Edward Leedskalnin TPU
RE: Edward Leedskalnin TPU
« Reply #75, on November 10th, 2013, 08:47 AM »Last edited on November 10th, 2013, 09:08 AM by freethisone
proposal, 2 rodan coils, as a field magnet, iron bar, or pipe trough its center stator armature spark gap brushes..  short the center tube . its axil or field of rotation. set it  up like he had done in the pmh movie.
a grounding pipe. a pmh with pmh generator or coils. add a hand crank if that was desired.
it will work best as a motor, a field magnet focused at its center, or around its outer edges  .A pick up coil or coils arranged vertical at 90 degrees from its outer edge. can be wound with 1200 feet of wire.. to make a vortex of dense dipole alignments at the center of said vortex, or  a folding in on itself, if i try to follow the flow of dipole alignments of said rotating magnetic  field.  :angel::angel:.
i will show you many types of field magnets. and we can arrange them in a circle.
https://www.youtube.com/watch?v=rpeSfq5yq3w:Pnice
step down transformer should be added. motor type capacitor banks for energy storage.  feed back to a motor for rotation of said field via cap banks. to power the ed lee flyW. or rodan type electric field magnets.
we should capture much more energy then we put in.
« Reply #76, on November 11th, 2013, 01:46 AM »Last edited on November 11th, 2013, 03:28 AM by freethisone
/watch?v=igtnGapd1Wg
My cousin Vine. Yo.
Truth is I had said the coral castle is a time of Precession. perhaps 3800 years. the money left behind. In the case ENFP torque times delta T.
Equinox. He did have help. His Grand dad surely gave the boy the text to follow.
It comes from Egypt.
The picture below is a field magnet too.:angel: My discovery. Including the dipole. it also has a copper oxide coating.  Azurite.:angel:
This is the way we need to go in order to move forward Follow along..
Just look ,its a ferrite, and could be used for communication. It may be a PMH or radio pick up coil. see the rings rings of gold?
Note we have the 4 pole motor. 3 poles are separating mass from energy. Hmm??
Feb. 14 comet 2016.
 in fact the equinox was February 16 2010. my discovery also. Start of solar cycle 24, Feb. 5th 2010.. to last up to 12.6 years. Keplers law. I had discovered the key symbol at the coral castle. Find picture, ring bell 2 times.
The effects of negative gravity will clear your head, like I had said.:sleepy:
every one should be pulling out there Rodan coils to experiment. It was said its a field magnet also... shield the hell out of it too. Input 9 to 12 volts.
i would take an ole graphite driver, use the handle and bend it in the shape outlined below. this should work as a nice magnetic core.
« Reply #77, on November 13th, 2013, 02:51 PM »Last edited on November 13th, 2013, 03:03 PM by freethisone
i make a prediction, one of Ed Lees invention was using bar magnets as the forks in a bike.  the ones with the south pole inside the bar, and the north pole face outside.
howlycow.. a bike wheel with the spokes, as single pole magnets. what did we do?
http://open-source-energy.org/forum/attachment.php?aid=2698
really its all for free.:D
one big wheel one small. i shuttle the flux to the rear wheel and wow.
so its a train in a circle. energy is never destroyed. simply moved by disruptive discharges. moved by sending the back emf to another conductor. the  speed, and duration of magnetic collaps is potential energy. reason the inductor gets hot.
« Reply #79, on November 13th, 2013, 05:08 PM »
Quote from Matt Watts on November 13th, 2013, 04:41 PM
So back in 1871, this device actually worked.  Two transformers hooked together, primary A to secondary B; primary B to secondary A.
Well, it doesn't work in 2013, so what has changed between then and now?
Are you saying you made 2, 6 foot long inductors?
like in the patent?
it looks like it could be a PMH also.
« Reply #80, on November 13th, 2013, 05:35 PM »
Quote from freethisone on November 13th, 2013, 05:08 PM
like in the patent?
Quote from "Daniel Cook"
In carrying out my invention, I do not confine myself to any particular mode of constructing a helix, or helices, or to any particular size of wire, observing only that the quantity of wire of the several helices is sufficient to produce the result,
So I used two big isolation transformers that easily have over a 1000 feet of wire on them; both iron core.
