VERY IMPORTANT Free Energy - Nuclear Engineer M.T. Keshe @ ElektorLive!
« on June 2nd, 2012, 04:46 PM »
Ok guys and gals, this is going to knock your socks off:D:cool:
This is a long video but one well worth watching here,:cool:
https://www.youtube.com/watch?v=fCFO3-MOCYE&feature=g-all-f
I advise everyone to watch it then go to his forum here, he is going to release all his work free in the next few months to the world, in PDF form. Needless to say this will have the greatest impact on the world since Tesla's introduction of AC power.
http://www.keshefoundation.com/phpbb/viewtopic.php?f=10&t=2506
FloatyBoaty
RE: VERY IMPORTANT Free Energy - Nuclear Engineer M.T. Keshe @ ElektorLive!
« Reply #1, on June 2nd, 2012, 06:04 PM »
Good to hear this.  :)
Do let us know when and where to get a copy.  :D
« Reply #2, on June 2nd, 2012, 06:14 PM »
Quote from FloatyBoaty on June 2nd, 2012, 06:04 PM
I will keep tabs on it, you can also join his forum if you wish.:D
« Reply #3, on June 3rd, 2012, 12:48 AM »
ha, i just watched this!!!
some one emailed it to me..
this some crazy stuff!
« Reply #4, on June 3rd, 2012, 03:01 AM »
plasma you can touch with bare hands???
copied from here:
http://www.hovertech.com/home/research/coldplasma.html
Cold Plasma Hovercraft
Back in 1997, researchers at Berkley National Laboratory developed a cold plasma generator dubbed the "Constricted Plasma Source" or CPS. "The beauty of our source is that it can run with virtually any gas," says physicist André Anders of Berkeley Lab's Accelerator and Fusion Research Division. Anders, along with Michael Rubin and Michael Dickinson, who also work at Berkley National Laboratory, won the R&D 100 Award for development of the device.
Constricted Plasma Source Anders describes the unique design of the CPS as "beautifully primitive. There's nothing to break." The device works by forcing gas and an electric current through a narrow constriction which may be a single hole, a series of holes, or a narrow slit in a plate between the source's negatively charged cathode and a positively charged anode. As pressure builds in the chamber behind the constriction, ionization of the gas molecules increases resulting in a gas of charged atoms and molecules mixed with free electrons— a plasma. But unlike most plasmas, this one is at room temperature.
The electrons stream through the constriction, attracted toward the anode, which may be a metal grid near the constriction or the target itself. Meanwhile the positively charged ions remain inside the chamber due to their attraction to the cathode. However, as the pressure builds inside the chamber, the less energetic ions are finally ejected through the constriction, the only means of escape.
The process is started when helium is injected into the tube and short high-voltage pulses (under one microsecond) are applied across the electrodes. The resulting discharge in the gap between the electrodes creates a blue plume of plasma up to 5 centimetres in length. Increasing the helium flow rate or the magnitude of the voltage pulses will increase the length of the plume. The plume remains at room temperature and can be touched by bare hands.
Because of the sterilizing effect of plasma and portability of the device, most applications will be in the biomedical industry to kill bacteria, heal wounds and treat plaque. However, if the plasma can be reinforced by an external magnetic field, it may find applications as gas flow restrictors and maybe even force-fields to contain pressure.
One example of a plasma force-field is the plasma window invented at Brookhaven National Laboratory. Plasma windows produced in the lab typically consume about 20kw for every inch in diameter (8kw/cm), but are capable of providing a transparent wall between the vacuum of space and the pressure within a spacecraft. You may not want to get too close though as the plasma temperature can exceed 15,000 Kelvins (26,540 F). Yet, given the significantly lower pressure differential needed to support a hovercraft, a plasma force field at atmospheric pressure and room temperature shouldn't be that far fetched.
FloatyBoaty
« Reply #5, on June 3rd, 2012, 11:44 AM »
Quote from ~Russ/Rwg42985 on June 3rd, 2012, 03:01 AM
copied from here:
THIS, is really cool.  :cool:  I'll have to check it out further.
