The Adventure Of Building A Delta 3D Printer ~Russ
RE: The Adventure Of Building A Delta 3D Printer ~Russ
« Reply #150, on August 28th, 2013, 12:57 AM »
hey guys, sorry for the no reply,
i have know idea about your drives. i have not even seen one of those.
possibly sell it to buy the rest of the eletronics?
 i dont know. ~~
AleksanderA
« Reply #151, on September 7th, 2013, 09:51 AM »
Ok, I'l buy The Arduino electronics.
The question is, can I run a NEMA-23 stepping motor with it?
Thank you!
« Reply #152, on September 7th, 2013, 12:08 PM »
Quote from AleksanderA on September 7th, 2013, 09:51 AM
Thank you!
Alek, you might wait on making any other purchases. Might I suggest doing some research, my past post reflect we can't answer your question to completeness. All I can help you with is giving you recommendations and linking you to a  site I use quite regularly. You can find answers to your question there.
http://www.cnczone.com/forums/
Here is the link to a guy that could help
http://www.cnczone.com/forums/commercial_opensource_3d_printers/146896-hosss_3d_printers.html
Sorry we could not be more helpful, Jeff. :D
flyn_brian
« Reply #153, on October 19th, 2013, 05:29 AM »
Wow I just read this thread and am in utter awe. Russ you have done what I've been wanting to do for over a year. You helped me to make up my mind on what kind of reprap I want to build. At this point I have an audrino mega 2560, a ramps 1.4 board 12 lm8uu bearings, 608zz bearings, a heated bed etching and a lot of discarded 8020 extrusions. I need to get the driver boards and nema 17 motors. Also I was thinking of using the extrusions with some 8mm drill rod and lm8uu bearings kind of a hybrid design. It would be awesome if the audrino was able to run nema 23 motors as I have a few of them laying around but I think it would be better to bite the bullet and buy the nema 17's and drivers.
« Reply #154, on October 19th, 2013, 05:51 AM »
Quote from flyn_brian on October 19th, 2013, 05:29 AM
Hi flyn,
You might check out this link here on the forum for inexpensive parts you will need
http://www.open-source-energy.org/?tid=376
Re: The Adventure Of Building A Delta 3D Printer ~Russ
« Reply #155, on October 20th, 2014, 02:40 PM »Last edited on October 20th, 2014, 02:42 PM
OK, so I'm upgrading all my parts on this printer so I'm logging my build here:
the list:
20tooth pulleys
new brakes to hold on the pulleys for the 20 tooth pulleys ( explain later)
auto leveling system : hard where DONE here: http://open-source-energy.org/?topic=2098.msg28737#msg28737
new carage with new stile groves for belt.
new end effector bracket ( nothing changed just new)
possible remount of extrudeer motor to hang above the hotend for better sucking action... less strings.
and an LED " head lamp" ! DONE:
« Reply #156, on October 20th, 2014, 03:24 PM »Last edited on October 20th, 2014, 03:30 PM
more photos of the updated end effector with headlamp and Z probe...
looks to be about 1" of travel. it will detect only moving about .1"-.2" from all the way out. and it will retract at  .3" only to stick out .25"
just what i Ordered ( well i had to build it that way...)
and yes i did drill a hole in the plate as well as cut off the extra stuff that was on the Z probe so it was round...