Now the differences are they don't have open ends and the wraps traverse back-n-forth across the core.  Maybe that's enough to kill the desired result. ???
« Reply #81, on November 13th, 2013, 05:51 PM »Last edited on November 15th, 2013, 09:35 AM by freethisone
Quote from Matt Watts on November 13th, 2013, 05:35 PM
like in the patent?
could this be the reason?
Galvanic isolation is a principle of isolating functional sections of electrical systems to prevent current flow; no direct conduction path is permitted. Energy or information can still be exchanged between the sections by other means, such as capacitance, induction or electromagnetic waves, or by optical, acoustic or mechanical means.
Galvanic isolation is used where two or more electric circuits must communicate, but their grounds may be at different potentials. It is an effective method of breaking ground loops by preventing unwanted current from flowing between two units sharing a ground conductor. Galvanic isolation is also used for safety, preventing accidental current from reaching ground through a person's body.
like in the patent?
now i know what this was for. to prevent death from accidental discharge.
at 39 min plus a demonstration.:D
https://www.youtube.com/watch?v=NQvmJjiM124#t=2518:D
the snake is the hissing of electrical discharge.
« Reply #82, on November 13th, 2013, 06:35 PM »
Quote from freethisone on November 13th, 2013, 05:51 PM
Galvanic isolation is...
Well, that's what isolation transformers do.
It also keeps things from corroding, stops high frequency spikes, allows for voltage doubling, power phase change, all sorts of stuff.
« Reply #83, on November 14th, 2013, 05:08 AM »Last edited on November 15th, 2013, 09:33 AM by freethisone
in the case of isolation   transformer, it is made that there is a break, and no back emf occurs.
no magnetic pathway .:(
« Reply #84, on November 15th, 2013, 12:18 PM »
this is a advance use
comment please?
cristian alba
« Reply #87, on November 17th, 2013, 08:46 PM »Last edited on November 17th, 2013, 08:54 PM by cristian alba
Hello to all
Youtube channel this man. It seems that it is an illusionist by the regular movement of the hands and how to speak without interruption but ...... watch VIDEOS and you'll see   https://www.youtube.com/user/Deirones?feature=watch
Best regards      cristian.
« Reply #88, on November 19th, 2013, 02:11 AM »Last edited on November 19th, 2013, 03:44 AM by freethisone
i solved another key feature from the corral castle. Our friend
that is shewn below. add pictures.
related to the crown constellation.
in fact the big dipper itself. looking north.
I had sloven, rather confirming its position an ancient Sumerian glyph. find pic. add confirm, description.:angel::angel:
(enter the age of Aquarius. we have the full moon a gibbis. november 2013.
the question is what is poynting? a vector potential, in fact more then just one.  now we follow the tail of the scorpion to the red beating pulsing star in the east before dawn. from my eye i see a streaming tail of matter.
looking directly at this star with the naked eye is not advised.  A whole cut in the great pyramids to capture one of these stars light. in theory we are in that position, but for how long it remains is the question.
looking now north to the big dipper, upside down with its handle. 6 stars in enlightenment with the crown stone . this is the point i wish to ponder, and show.
At  the headache has come back. and is that of ion passing our bow.  this will cause internet, and cell phone problems. in a short time. an ordinary spark gap trigger is assumed. This may bean  unbarable situation for some people.
the Orion  comes out of the water, he steps onto the earth. at a time of water, as he bears his water.
the pyramidal crown stone has how many points, how many stars.
lets see what is said. add movie.
lets discover his history, and greatest discovery.
https://www.youtube.com/watch?v=Ga4d0e0YGC8
 now what did we do,? a trail of bread crumbs..
Our friend Mr pool has in deed added a great deal of knowlage. i will recap this for my understanding. yours also.
at one min 15 sec Mr Pool states, this 5 pointed star depicted as a chunk of coral carved.
stated spica is the brightest star in Virgo. at 2min 14 sec he states to drop below polaris.
in support we find footnoetes.
Arcturus
Jump to: navigation, search
For other uses, see Arcturus (disambiguation).
