Starship, Rodin and other electromagnet designs
Samson4
« on April 4th, 2012, 12:44 PM »
Hello to all!! I hope to be around a while soaking up information.
Reason for thread
So after about 3 months of; researching, dead ends, and hours of youtube demonstrations, I've come here to learn from people much more experienced than I.
My Application
I am trying to build a coil with a 2 inch diameter. I want it to produce a 1.4T field in it's center. The coil can only be 1/2 an thick. I will then make a core out of 99.95% iron wire and epoxy.  I am basically trying to make an electromagnet with it a core  equal in size and strength as a 2x1x1 inch N42 bar magnet.
My Questions
What I can't figure out is how to calculate the b-field of a starship coil. On top of that, I can't decide on which type of coil will produce the strongest field at limited thickness.
I haven't been able to find out why a starship type coil produces a stronger magnetic field than a traditional electromagnet. Does anyone know the answers to these questions or have a link they could share?
RE: Starship, Rodin and other electromagnet designs
« Reply #1, on April 4th, 2012, 01:45 PM »
Quote from Samson4 on April 4th, 2012, 12:44 PM
Reason for thread
My Application
My Questions
Russ or Firepinto could probably help you.
« Reply #2, on April 4th, 2012, 11:39 PM »Last edited on April 4th, 2012, 11:41 PM by ~Russ/Rwg42985
Reason for thread
My Application
My Questions
my tests /theory has shown that these coils produce such a magnetic field that the field is not contained but instead reflected out!
so the wire crossing in a 90 degree from each other dose some weird things like project the magnetic field instead on making it all concentrated...
i hope this makes sense.
look up what happens when 2 wires are 90 degrees from each other.
i'm not sure how much T my coils produce as i don't have a way of checking. but i can these babys put off a tun of emf... that's bad for your health if over exposed. i have gotten sick from a lot of power pumped in to this coil:
http://vortexspace.org/download/attachments/10649631/IMG_2966.jpg
i hope this helps. one place i can recamend you is here:
vortexspace.org/dashboard.action
be sure to join the rodincoil group on Google...
also skycollection on youtube is doing some really cool stuff...
Samson4
« Reply #3, on April 6th, 2012, 05:05 AM »
Quote from ~Russ/Rwg42985 on April 4th, 2012, 11:39 PM
Reason for thread
My Application
My Questions
Thank you for the links. Lots of new and interesting topics to read. As for skycollection, I believe I have watched everyone of his videos. He is one of the only people I know of using a core in a starship.
What do you think about using aluminum versus copper in a starship coil? I'd like to think the aluminum's paramagnetic characteristic would aid in magnetism.
Re: Starship, Rodin and other electromagnet designs
« Reply #4,  »
Quote from Samson4 on April 6th, 2012, 05:05 AM
COMPRESSED SPIRAL STARSHIP COIL (BIFILAR WINDING)
https://www.youtube.com/watch?v=DHi_ynAzEJU
SPIRALSHIP COIL & SKYLEV BASE
https://www.youtube.com/watch?v=wu3yMApjN2o
Spenno
« Reply #5,  »
What were those youtube videos about, Namirha? They're gone now and I can't tell what picture you were trying to paint by linking them.
« Reply #6,  »
Quote from Spenno on November 17th, 2018, 07:31 AM
ELECTROMAGNETIC PROPULSION, PMBO 2018 FINAL ENTRY
https://www.youtube.com/watch?v=FOmUyWTPLxQ
« Reply #7,  »
Demonstration of SkyCollection Bedini and Rodin Coil Variants at TeslaTech
https://www.youtube.com/watch?v=ZoXoDNHanRI
