Hydrogen gas gun, Gas Possessor, Gas Ionizer.
01-11-2012, 05:22 AM
(This post was last modified: 01-11-2012 05:33 AM by ~Russ/Rwg42985.)
hey guys, so im making this post for my work and thoughts and build on the hydrogen gas gun, or Gas Possessor, witch is basically a DC ionizer.
one can get more info here: http://www.hereticalbuilders.com/showthread.php?t=174 copped from RWGresearch.com : Quote:Here you will find some information on the HGG “Hydrogen Gas Gun”. so my next thing is to get some mesh to extract the electrons, so here is what i'm considering: http://www.mcmaster.com/#stainless-steel...cs/=fr97lq i also think that the center " tube" needs to be a single wire and then you can use a smaller voltage to do the same thing as you will have a smaller brake out point. any thoughts on this? ~Russ Gries "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
01-11-2012, 01:11 PM
RE: Hydrogen gas gun, Gas Possessor, Gas Ionizer.
Hey Russ,
I Just have 1 question about the light array in the gas gun. In the document titled The Birth of New technology section 1-8 Stanley states that he uses a laser which cause atoms to lose electrons. He also indicates that the light comes from red LED lights. Is there a reason he uses red light? Why not use an actual laser? Have you tried this with a green laser? The energy emitted from a green laser is much greater then that of a red laser. Would it be possible that using a green laser would cause more atoms to lose electrons then red LED's? Thanks for all you do! |
01-11-2012, 03:53 PM
(01-11-2012 01:11 PM)HHO4Life Wrote: Hey Russ, Its all about the wavelength, the wavelength needs to match the absorbtion/emmision spectrum of whatever it is you are trying to ionize. When the gas is exposed to certain wavelengths of light the electrons become excited and move up in energy level, the electrical energy needed to remove them from the structure fully is then less. Heres a little pic (sorry its come out so small) emission spectrum of hydrogen.bmp (Size: 76.62 KB / Downloads: 91)
The 656 band of light is at the red end of the spectrum. You could use a 486nm green led too or any of the others, but some wavelengths will cause more of a jump in energy levels than others, You could get a laser tailor made to whatever wavelengths you like i spose if you got the money, leds are much cheaper. It seems like the leds were also pulsed to gain an amplification. So you end up with a chamber that uses pulsed led light and high voltage to ionize the gas, then the electron extraction circuit kicks in (alternate power swich in fig 1-14) and burns off the liberated electrons in the amp consuming device. Hope that helps a bit. |
01-12-2012, 04:13 AM
(01-11-2012 03:53 PM)phil Wrote:(01-11-2012 01:11 PM)HHO4Life Wrote: Hey Russ, yes, phill is right on the money, here is a good thread to read: http://open-source-energy.org/forum/show...php?tid=89 this ill help you. and your welcome! thanks for all the support and everything all is doing to help as i would not be this far! thanks world! ~Russ
01-14-2012, 12:18 AM
01-15-2012, 01:27 AM
(01-14-2012 12:18 AM)KevinW-dirtwill Wrote: Russ, I know your working on the extraction grid first, but what about the circuit that uses scr's or transistors? (EEC circuit) Another question, how do you think the gas gun differs between the one made to process hydrogen and oxygen and the one used on the intake of the buggy? |
01-17-2012, 06:38 AM
(This post was last modified: 01-17-2012 06:42 AM by ~Russ/Rwg42985.)
(01-15-2012 01:27 AM)Davecbwfc Wrote:(01-14-2012 12:18 AM)KevinW-dirtwill Wrote: if we know how it works... we know the principles... we can build it how ever we want... haha scrap the SCR... we have better things now. so, no i dont plan on using an SCR. but that's just at the moment. i haven't studded the EEC to its deepest point. the russtic gen 7.0 will allow me to control external outputs at alternating times. (180 out a phase) i plan on making an external circuit that the russtic will run. but SCR's are something i may or may not use. havet gone that far on finding what components im going to use... soon i will tho! still working on the corona wire and such as im having arc problems... i think i need higher voltage with less amperage... and the wire needs to be as small as possible. the less surface area on the high voltage side of things the better... the less amperage i need to use. attached is some photos of the EEC grid in my gas gun. (water Faucet aerator) still not sure if the gas gun and gas possessor are the same... im going to say yes. but one is for air. see the way Stan was making gas the gas was already ionized... so no need to run the h h o in to the processor as the effect is already there. he talks about this in his videos. high voltage brake down of the water will have some other effects that just braking it down??? thanks! ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
01-17-2012, 01:56 PM
Post: #8
(01-11-2012 05:22 AM)~Russ/Rwg42985 Wrote: hey guys, so im making this post for my work and thoughts and build on the hydrogen gas gun, or Gas Possessor, witch is basically a DC ionizer. I don't know about that Russ, I just wanted to say your Gas Processor is a work of art! Beautiful! Those who expect to reap the blessings of freedom, must, like men, undergo the fatigue of supporting it. ~Thomas Paine MY BLOG |
01-19-2012, 08:47 PM
Post: #9
Finding that mesh for the EEC gas grid with the right width for your project was awesome. Like you said, clearly you're on the right track
![]() Peace , Love and Well-Being![]() Alexsei |
01-20-2012, 04:16 AM
(This post was last modified: 01-20-2012 04:19 AM by ~Russ/Rwg42985.)