Arcturus
Arcturus in the constellation of Boötes.
Observation data
Epoch J2000      Equinox J2000
Constellation    Boötes
Pronunciation    /ɑrkˈtjʊərəs/
Right ascension    14h 15m 39.7s[1]
Declination    +19° 10′ 56″[1]
Apparent magnitude (V)    −0.04[1]
Characteristics
Spectral type    K1.5IIIFe-0.5
Apparent magnitude (J)    −2.25[1]
U−B color index    1.27
B−V color index    1.23
R−I color index    0.65
Variable type    Variable star
Note (category: variability):    H and K emission vary.
Astrometry
Radial velocity (Rv)    -5 km/s
Proper motion (μ)    RA: −1093.45 mas/yr
Dec.: −1999.40 mas/yr
Parallax (π)    88.98 ± 0.68 mas
Distance    36.7 ± 0.3 ly
(11.24 ± 0.09 pc)
Absolute magnitude (MV)    −0.30 ± 0.02[2]
Details
Mass    1.10 ± 0.06[3] M☉
Radius    25.7 ± 0.3[4] R☉
Luminosity    170[3] L☉
Surface gravity (log g)    1.76 ± 0.05[3] cgs
Temperature    4,290 ± 43[3] K
Metallicity [Fe/H]    −0.37[5] dex
Rotational velocity (v sin i)    2.4 ± 1.0[2] km/s
Other designations
Alramech, Abramech, α Boötis, 16 Boötes, BD+19°2777, GCTP 3242.00, GJ 541, HD 124897, HIP 69673, HR 5340, LHS 48, SAO 100944.
Database references
SIMBAD    data
Data sources:
Hipparcos Catalogue,
CCDM (2002),
Bright Star Catalogue (5th rev. ed.),
VizieR catalog entry
Arcturus (/ɑrkˈtjʊərəs/; α Boo, α Boötis, Alpha Boötis) of the constellation Boötes is the brightest star in the northern celestial hemisphere. With a visual magnitude of −0.04, it is the fourth brightest star in the night sky, after −1.46 magnitude Sirius, −0.86 magnitude Canopus, and −0.27 magnitude Alpha Centauri. It is a relatively close star at only 36.7 light-years from Earth, and, together with Vega and Sirius, one of the most luminous stars in the Sun's neighborhood.
Arcturus is a type K1.5 IIIpe orange giant star, with an absolute magnitude of −0.30. It has likely exhausted its hydrogen from the core and is currently in its active hydrogen shell burning phase. It will continue to expand before entering horizontal branch stage of its life cycle.
footnote spica the blue kachina?
Spica
For other uses, see Spica (disambiguation).
Alpha Virginis A/B
Location of Spica
Cercle rouge 100%.svg
Location of Spica (circled) in the constellation Virgo
Observation data
Constellation    Virgo
Pronunciation    /ˈspaɪkə/
Right ascension    13h 25m 11.5793s[1]
Declination    −11° 09′ 40.759″[1]
Apparent magnitude (V)    +1.04
Characteristics
Spectral type    B1 III-IV/B2 V[2]
U−B color index    −0.94[3]
B−V color index    −0.24[3]
Variable type    β Cep,
Rotating ellipsoid
Astrometry
Radial velocity (Rv)    +1.0[4] km/s
Proper motion (μ)    RA: −42.50[1] mas/yr
Dec.: −31.73[1] mas/yr
Parallax (π)    12.44 ± 0.86[1] mas
Distance    260 ± 20 ly
(80 ± 6 pc)
Absolute magnitude (MV)    −3.55 (−3.5/−1.5)[5]
Orbit[6]
Period (P)    4.0145898 d
Eccentricity (e)    0.067 ± 0.014
Inclination (i)    54 ± 6°
Periastron epoch (T)    2440678.09
Argument of periastron (ω)
(secondary)    140 ± 10°
Details
Primary
Mass    10.25 ± 0.68[6] M☉
Radius    7.40 ± 0.57[6] R☉
Luminosity    12,100[7] L☉
Surface gravity (log g)    3.7 ± 0.1[5] cgs
Temperature    22,400[5] K
Rotational velocity (v sin i)    199 ± 5[6] km/s
Secondary
Mass    6.97 ± 0.4[6] M☉
Radius    3.64 ± 0.28[6] R☉
Luminosity    1,500[7] L☉
Temperature    18,500[7] K
Rotational velocity (v sin i)    87 ± 6[6] km/s
Other designations
Spica, Azimech, 角宿一, Spica Virginis, Alaraph, Dana, α Virginis, 67 Virginis, HR 5056, BD -10°3672, HD 116658, GCTP 18144, FK5 498, CCDM 13252-1109, SAO 157923, HIP 65474.[8]
Spica (α Vir, α Virginis, Alpha Virginis, pronounced /ˈspaɪkə/) is the brightest star in the constellation Virgo, and the 15th brightest star in the night sky. It is a blue giant and a variable star of the Beta Cephei type located 260 light years from Earth.