« Reply #6, on June 16th, 2012, 07:35 AM »
geert8550 one of our members of this forum, lives in Belgium, 70 KM from Dr. Keshe, I had emailed him to see if he would be willing to attend a conference given at the Keshe Foundation yesterday, Geert did attend, he said it was very interesting and would post information about what was discussed at the conference within the next couple of days, can't wait to hear about what he has to report, Jeff. :D
geert8550
« Reply #7, on June 17th, 2012, 02:22 AM »Last edited on June 17th, 2012, 03:07 AM by geert8550
Report following attendance at the lecture in the Keshecenter Ninove Belgium on 15 June 2012.
As I said in another toppic, I apologize for some weird syntax. Since I never learned to write English, I use Google translation tool. I only learned to understand and speak English through Hollywood movies and TV.
First I want to thank Jeff Nading who made me aware of the existence of this technology practically in my backyard without knowing.
To incorporate this technology one must understand the available information such as patents and movies look closely, this is what I did before taking part in the event. This is the revolution. One speaks of the wheel as the greatest invention ever, later, steam engines (industrial revolution), electricity brought a very different age, thirty years ago people said that the nuclear era was busy, now we know the computer age. Well it's high time for a new era ... the era of the fusion plasma. I will not explain here the theory for that I refer to the website of kesche foundation, nobody can do this better than Mr. keshe itself.
His goal is, let the people decide what happened with the technology. In the past, let us take the example of S. Meyer, many governments have covered up, and much more than we realize.
Well, just so, the report.
We were present with 25 registrants from around the world I would say. Korea, America, Canada, Italy, Denmark, Sweden and some Belgians, of course.
At the opening Mr. Keshe had an important announcement. This was the last meeting of this foundation.
  She stop to exist as it is now. There are, and still, negotiations with governments worldwide to introducing the technology in their country. The foundation exists as they are now being transferred to the Belgian Government on 6 September this year. She is converted into a limited company to continue the lessons for doctors, professors, scientists in general, international teaching as Mr. keche says. The pressure of government to his familly was too high. "I can not speak about 6 september" he said. No, it is not finisched! This is the start of a new  era. Very soon, according to Mr. Keshe september, the following two pattenten be published to the public in PDF format. These forms more clarity to the construction of the device which is now easier and more sophisticated.
Again, this technology to understand, first follow the films on the website which also on top of this toppic.
By absorption of the proteins in the ambient air has been developed in an egg yolk, just yes you read that right, an egg yolk gives a household energy for 500 years. Mr. keshe asks the people to fully understand the technology and further develop itself, the only way peace can develop on earth. It should stop that governments decide how smart we may be or how much we may know their power to be able to continue. Who, just so long ago, when time dared to say that the earth was round landed in prison, this is such a situation. Mr. Keshe has also experienced the same evaring. Under terms of the Canadian government sent back to Belgium.
The technology is based on the combination of the magnetic field and gravity will shortly be publicly available and in full effect will be displayed. The unit will be ready Wednesday, September 20, 2012. There will be publicly displayed to fly without a motor, no emissions, no noise can be flown with an even higher speed of light. It has been seen a few devices built for us UFOs seem to be because they emit light by the plasma, which in ten minutes from Belgium to South America have flown. The moon can be reached in two hours, Mars in one day. Power supply, disease, curing may also be returned to the technology due to protons, electrons back in the right place to be put, and the body back to its original state is inherited. Imagine with the system that NASA is doing: you know how much food and drink you need to travel to mars with three people? We speak not ill during the trip. NASA boasted of their travel to other planets has begun not with current technology. Think that you travel for six months with three people to the Sahara, let alone in this situation and stay away few years. there can not travel enough doctors with them, if they do not die on the road themselfs.
