of phase 1 and then 1 layer of the second phase 10 degrees clockwise from the start of the first phase leaving the third phase free as in the rodin coil... Has this been done before? Does that even make sense...? |
05-12-2012, 08:42 AM
(05-11-2012 05:44 PM)simondodd Wrote: Hey guys, I have just built my first Star Chalice coil, (actually I built 2 but the first one wasn't tight enough.PM firepinto, I think he will be able to answer your question, Jeff.
As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.
05-12-2012, 10:51 AM
(05-12-2012 08:42 AM)Jeff Nading Wrote:(05-11-2012 05:44 PM)simondodd Wrote: Hey guys, I have just built my first Star Chalice coil, (actually I built 2 but the first one wasn't tight enough.PM firepinto, I think he will be able to answer your question, Jeff. I'm not sure if that has been done before. I actually haven't tried making a star chalice coil. It's worth a try to experiment and see if there is different results. I mostly messed around with rodin style windings in a different type of multiplication table sequence. You can see what I did here: http://www.firepinto.com/rodin_coils.html http://www.firepinto.com/rodin_math.html Nate Ideas are bullet proof. |
05-13-2012, 12:13 AM
(05-11-2012 05:44 PM)simondodd Wrote: Hey guys, I have just built my first Star Chalice coil, (actually I built 2 but the first one wasn't tight enough. these coils seem to be better as a pickup coil than an output coil... ![]() i have done bifilir starship with an offset of 10 degrees. i have built a bifilar with no offset on a Star Chalice coil. was going to use it as a dubble pulse coil... all depends on the application! ![]() build, test, post, learn! ![]() ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
12-15-2012, 10:07 AM
Post: #8
just subscribing. I hope someone can help me figure out how to subscribe to a thread without posting a message. The program doesn't seem to let me do that.
12-19-2012, 08:55 AM
Post: #9
(12-15-2012 10:07 AM)Frank Grimes Wrote: just subscribing. I hope someone can help me figure out how to subscribe to a thread without posting a message. The program doesn't seem to let me do that. Hi Frank, look at the lower left corner of the thread your on, there will be a selection to subscribe, click on that, then you will be subscribed.
12-19-2012, 06:49 PM
(This post was last modified: 12-19-2012 07:26 PM by Frank Grimes.)
Post: #10
(12-19-2012 08:55 AM)Jeff Nading Wrote:(12-15-2012 10:07 AM)Frank Grimes Wrote: just subscribing. I hope someone can help me figure out how to subscribe to a thread without posting a message. The program doesn't seem to let me do that. Yes, I've tried doing that. I get some kind of incompatible message. My work-around has been to post a message, which then causes me to be become subscribed. I have also figured out that I can go back and delete the meaningless message, and still remain subscribed to the thread. I just can't figure out why the "subscription" link doesn't work directly. Anyway, I am managing to get subscribed to all the topics which interest me. Thanks much for responding. PS Here's the exact message: Authorization code mismatch. Are you accessing this function correctly? Please go back and try again. I always get that message when I click on the link to subscribe to a thread without posting a message. |
| Possibly Related Threads... | |||||
| Thread: | Author | Replies: | Views: | Last Post | |
| WATER FUEL CELL Technical Brief (Building, Testing and Understanding Stan's Work) | gpssonar | 573 | 24,400 |
05-09-2013 11:53 PM Last Post: Dog-One |
| Meyer Demo Cell Replication for University Testing by JP | MeyerandMe | 230 | 31,291 |
03-19-2013 03:37 PM Last Post: MeyerandMe |
| Vortex Based Research - The Math | admin | 7 | 2,587 |
02-22-2013 07:36 PM Last Post: Dog-One |
User(s) browsing this thread: 1 Guest(s)
Peace.