footnote Polaris
For other uses, see Polaris (disambiguation).
Alpha Ursae Minoris
Polaris as seen by the Hubble Space Telescope.
Observation data
Constellation    Ursa Minor
Component    α UMi Aa    α UMi Ab    α UMi B
Right ascension    02h 31m 49.09s       02h 30m 41.63s
Declination    +89° 15′ 50.8″       +89° 15′ 38.1″
Apparent magnitude (V)    1.98v[1]    9.2[1]    8.7[1]
Characteristics
Spectral type    F7Ib    F6V    F3V
U-B color index    0.38[1]       0.01[2]
B-V color index    0.60[1]       0.42[2]
Variable type    Classical Cepheid
Astrometry
Radial velocity (Rv)    -17 km/s
Proper motion:
RA (μα cos δ)    44.48±0.11 mas/yr
Dec. (μδ)    -11.85±0.13 mas/yr
Parallax (π)    7.54 ± 0.11 mas
Distance    325[3] - 425[4] ly
(99[3] - 129.5[4] pc)
Absolute magnitude (MV)    -3.6[1]    3.6[1]    3.1[1]
Details
Mass    4.5[1] M☉    1.26[1] M☉    1.39[1] M☉
Radius    46±3[1] R☉       1.38[2] R☉
Surface gravity (log g)    2.2[5]       4.3[2]
Luminosity (bolometric)    2500[6] L☉    3[1] L☉    3.9[2] L☉
Temperature    6015[2] K       6900[2] K
Metallicity    112% solar[7]
Rotation    119 days[8]
Rotational velocity (v sin i)    14[8]km/s       110[2]km/s
Age    7×107[9] years
Orbits[1]
Secondary/primary    Ab/Aa    B/A
Period (P)    29.59 years    ~100,000 years
Semimajor axis (a)    0.133"    32" (0.02 pc)
Eccentricity (e)    0.608
Inclination (i)    128°
Longitude of node (Ω)    19°
(secondary)    303°
Semi-amplitude (K1)
(primary)    3.72km/s
Position (relative to Aa)
Epoch of observation       2005.5880    2005.5880
Angular distance       0.172″    18.217″
Position angle       231.4°    230.540°
Database references
SIMBAD    data       data
Other designations
Polaris, North Star, 1 Ursae Minoris, HR 424, BD +88°8, HD 8890, SAO 308, FK5 907, GC 2243, ADS 1477, CCDM 02319+8915, HIP 11767, Cynosura, Alruccabah, Phoenice, Navigatoria, Star of Arcady, Yilduz, Mismar
Polaris (α UMi, α Ursae Minoris, Alpha Ursae Minoris, commonly North Star, Northern Star or Pole Star, also Lodestar, sometimes Guiding star) is the brightest star in the constellation Ursa Minor. It is very close to the north celestial pole, making it the current northern pole star.
It is a multiple star, consisting of the main star α UMi Aa, two smaller companions, α UMi B and α UMi Ab, and two distant components α UMi C and α UMi D. α UMi B was discovered in 1780 by William Herschel.