This may no longer be stopped, governments are aware to ensure, to lay down that the technology is real and belongs to the people. Now it's their job to prevent chaos and new Inova tions to develop the current economy, technology and legislation quiet lane to adjust. You understand that in our cities would be impossible that anyone can fly as high as they want. There must be arrangements for that to ensure security. You yourself can well imagine that the auto industry makes it difficult to use the technology. Billions of dollars investment in a time past have become.
Mr. Keshe has been two years a flashlight that stays on and that still works, you can see that there are no batteries in it, it's practically an empty transparent tube. I understand this will also be released so that everyone can build yourself a flashlight to the technology to understand and further develop themselves. He will teach us to make energy, learning to heal this for home use; This concept would be possible for $ 3. The (Belgian) government must cooperate, otherwise it makes no sense to learn it.
One of the anecdotes Mr. Keshe mentioned was that, as with many governments and their companies had done, NASA had also been invited to the technology to propose and demonstrate two of their engineers. The answer was that NASAs budget, has had annual investment of billions of dollars,does not permit for two tickets and a hotel in Belgium to order. nevertheless we also have budget-friendly hotels :-/. Mr. Keshe suggested this trip from his own pocket to pay for them but could not convince them. NASA refused to cooperate fully. Well, while NASA tried  to travel to mars with their old-fashioned hydrogen technology, I can with my plasma fusion technology car  in Belgium take a trip with my familly to the moon where I do not need years of training and no special clothing, I can actually in my swimsuit travel. Funny how smart Nasa thinks he is.
As I said the two following patents, which many governments are prohibited, will be published. This is planned for September 16, 2012, so very soon. To say Mr. Keshe itself, these two patents changes the first two. The possibilities and applications of plasma technology are in a rapid and they are daily more improved and simplified.
Personally, I think back to the predictions of Nostradamus mentioned that in our time about a new energy source would be discovered, making deep space travel possible.
I have utmost note of the important elements. In conclusion we can summarize that this does not stop it, that the technology is transferred to the people, governments must adapt if they want to remain as the country of the world, the technology soon will publicly displayed and that the opportunity is to further develop the technology as an ordinary citizen.
The foundation is still looking for volunteers for all possible contributions. This can now as the technology to transmit and to teach others. If you have ideas or important contacts and have similar or other contributions of knowledge or practical matters, this may contact the following email address:  webmaster@keshefoundation.com. Visit the website regularly keshefoundation.org to further developments of the situation and signup for the newsletter where the letters and communications of governments also published, as well as the publication of patents. Distribute as many copies of these patents. Help make history ...
As your president said, YES WE CAN!
If you have any questions concerning  the lecture, you can email me. If you have questions about the technology, then I recommend to consult  the information on the Keshe website and to subscribe to the newsletter. Have some patience until the patents are published.
I am glad with my small contribution to the beginning of this new era through your forum.
Geert Vranckx
« Reply #8, on June 17th, 2012, 05:17 AM »
Quote from geert8550 on June 17th, 2012, 02:22 AM
Geert Vranckx
Geert, I truly want to thank you for going to the conference and posting this news letter of what transpired there, maybe one day soon, we can actually shake hands and bring in this new technology, Jeff.
geert8550
« Reply #9, on June 17th, 2012, 11:58 AM »Last edited on June 17th, 2012, 12:01 PM by geert8550
I found this on one (see annex) of the toppics Keshe on the forum. This may be old school, i dont now.
Link forum toppic: keshefoundation.org
« Reply #10, on June 18th, 2012, 06:32 AM »
Quote from geert8550 on June 17th, 2012, 11:58 AM
Thank you Geert, Jeff.:cool::D:P
Ravenous Emu
« Reply #11, on June 18th, 2012, 08:34 PM »
Quote from FloatyBoaty on June 3rd, 2012, 11:44 AM
Yes... This, is very intriguing. :D
Thanks for the post Jeff.
I still don't, quite, get what he means by "plasma".