Post: #10
(01-19-2012 08:47 PM)thisuser Wrote: Finding that mesh for the EEC gas grid with the right width for your project was awesome. Like you said, clearly you're on the right track agreed!!! thanks!!! here are the videos in this new series: Love the hair? Hahaha ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
01-20-2012, 04:56 PM
Post: #11
(01-20-2012 04:16 AM)~Russ/Rwg42985 Wrote: Love the hair? Hahaha ~Russ Yes! hahah but having long hair myself I can appreciate not liking it in my face/eyes when I'm working away hehe I really like your reuse/recycle approach to your work and being inspired by what you're doing, I am looking at some of the patents you have on your site to see what I'd like to start building and testing myself and sharing the results, with love ![]() Peace, Love and Well-Being, Alexsei |
01-21-2012, 02:22 AM
Post: #12
(01-20-2012 04:56 PM)thisuser Wrote:(01-20-2012 04:16 AM)~Russ/Rwg42985 Wrote: Love the hair? Hahaha ~Russ haha wonderful my friend! yeah, EPG, Adjusting the burn rate, VIC, VIC controls, WFC, quenching disk, and a few others is where i started... lol a bit too many at once perhaps? life is grand... lol challenging but grand...Be Blessed! ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
01-26-2012, 02:49 PM
Post: #13
The gun looks great Russ! I love your work man I love it!
01-27-2012, 06:01 AM
Post: #14
(01-26-2012 02:49 PM)HHO4Life Wrote: The gun looks great Russ! I love your work man I love it! thanks my friend!!! just trying to get this stuff proven or disapproving!!! lol ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
01-27-2012, 02:53 PM
Post: #15
Very cool vids Russ!! Your craftsmanship (and hair) are awesome!
Regarding the arcing, maybe your components are too close together for the voltage you're working with? Or you had greasy fingers when you put it together heh heh... ![]() An idea I just had: Is there a way to run water between the central corona chamber and the LEDs? If you can imagine another tube with a space between them for water to flow. Could you make it do 'double duty' and strip electrons directly from the water using the same method? Keep up the great job!! Derrick |
01-27-2012, 04:23 PM
Post: #16
The hair definitely goes with the mad Scientist thingy! lol :-D
01-28-2012, 01:29 PM
Post: #17
Hi Russ! Congratulations on your work!
I'm still reading all the theory, but I have a question? What its the amount of current your are using in the video, is it 20 A? have you find the resonance frecuence in some point? I'm trying to build a digital generator with control electronic included.. I don't have any commercial purposes,so I would like to share my research in the forum if its ok with you. Sorry about my english, I'm from Argentina.. Thanks! |
01-28-2012, 01:34 PM
(This post was last modified: 01-28-2012 02:45 PM by Jeff Nading.)
Post: #18
(01-28-2012 01:29 PM)fedeperis Wrote: Hi Russ! Congratulations on your work!The amperage is just experimental right now but Stan was using very low amps [1/2 an amp] with high voltage, and please feel free to post any results you wish to, we are all in this together, Jeff. As for most if not all of mans inventions and discoveries, we have or had to observe Gods Creation's, this in it'self proves he exists. Rom. 1:20. Have a good one, Jeff.
01-28-2012, 01:36 PM
Post: #19
Thank you Jeff! instant answer! ejej
(01-28-2012 01:34 PM)Jeff Nading Wrote:(01-28-2012 01:29 PM)fedeperis Wrote: Hi Russ! Congratulations on your work!The amps is just experimental right now but Stan was using very low amps [1/2 an amp] with high voltage, and please feel free to post any results you wish to, we are all in this together, Jeff. |
01-29-2012, 12:24 AM
Post: #20
(01-27-2012 02:53 PM)BaronBassman Wrote: Very cool vids Russ!! Your craftsmanship (and hair) are awesome! ahhhh, nice idea with the water. i will keep that in mined for the future!!! now one thing that you need to understand is that the LED's are suppose to do is reflect off the inner electrode and amplify the intensity of light. or that is a theory i was told. like a laser pumping effect. but im not sure how true that is. time will tell. i mean yes, the more intense the light is the better. so it makes scene, i'm just not sure that stan had his set up like that. so, the water would effect that but it would be cool to make that way... cool idea! i don't know if it would strip electrons from the water with out being in the corona field yeah. i believe its oil or something... its not arching its just burning off the oil or what ever... hah kinda crazy. thanks for the input !!!! ~Russ "I had to go to a source of power greater than Stan Meyer in order to try and bring in this form of technology. And the Lord said that this knowledge of pertaining to water when he was talking to Job and he asked Job the question. He said, "Job have you ever considered the treasures of snow or have you ever considered the treasures of Hell which I have reserved against the time or trouble against battle and war". And the reason I am here today is that the multi international corporate structures can't bring in this type of technology, the Federal governments cannot bring in this technology, it has to come through an individual such as myself and it has to move through you and I. So as I impart this technology onto you, then you have a responsibility to it. This technology must get in through the people or otherwise it will not go forward." - Stan Meyer "We can demonstrate the technology. We can say it’s here but in actuality it will not be Stan Meyers to bring it in. It will be either you or I, the guy down the street, who will come together to bring it in. Otherwise, I do not believe an alternate energy source, whether water fuel cell or other, would ever come in. It’s going to have to be mandated by the people to try to reverse the environmental problems, the environmental damage, that’s actually occurring. - Stan Meyer, 1997" "If you believe, even tho you can not see, you will see." ~Russ Gries |
| Possibly Related Threads... | |||||
| Thread: | Author | Replies: | Views: | Last Post | |
| Let's build A "Popper" Noble Gas Engine AKA Ppap Engine. | ~Russ/Rwg42985 | 1,957 | 193,398 |
06-04-2013 04:09 PM Last Post: FaradayEZ |
| Gas clusters used in a thermodynamic cycle: WTF?? | k c dias | 63 | 2,870 |
06-04-2013 03:23 PM Last Post: FaradayEZ |
| OPen Source Hydrogen Car | securesupplies | 2 | 191 |
05-24-2013 12:20 PM Last Post: securesupplies |
User(s) browsing this thread:
, Love
and Well-Being