Many recent papers calculate the distance to Polaris at about 434 light-years (133 parsecs).[4] Some suggest it may be 30% closer which, if correct, is especially notable because Polaris is the closest Cepheid variable to Earth so its physical parameters are of critical importance to the whole astronomical distance scale.[3]
at 7 min 22 seconds we see the corral castle l crown stones. i say
I say they must be unfolded into the big dipper.
if we now drop 10 cents, degrees, or arch seconds below we find something poynting. what star is it?.
lets test this for truth.:angel:
[/size]
I add as a prediction to test for truth
Aug 16 2016 a special note worthy date, perhaps a bell ringer also, ring bell two times.  future date.:angel:
:sleepy::dodgy:
Test February 5th 2016, for great quake. on anniversary of, feb 5th 2013. kelpers law
M8.0 - 76km W of Lata, Solomon Islands (BETA) 2013-02-06 01:12:27 UTC
PAGER - GREEN ShakeMap - VIII DYFI? - VIII Tsunami Warning Center
Earthquake location 10.738°S, 165.138°EReturn to the EQ List/Map/Search
kml iconGoogle Earth KML
Summary
Location and Magnitude contributed by: USGS National Earthquake Information Center
General
50 km
30 mi
Powered by Leaflet
10.738°S, 165.138°E
Depth: 28.7km (17.8mi)
Event Time
    2013-02-06 12:12:27 UTC+11:00 at epicenter
    2013-02-05 20:12:27 UTC-05:00 system time
Location
10.738°S 165.138°E depth=28.7km (17.8mi)
Nearby Cities
    76km (47mi) W of Lata, Solomon Islands
    574km (357mi) NNW of Luganville, Vanuatu
    586km (364mi) ESE of Honiara, Solomon Islands
    846km (526mi) NNW of Port-Vila, Vanuatu
    1149km (714mi) NNW of We, New Caledonia
« Reply #89, on November 19th, 2013, 03:22 AM »Last edited on November 19th, 2013, 11:59 AM by freethisone
Joe Rao serves as an instructor and guest lecturer at New York's Hayden Planetarium. He writes about astronomy for The New York Times and other publications, and he is also an on-camera meteorologist for News 12 Westchester, New York.
linkhttp://www.space.com/8319-measure-distances-night-sky.html source. to make you use your fist, or fingers to duplicate the coral castle telescope. to find the 10 cents above or below the dippers tail.
Sometimes, the apparent distance between two celestial objects ? the distance we can actually see on the sky ? is indicated in terms of angular degrees. But these descriptions can seem like a foreign language to folks who don't pore over star charts every day, so here's a handy primer.
If we measured the distance around the circle of the entire horizon ? from north all the way around through east and south and west and back to north again ? that would equal 360-degrees.
From the horizon to the point directly overhead (the zenith) would equal 90-degrees; from one horizon point through the zenith and continuing across to the opposite side of the sky would measure 180-degrees.??
You can also use your clenched fist as a sextant to measure the height of the moon, star, or planet above the horizon. Your clenched fist, correctly held, will roughly measure off 10-degrees. So you can use your fist to make a reasonable guesstimate of degrees either horizontally or vertically.
The stars themselves can serve as handy yardsticks in the sky. The famous belt of Orion, for instance, measures 3-degrees and the twin stars of Gemini (Pollux and Castor) are 4-degrees apart.?
This week, the constellation of Leo, the Lion conveniently stands high above the southern horizon at dusk. The backward-question mark pattern of stars popularly known as the Sickle forms the Lion?s head and measures 14-degrees from top to bottom.
The distance between Leo?s two brightest stars, Regulus (at the bottom of the Sickle) and Denebola (which marks the tip of the Lion?s tail) is 24-degrees.
Close Encounters
Occasionally two planets, or a star and planet will appear exceptionally close together in the sky; their distance being less than a degree apart.?
In such unusual cases, we would measure the distance between the two objects in tenths of a degree or in more extreme cases, in arc minutes. One degree, for instance, is equal to 60 arc minutes. One half of a degree, which is the average apparent size of the moon is equal to 30 arc minutes.?
In the Big Dipper (or the ?Plough? if you are reading this in the United Kingdom) the star at the bend of the handle is Mizar which appears to have a fainter companion about one-fifth as bright known as Alcor.
