Building The Russtic WFC Freq Gen V7.0
01-08-2012, 07:39 PM
(This post was last modified: 01-08-2012 07:47 PM by KevinW_EnhancedLiving.)
Post: #21
RE: Building The Russtic WFC Freq Gen PCB V7.0
Hey Dave, thanks for joining the convo.
Thanks for posting the drawing Russ!! Suprized you still have that .So dave that drawing only shows the amp meter wiring withe the 4P2T Switch, the voltage meter is pretty strait forward with a 2P2T Switch. These switches are not needed and were only used to save space and meters, So I was able to use 2 meters instead of 4. (Also the large 4P2T switch is just about impossible to find, another reason why I didn't post that part) Good Luck, Kevin (01-08-2012 06:19 AM)dlpatte Wrote: Thanks Russ. And, thank you and Kevin for the great work you are doing. |
01-10-2012, 02:08 AM
Post: #22
(01-08-2012 06:19 AM)dlpatte Wrote: Thanks Russ. And, thank you and Kevin for the great work you are doing. any time, i do what i can! thanks, ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
01-16-2012, 10:51 AM
(This post was last modified: 01-16-2012 10:57 AM by KevinW_EnhancedLiving.)
Post: #23
http://open-source-energy.org/rwg42985/r...ircuit.png
This is a good example of how to connect your Cell |
01-19-2012, 02:39 PM
Post: #24
Tutorial!!
01-19-2012, 05:34 PM
Post: #25
(01-19-2012 02:39 PM)KevinW-dirtwill Wrote: Tutorial!! That's awesome Kevin, I will be building one, after I finish two other projects, thanks. As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.
01-21-2012, 04:15 PM
Post: #26
Such a beatiful post I had to read it over, nice work!
Reps for thread creator. |
01-22-2012, 06:25 PM
Post: #27
Many thanks for the Thanks everyone. Happy Building
01-23-2012, 01:52 PM
(This post was last modified: 01-23-2012 01:55 PM by KevinW_EnhancedLiving.)
Post: #28
Does anyone know how permeability/core structure affect the collapsing field of an inductor?
01-23-2012, 03:28 PM
(This post was last modified: 01-23-2012 05:46 PM by KevinW_EnhancedLiving.)
Post: #29
Frequency modulation
01-23-2012, 05:54 PM
Post: #30
(01-23-2012 03:28 PM)KevinW-dirtwill Wrote: Frequency modulation Very nice Kevin, could that be oscillation of resonance, I can't wait to try that. As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.
01-23-2012, 11:10 PM
Post: #31
When you tune a stringed instrument you get the same thing. Peaks of your waveforms slightly out of tune heh heh... Yeah, frequency modulation.
Cool vids, love the generator! Keep up the great work. Derrick |
01-29-2012, 01:23 PM
Post: #32
(01-23-2012 05:54 PM)Jeff Nading Wrote:(01-23-2012 03:28 PM)KevinW-dirtwill Wrote: Frequency modulation Nice work Kevin!! I´m making my own now, it´s almost finished!! Is it any problem if i use the same power supply for all the squematic?...can i use the alternator supply(14v) for driver circuit? Thanks!! |
01-29-2012, 02:05 PM
Post: #33
(01-29-2012 01:23 PM)Muxar Wrote:(01-23-2012 05:54 PM)Jeff Nading Wrote:(01-23-2012 03:28 PM)KevinW-dirtwill Wrote: Frequency modulation Hey Muxar, You can defiantly use 14V supply for both supplies, 5V system just wont be isolated. Just add a fuse before each regulator and you should be fine. Something like .5 - .7A fuse on the 5V side The 7805 tends to get fairly hot. Even when I'm using a small cell phone charger. So maybe you could throw in a porcelain resistor before it to take some of the heat off?? As for voltage comming off a alternator im not sure how that would affect the system. but should be ok, i would think... |
01-29-2012, 03:14 PM
(This post was last modified: 01-29-2012 03:53 PM by KevinW_EnhancedLiving.)
Post: #34
(01-29-2012 02:05 PM)KevinW-dirtwill Wrote:(01-29-2012 01:23 PM)Muxar Wrote:(01-23-2012 05:54 PM)Jeff Nading Wrote:(01-23-2012 03:28 PM)KevinW-dirtwill Wrote: Frequency modulation When you connect both 78xx reg to the same source there is a physical connection for back spikes to possibly enter and harm your system. When there is a transformer on the 5V side this removes the physical connection. |
02-22-2012, 02:01 PM
(This post was last modified: 02-22-2012 02:05 PM by ~Russ/Rwg42985.)
Post: #35
RE: Building The Russtic WFC Freq Gen V7.0
Rustic PCB build
enjoy... ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
02-22-2012, 04:02 PM
Post: #36
(02-22-2012 02:01 PM)~Russ/Rwg42985 Wrote: Rustic PCB build Good job Russ, I so want to try that, have not had the time. As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.
02-23-2012, 07:02 AM
(This post was last modified: 02-23-2012 07:09 AM by ~Russ/Rwg42985.)
Post: #37
the Russtic 7.0 done and pulsing a VIC...
enjoy ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
03-01-2012, 09:48 AM
Post: #38
If anyone has more sources for the TLP-250 chips, Please post them!!
Thanks Kevin |
03-03-2012, 07:41 AM
(This post was last modified: 03-03-2012 07:49 AM by ~Russ/Rwg42985.)
Post: #39
(03-01-2012 09:48 AM)KevinW-dirtwill Wrote: If anyone has more sources for the TLP-250 chips, Please post them!! ha, that's what i'm working on... lol~Russ http://www.findchips.com/ref/TLP250 http://search.digikey.com/scripts/DkSear...250%28F%29 http://oeicl.member.seekic.com/product_c...LP250.html http://www.jameco.com/webapp/wcs/stores/..._765142_-1 http://www.wvshare.com/product/TLP250.html http://www.donberg.ie/catalogue/semicond...p_250.html http://www.embeddedprojects.org/index.ph...&Itemid=27 "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
04-21-2012, 12:14 PM
Post: #40
HI Guys missed this thread, very nice,
as a summary can you post gerber file format and final excel parts list will start to build now . Dan |
« Next Oldest | Next Newest »
| Possibly Related Threads... | |||||
| Thread: | Author | Replies: | Views: | Last Post | |
| WATER FUEL CELL Technical Brief (Building, Testing and Understanding Stan's Work) | gpssonar | 573 | 24,539 |
05-09-2013 11:53 PM Last Post: Dog-One |
| WFC must see...Preventing water Short..... | Heuristicobfuscation | 17 | 1,233 |
04-14-2013 01:34 PM Last Post: FaradayEZ |
| Water Fuel Cell (WFC) Resonance - Stanley Meyer`s Secret | HillBillyBob | 2 | 448 |
03-13-2013 09:19 AM Last Post: HillBillyBob |
User(s) browsing this thread: 1 Guest(s)