It almost sounds, to me, very similar to what stan was doing.  It's just Mr. Keshe's analogies are some what weird. (at least to me.)
geert8550
« Reply #12, on June 19th, 2012, 02:24 AM »Last edited on June 19th, 2012, 04:10 AM by geert8550
Quote from Ravenous Emu on June 18th, 2012, 08:34 PM
For the moment I'm engrossed in study of that technology. I want to understand this but it takes a lot of time because it again is not my native language.
I will try to explain what plasma  is meant by Mr. Keshe.
For simplicity, we visually present our solar system as an example because the technology is based on it.
Now assume that the solar system is an atom. The sun is the center and states for the proton as part of the atom, the electrons are the planets around the sun, as they behave around a proton. The earth is as an electron. The sun has a magnetic field provides just as the earth, both with a certain range. The space between the magnetic fields, so Interstate earth and the sun, is the plasma.
The plasma in an atom is the space between the electrons and the proton. By the action of two magnetic fields, gravity and magnetism, loses the plasma particles visible radiant glow that generates light in the process.
The planets (just like the ring magnets) find their balance to each other. They continue to keep their position relative to each other.
On earth, we know the attraction G1, which is also in aircraft created for normal to walk around. The vehicles (designed to bring this technology to fly) on earth can maximum gain of G53, beyond the earth is much more. To use the speed of light to be able to fly there is also a G1-cocoon created, otherwise it would smash you like a mosquito with a fly swatter to the wall of the cabin.
So, on the surface of the earth, we know the force of gravity G1, to the sun in the vicinity of the normal force of gravity to be able to live (G1) is that much further away, because the sun, a force of attraction which has 28 times greater than on the earth.
It is difficult to understand that there are elements that just from the air can be taken. But think of the experiment of Tesla, he caught also energy from the environment. These two theories are very close together, "If Tesla lived in our time and technology, he would immediately understand," said Mr. Keshe.
Geert
« Reply #13, on June 19th, 2012, 05:36 AM »
Your very welcome Ravenous Emu and thanks to Geert, for helping us understand. This is the most important discovery in human history and will be for decades to come, so get the message out to all you know, have them watch the videos read the announcements from Dr. Keshe. :D:cool:
geert8550
« Reply #14, on June 19th, 2012, 10:29 AM »
This comes from the Keshe forum (if you ar registred: Keshe forum toppic )
The text below is the copy of the official invitation to the leaders of your governments through their embassies in Belgium.
These emails will start leaving the Foundation and will be forwarded to every ambassador in Belgium in the next two weeks.
We will publish the name of the country and the email used that you can follow the progress of your nations work.
It is from now on up on you to see this technology's implication through your country of origin.
The world peace invitation and release of technology
Following the meeting of the Keshe Foundation with the world ambassadors invited to Brussels on 21 April 2012, now our invitation goes to the nations of the world through their ambassadors and their leaders to attend a gathering on 6 September 2012 at the Keshe Foundation Center in Ninove, Belgium (or in any other place the nations may choose).
As your Excellencies have been aware, we invited representatives of every country to the first presentation of our technology on 21 April 2012. The ambassadors of some nations attended this meeting and others chose to ignore the call, due to pressure from other nations, and decided not to attend or withdrew at the last moment.
With this second invitation we directly and unequivocally invite the leaders of your nation to appoint qualified individuals who can take part in the upcoming meeting at the Foundation on 6 September on behalf of their governments.
The reasons for this invitation and the meeting are as follows:
    1: On 21 September 2012 the Keshe Foundation will release the first phase of its space technology and the gravitational and magnetic (Magravs) systems it has developed, to all scientists around the world simultaneously, for production and duplication.
    From that point on, international borders will cease to have any real significance. This is because, once the first flight system has been built and put into operation by public, the time of travel for example from Tehran to New York will be about 10 minutes maximum.
    The new airborne systems will enable every individual to make the same length of journey in the same time and at hardly any cost from any point on this planet. The craft will not be detectable with present radar technology.
    2: The energy crisis will be resolved at a stroke, and once the technology is put into practice the powers that control energy supplies and through them the present financial structures will find their hands empty.