Mizar and Alcor together are sometimes called the "Horse and Rider," and the ability to resolve the two stars with the naked eye is often quoted as a test of eyesight, although even people with quite poor eyesight can see the two stars. They are separated by just 0.2-degree or 12 arc minutes check them out tonight for yourself.? Indeed, two bright planets or a bright planet and bright star that are separated by less than this distance can make for a stunning visual spectacle.
I did some checking and found some very close conjunctions coming up during the next 20-years in which two objects ? either two bright planets or a bright star and a planet ? will appear within a distance of less than 12-arc seconds. I?ve listed five such cases in the table below.
DATE??????????????????????? OBJECTS????????????? SEPARATION?????????? VIEWING TIME
Oct. 3, 2012
Venus/Regulus
8-arc minutes
Before sunrise
Aug. 27, 2016
Venus/Jupiter
7-arc minutes
After? sunset
Dec. 21, 2020
Jupiter/Saturn
6-arc minutes
After sunset
Jul. 28, 2023
Mercury/Regulus
8-arc minutes
After sunset
Oct, 2, 2028
Venus/Regulus
9-arc minutes
Before sunrise
Historians and biblical scholars no doubt will have a special interest in viewing the Venus/Jupiter conjunction in August 2016, since some theorize that a similarly close approach of these two bright planets in the eastern twilight sky in August of 3 BC might have been what the Magi later identified to King Herod as the legendary Star of Bethlehem.
Even more intriguing is the close pairing off of Jupiter and Saturn on Dec. 21, 2020.
Conjunctions between Jupiter and Saturn occur on average once about every 20 years. But the 2020 case will be unusual in that rarely do these two planets ever appear to come so close to each other. Have you ever wanted to see Jupiter and its retinue of bright satellites passing Saturn and its famous ring system together in the same high-power field of a telescope??
You?ll be able to do so on this night!? In fact, the last time they were this closely spaced was in July 1623 and they will not appear so close together again until March 2080. Mark your calendars!
Our Deceptive Moon
Because it measures one-half degree in apparent size, some might think that the moon can be used to measure off angular distances, but this is far from the case.?
For one thing, there is the famous ?moon illusion? in that our natural satellite seems to appear much larger in size when it lies close to the horizon. Indeed, a rising moon can sometimes appear absolutely enormous, yet an hour or two later it will appear to have shrunk to a considerably smaller size. This strange effect has intrigued artists and puzzled psychologists for many years and has perplexed people since earliest historical times, such as Aristotle.?
No one seems to know exactly why this happens, though the most popular explanation is that the moon illusion is an optical illusion related to the Ponzo illusion in that the human mind judges an object's size based on its background with foreground objects such as trees and houses tricking our brain into thinking the moon is much bigger than it really is.
But even when it appears high in the sky, the moon looks ?too big? to be one-half degree in width.? And this illusion is not confined to the real sky, but is even evident in the ?pretend universe? of a planetarium.
When the very first projectors were designed and made to project the moon?s image of one-half degree on the planetarium dome as it appears in the real sky, it was found that it appeared too small to be realistic although it was in actuality the correct angular size with respect to the background sky. [Full moon photos.]
To rectify this problem, engineers doubled the size of the projected moon image to one-degree, which presents a much more realistic appearance; one of the few places where accuracy was sacrificed for the sake of realism.
Similarly, the real moon appears much larger against the real sky. Try this mental experiment some night when you can see both the Big Dipper and moon in the sky at the same time.
First look at Dubhe and Merak, the two stars that are commonly used to point toward Polaris, the North Star. Now, looking at the moon and then back to Dubhe and Merak, try to estimate how many moons you could fit between the two stars.?
Keep in mind that those two stars are separated by 5 1/2 degrees. And as we?ve already noted, the moon itself appears a half-degree in width.
That means you should easily be able to squeeze no fewer than eleven moons between the two stars. It is a fact that is very difficult to accept. Maybe four moons can fit in the space between the stars; five at the very most.
But 11? The night sky is full of surprises
Amateur Astronomers' Best Space Photos
How to See the Twin Stars of Spring
Venus and Mercury Sparkle Over Rome in New Photo
I see the dipper, as a clock, this time and place. its handle a crank, it shiffted by two star. these stars are in conjunction to what i have learned.now look outside this morning and see the full moon in its glory as it is due west in the morning sky. 11-19-2013
thank you for this life. to prove aa theory we test its truth.:cool:
take out a   compass and find exact magnetic alignment if you may do so,
https://www.youtube.com/watch?v=sdTPHGwE1zQ&feature=youtube_gdata:D
https://www.youtube.com/watch?v=hzCLGaXnp4g
i count the day Venus takes to pass the sun, but at 2min 26 to 27 second something happens. the object goes back the other way, the camera is forced into rotation, and the handle aspect angle has changed.
the period of time from december 10th for almost 80 day, the slow moving pass is observed.
today these objects are whizzing by our cameras at a pace never before seen.
:huh:
i give you the fly wheel. in its glory.:angel:
I add the two object captured in the reflection is at the south west position. the reflection of nibiru april 2010. these objects are poynting also. i can now see a naked object in the south west above the brighter then sun object.
the brighter then sun object cannot be venus.
« Reply #90, on November 20th, 2013, 02:21 PM »Last edited on November 20th, 2013, 02:21 PM by freethisone
:cranking up the power of the ed lee dynamic magnetic  generator.:idea::idea::idea::idea:
/watch?v=PyHQYsQ4RNI
do it..;)
thanks Mr T.
« Reply #91, on November 27th, 2013, 02:36 PM »Last edited on November 27th, 2013, 03:53 PM by freethisone
ed lee solved..
with theory we are able to grasp these understanding. we must always look to the old ways for guiedence
we listen in the books, and follow along with experiment.
it is now understood that Faraday, Cavendish, Tesla etc. and ed lee goe hand and hand..
it is now clear and if i share you will see beuty..:angel::heart:
"the axil in rotation.. i now make it magnetic, and vortacal. i m ake it eatheral. and so on. we have light. we have to determine .
teach us  what is right, and
we must go on, and on to describe these effect".....
:angel:
/watch?v=yblGWkT0RjM
/watch?v=K0RUzDtdZR0&feature=c4-overview-vl&list=PLEE06EF830053FF38 link click Lorrie
« Reply #92, on December 1st, 2013, 02:58 PM »Last edited on December 4th, 2013, 04:02 PM by freethisone
new motors. first thought.:sleepy::D
this is the start of my pulse motor for 2014.
if you would like to test i give you more detail.
Quote from freethisone on November 27th, 2013, 02:36 PM
ed lee solved..
:angel:
/watch?v=dw73DcwIX-A
http://maglix.com/ yes this is a ed lee coil. this is the concept . i already made ten motors but dont make them..
finger paint, interesting i make light, and use of the power of two, over the power of one.
its a bias? asymmetry. in other words i use these 4 stationary magnets, in conjunction with the rotating assembly.  pulse time duration may vary frome one flip to the next. on off time slightly shorter. any number of experiments may be performed.:D
update my gen.
« Reply #93, on December 4th, 2013, 03:41 PM »Last edited on December 4th, 2013, 05:43 PM by freethisone
A most important finding, please download, and upload from this user.
/watch?v=79VEaV5jOE4:blush::blush:
this a very high power ED  LE PMH, with modern day advancements.
with a BIAS for two coils that are not the same. two cores two coils. this can be advanced in any number of ways. another great find..
lets sit down to ponder, and see how a stone may be levitated. in that vibration..
we can now add a coil for induction, and widen the u shape magnet so too pass a coil through, Like the forks on a Bike. I can now use 2 power sources for driving each coil. thank MR ed.:angel:...:sleepy::
« Reply #94, on December 13th, 2013, 06:14 AM »Last edited on December 13th, 2013, 06:50 AM by freethisone
/watch?v=v2L7a1jMJNU
/watch?v=BsN2sr3U0PY
/watch?v=0VojsTUVxGM
/watch?v=BTrY2FgLjtk
the real use for the PMH . both discovered, but if i use iron, its better.