    3. The world water shortage will be addressed and resolved by presenting this technology to the public soon after the release of our energy and space technology.
How we have done this?
For the past six years we have used the international patent system to make sure that every nation and major scientists around the world have a copy of our patents in their possession. (Please check the European patent and international servers downloads for number of downloads)
Thus we have prevented any possible blocking of this technology by any individual or group and now most nations are in possession of our patents for energy generation, medical systems and space travel.
In this way the methods used in the past to prevent international development have been circumvented and now all nations have the same opportunity to work together to see that this technology is developed safely.
The principal point is that our technology is intended to be freely available to every government for the benefit of all its citizens. Through the systems we have developed every nation can have access to as much energy, water and food as they need, as well as to new methods of health care and of transport, all at very little cost.
According to its charter the Keshe Foundation and all its technologies are owned by the peoples of the world. The patents are the assets of every individual on this planet and cannot be claimed by any one person or organization or nation. This means that all income generated by the technology belongs to the nation that makes use of it.
We will release the list of countries invited to the meeting on 6 September 2012 and the full e-mail addresses of those who receive invitations, so it will be up to you as a government to make it known who from your nation will be attending this meeting.
By the time this email arrives at your embassies a copy will be posted on the Foundation forum and website so your citizens will be aware of the offer that has been made to you. Then it will be for you to make your response known to them, as well as to the Foundation, and we will gather the names of the delegates appointed and let your officials know where and how to meet.
Following this meeting, the presentation on 21 September 2012 will be the first step in the Keshe Foundation’s teaching program to share its knowledge and put it into the hands of the people worldwide. Once these new technologies and their benefits are known to the general public, the leaders of every nation will need to decide how they are going to implement them for the betterment of everyone.
At that point there will be two choices: either we all work together to change the life of everybody on earth for the better through the correct patterns of conduct, or the advanced nations of the world will see in the near future a flood of immigrants in tens of thousands flocking to the major cities.
We are prepared to present the technology to your representatives in any setting so that they can understand its implications and the changes it will bring about.
From now on, we can make sure that no child or adult will die of thirst or hunger and that no nation will be attacked by another, because the potential military applications of the new technology are so horrendously destructive that we will have no choice but to accept that fighting over the resources of the planet is a thing of the past.
There has been nothing wrong with protecting national assets, but now as the leaders of small regions of the Earth it is your responsibility to see that its resources are available to be shared, and that with the help of our technology everyone’s basic needs for energy, water, food and health care are met.
The Keshe Foundation takes no account of color, nationality, religion or political affiliation, thus our call is going out to every government to appoint a team of scientists to come and see our technologies at first hand. Then they can decide whether or not to make use of them. If you ignore this invitation your nation will soon have no choice but to follow the lead of the nations who have decided to develop them.
We call on your nation to start the process of world cooperation as soon as possible because once these systems are in operation, the frontiers that separate one country from another will have no meaning.
We have set the scene for a change of course for humanity and in the coming months we will see it through. In the near future people will come to realize that we are here to serve each other and not to be served, as all resources will be available to everyone at the same time and in the same measure.
M T Keshe
The founder and caretaker director of Stichting the Keshe Foundation
« Reply #15, on June 19th, 2012, 11:49 AM »
Quote from geert8550 on June 19th, 2012, 10:29 AM
M T Keshe
Thanks Geert, my sister works for the Foreign Service and is stationed in Baghdad Iraq at this moment, she will be back home in July, I will ask her if she knows anything about this invitation, I expect her to say no, we will see, Jeff.:D
Ravenous Emu
« Reply #16, on June 19th, 2012, 06:33 PM »
I might move from Stan's Tech to Keshe's Tech... This is WAY more appealing to me. :D
I think I notice slight similarities to stan's work.  The EP1770717 A1 Patent looks similar to an "EPG".