« Reply #95, on January 20th, 2014, 07:40 PM »
/watch?v=6lspAxYGxWA
this is more on the study of.:angel:
Re: Edward Leedskalnin TPU
« Reply #96, on February 3rd, 2014, 10:34 AM »Last edited on February 3rd, 2014, 10:57 AM by freethisone
new information i uncovered, relate to for magneto.
new movie by vini.
this is ground breaking stuff. i found this on the web. who had ever thought this was the case? a 40 hp self running magneto motor? O:-) O:-)
/watch?v=76X2NniEXzE  click link  do you see the corralation heh, corral.
http://www.mtfca.com/coils/Coils.htm
When automobiles were first being developed, there was serious competition between the various inventors vying to be first to market and in a big way.
The vested interests did not want automobiles because it would change their world, requiring them to alter their business stance or adapt to a new world where competition would run rampant. Competition means hard work to stay even or get ahead of the pack, so life is easier when everything is crystallized and fixed. The comfort zones were well established and would be maintained any way they could.
The first year model Ts built by Ford had a special flywheel and housing that was said to have been designed by John Worrell Keely and sold to Henry Ford. Ford bought the design as a form of insurance because of all the harassment he was getting from vested interests not wanting to see him succeed.
After 20,000 to 30,000 cars went out, Ford was threatened by oil and gas interests trying to coerce him to shut down production. It was not made clear who these forces were or why they were trying to put Ford out of business.
After the first year of manufacturing Model Ts, efforts were renewed to shut Ford down. At this point, Ford then gave THEM an ultimatum, either leave he and his family alone or he would send every Ford Model T owner a set of cow magnets which fit in special slots that were cut into the bell housings on the first year run of cars. This bell housing was cast into the engine block and not a separate unit as on modern vehicles.
The flywheels were the hand cranked units having Vee magnets. They were magnetos that when cranked, moved the magnets past a coil to produce a very high voltage/current to spark the plugs. It produced a vicious spark.
Once the cow magnets were placed in the slots, the hand crank was turned and the flywheel would spin on its own, generating up to 40 HP and completely self running.
You had to get the flywheel spinning to a minimum rpm before the magnetic drive effect would take place.
Ford told his opponents that all Model T owners would then be running their cars for FREE, not requiring any gasoline or other fuel. And that the principle would be copied and applied to all machinery.
Once Ford's opposing forces verified the truth of this, they instantly ceased all attempts at intimidating Ford and his company succeeded beyond their wildest dreams.
go to the links  i made it easy to find the patent by ed huff  https://www.google.com/?tbm=pts#q=ford+magneto&start=40&tbm=pts search a few of the pages for magneto related.
« Reply #97, on February 3rd, 2014, 12:06 PM »
Quote from freethisone on February 3rd, 2014, 10:34 AM
Sounds pretty neat Free.  Lets build one.
Seriously, those old cars had the ability to run overunity right from the factory?  Must be the wildest story I ever heard of.
Can you pull out some pictures to confirm the description?  Can't say I have ever seen an original first run Model-T engine.
« Reply #98, on February 3rd, 2014, 01:20 PM »Last edited on February 3rd, 2014, 01:38 PM by freethisone
Quote from freethisone on February 3rd, 2014, 01:17 PM
it took me a minute to understand what a cow magnet is. its a simple horse shoe magnet. now do we see what ed Lee had done? can you see what vini is doing?
but also a link to cow magnet  http://www.magnetsource.com/Solutions_Pages/cowmags.html uses  cow magnets. vini has a cow magnet too?
i guess its that easy when the fly wheel gets to a point it is self running. but now do you see? add all 24 pmh to the outside of the of the spinning ed lee fly wheel.
this will give a trust to the inner flywheel at the correct speed. as stated by vini in his new movie.
i posted the patents in the previous post.
on top of all that ed lee had done, we have these patents that were already availible to ed.
« Reply #99, on February 3rd, 2014, 01:44 PM »
Quote from Matt Watts on February 3rd, 2014, 12:06 PM
I've never seen any evidence of that story, but I'm no T expert either.  Found these pics and wire schematics roaming the net for T bell housings:
http://modelt.org/discus/messages/2/3009.html?1298084981