Gotta do more research and get Information Overload. :D
« Reply #17, on June 19th, 2012, 06:48 PM »
Quote from Ravenous Emu on June 19th, 2012, 06:33 PM
Yes, Keshe was and is way, way ahead of anything Stan did, we will have to wait until the last of September before the patent details are released to the public. Have you joined Keshe's forum here,
http://www.keshefoundation.org/phpbb/viewforum.php?f=2&sid=738fa78d331d24d88d34882012e09d6e
I still will be working on Stan's stuff though, I think it will be a prelude to Keshe's generator, Jeff.:cool::D:P
Ravenous Emu
« Reply #18, on June 19th, 2012, 08:04 PM »Last edited on June 19th, 2012, 09:00 PM by Ravenous Emu
Quote from Jeff Nading on June 19th, 2012, 06:48 PM
Agreed.
I do also recall watching some video's on you-tube about what I think is related to this stuff... kinda long, but interesting nonetheless.
https://www.youtube.com/watch?v=yLOO6Do2Q5o
(14:30)
(30:28)
(43:37)
(58:50)
geert8550
« Reply #19, on June 19th, 2012, 11:46 PM »Last edited on June 20th, 2012, 08:23 AM by geert8550
Hi guys
During the lecture Mr. Keshe Ninove talked about a U.S. drone that "crashed" in Iran. The U.S. government was just spying in the experiments of Mr. Keshe with the Iranian Space Agency.
The U.S. government is just afraid to lose the leadership of advanced technology and space programs.
I now that the image of the "UFO" is a bit cliché in following article, the drone so to say "collapsed down"  because it came too close to the magnetic field of the "rig".
Read the following articles:
http://www.wired.com/dangerroom/2012/01/iran-ufo-drone/
http://pesn.com/2011/04/06/9501804_Engineer_Behind_Iranian_Saucer_Technology_Comes_Forward/
Geert
« Reply #20, on June 22nd, 2012, 12:30 AM »Last edited on June 22nd, 2012, 12:44 AM by geert8550
I received some questions with email from Victor (a friend of Jeff), here the answers to his questions.
Wanted to ask you if Dr. Keshe performed any equipment/technology demonstrations during the conference?
No, on 21 September, the following two patents worldwide by e-mail sent at once to all governments and scientists (and available on the website to). The demonstration of the flying machine in ten minutes from Tehran to New York. keshefoundation.org forum topic
The presentation slides could get a glimpse of the unit (see photo of presentation Eindhoven).
Did you make any contacts at the conference that you are keeping in contact with?
There were only a twenty five participants, there was enough opportunity to talk with each other. I also talked with the webmaster of the site that I've emailed them several times. The website was ready for a move to because resver was too slow. Being a Joomla site I suggested the Akeeba backup tool.
Do you know of anyone that is trying to build a reactor from the patents that are available?
No, I do not know anyone but I know that some scientists worldwide are already doing so. The following two patents would be replaced the first two in that they are even easier.
Geert
« Reply #21, on June 27th, 2012, 08:12 AM »
The patents EP1770715A1 and EP1770717A1, which I sent earlier, were published in 2005. The following two patents WO2008113392A1 and WO2008113393A2 were later published (2007). September 2012 are the following two patents and replaced the first two, speaking MT Keshe.
Gtz
Geert
« Reply #22, on June 27th, 2012, 08:15 AM »
Quote from geert8550 on June 27th, 2012, 08:12 AM
Gtz
Geert
Thanks Geert, Jeff.:D:cool:
Kumaran
« Reply #23, on July 5th, 2012, 03:42 AM »
Quote from Jeff Nading on June 27th, 2012, 08:15 AM
Gtz
Geert
Fascinating technology. This is the technology we can use to take us to the stars to build the Starship Enterprises of the future warp drive and force field shielding. Look forward to September.
« Reply #24, on July 5th, 2012, 05:48 AM »
Quote from Kumaran on July 5th, 2012, 03:42 AM
Gtz
Geert
Yes, if this technology is released to the world and used in the right way , it will change mankind forever :cool::D:P
