Edward Leedskalnin TPU
Re: Edward Leedskalnin TPU
« Reply #100, on February 3rd, 2014, 04:58 PM »
 US1066729 search this pat.
I can see the similarity. you have to really read the descriptions he gives to understand what it can do.
« Reply #102, on March 8th, 2014, 05:27 PM »
didnt know were to add this but i like it.  very interesting coil for use with the fly wheel perhaps>
i would shield this coil in a lead or zinc box.
vortex
« Reply #103, on March 9th, 2014, 11:51 AM »Last edited on March 9th, 2014, 01:24 PM
https://www.youtube.com/watch?v=9EPlyiW-xGI#ws
point
with this coil, POE, and a disk you can create a larger potential.
i hope someone will try.
the disk is a ferrous plate, the coil  should be used to focus the vortex at the shaft.
this should give a lager potential to the outer edge of the disc due to the focus of the coil at the shaft.
the larger the disk the larger the potential diff. O:-) O:-)
« Reply #104, on March 12th, 2014, 03:42 PM »Last edited on March 12th, 2014, 03:51 PM
i just looked at some of my neo sphere magnets, and its true all the magnets have come out. they dont have clear north or south poles. they been stuck to many larger magnets for a long time. they wont even pick up a pin.
rock gate. water channel.   wave guied in the arch of a rock gate.
Ed states "Each particle in the substance is an individual magnet by itself, and both North and South Pole individual magnets. They are so small that they can pass through anything.. In fact they can pass through metal easier than through the air. They are in constant motion, they are running one kind of magnets against the other kind, and if guided in the right channels they possess perpetual power. The North and South Pole magnets they are cosmic force, they hold together this earth and everything on it. Each North and South Pole magnet is equal in strength, but the strength of each individual magnet doesn't amount to anything. To be of practical use they will have to be in great numbers.
    In permanent magnets they are circulating in the metal in great numbers, and they circulate in the following way: Each kind of the magnets are coming out of their own end of the pole and are running around, and are running in the other end of the pole and back to its own end, and then over and over again. All the individual magnets do not run around. Some run away and never come back, but new ones take their place."
so this is ion dipole. you only need to look at dipole density. and channeling it with water, or mercury. The pyramids had used lime stone channels below the structures. it may even channel the current in a way that is more compressed.
with that the AbAha coil does this, and has Rf interference this leads me right back to Tesla and the white noise i had discovered to be the source of said ions, or effect of aether due to spin, and density.
« Reply #105, on March 18th, 2014, 11:57 PM »Last edited on March 19th, 2014, 12:48 AM
related to the crown constellation.
https://www.youtube.com/watch?v=Ga4d0e0YGC8#
as a follow up i had looked for more information presented by MR POOL.
i had though this was a puzzle and was related to big dipper, but i had found some thing more.
perhaps Mr POOL is not 100 % correct when dealing with crown stone.
this is what i came up with. some thing looking like virgo , and i had said perhaps not.
see this vid here. https://www.youtube.com/watch?v=KIcMFZh0FQw#ws
i will imply present the case. http://maps.seds.org/Stars_en/Fig/ara.html
http://www.maicar.com/GML/CONSTELLATIONS.html   related to GREEK myth..
TRA  terra  http://maps.seds.org/Stars_en/Fig/ara.html
my case ARA is not the crown stone, but the alter itself, were the virgin gave birth to the son who would be eaten at birth.
any way look at this cluster it has 3 stars that can make a triangle also, and it could be in the same position as the crown stone in the north pointing up. as pool states The coma bernices.  so look at this, and tell me why the Greeks show case this star cluster,   HMM if you take the top triangle, and overlay it on the lower triangle, you end up with a masionic symbol. compass.
I think perhaps this is what ed lee had depicted, it also could be considered the tourch held at the Olympics. and masionic aprin washington wore.
so tell me what you think..
it needs to be rotated...
https://en.wikipedia.org/wiki/Hour_Glass
   see also medusa the head with snakes and its orgins.
« Reply #106, on March 19th, 2014, 12:51 AM »
 situated in Budapest, Hungary next to City Park, right of Heroes' Square and behind the Palace of Art (Műcsarnok). It is made of granite, steel, and glass, and weighs 60 tons. The "sand" (actually glass granules) flows from the upper to the lower glass chamber for one year. The sand runs out on New Year's Eve and the Timewheel is then turned 180 degrees so the flow of the sand can resume for the next year.
 heroes of the gods, who killed the giants? pole shift  galactic day 25 k years.. cheers
« Reply #107, on March 19th, 2014, 11:45 AM »Last edited on March 19th, 2014, 11:47 AM
Even more revieling is the solomon key in the wood frame, the chess board, the a frame, the compass, hourglass. the alter, and atheana. you have the heads of medusa, or the crowns, cheers.
aprin, and the tourch. and the crown stone all in one. so who has rediscovered truth?
« Reply #108, on March 19th, 2014, 12:02 PM »Last edited on March 19th, 2014, 12:19 PM
the magnet motor, think of it as a spiral galaxy one rotation around is a day, but the energy at the arms is were a current is formed. the centrafugal force. near the center you have a gate. the neutral black hole.
gravity. it works with light also. so you have a current, a diffrance in potential from the center through the axis. my advance ,send it through a wave gide or through a rock. mercury or conducting moving water.
a new homo polar motor is made.. with this you may find a run away effect..
now you make it like i will say. a disk and a shaft. with brushes and magnets, like i am telling.
simple take a Faraday motor, and at the copper disk add magnets. configured as stated in the fly wheel. connect your leads to both end bearings.. your taps, or out put  are the brushes to the spinning magnetic disk, and the other to the center bearing. shaft. between these connections a cap bank for storage. you may also try 2 tap wires brush on the outer disk spaced about 120 degrees, and a third brush at the shaft. configure your cap output circuit. credit.
i have shown many examples. with theory we can be assured to have results.. :cool:
cheers.
« Reply #109, on March 20th, 2014, 01:31 AM »
another smoking gun  Asteroid to Black Out Bright Star Regulus
Millions of lucky viewers can watch Regulus wink out late Wednesday night. . . weather permitting!
MARCH 13, 2014
by Alan MacRobert
« Reply #111, on March 22nd, 2014, 05:52 AM »Last edited on March 22nd, 2014, 06:07 AM
Yes Free,
That's the real deal right there.
Now the next step is to make that in three dimensions and you'll have a true plasma chamber you can do something with.  Based on what I learned from Tetryonics, if you build the 3D solution correctly, you may be able to transform energy directly into matter and vice versa.  Matter is nothing more than standing wave energy trapped in 3D space.  A fractal 3D device should provide a portal in and out of that space.
I have always thought the toroid donut was a partial solution, not the complete solution.  A true spherical solution that has two poles, has to be far more correct.
« Reply #112, on March 22nd, 2014, 09:04 AM »Last edited on March 22nd, 2014, 10:27 AM
now go to 17  min 58 seconds. there is the pattern ed lee shows. its on this mans collar..  cheers :cool:
proof positive
https://www.youtube.com/watch?v=Ga4d0e0YGC8#  and now go to 8 min 30 seconds, compare, its the same thing..
this is the case i make, and is how my planetary orbital objects travel round the sun..
proof positive..
now go watch the movie contact. we have cognitive contact with our reality. Keplers law outlined.
« Reply #113, on March 23rd, 2014, 08:25 AM »
Is this a Circuit diagram? to all u guys who know these things, i see for myself a switch but to confirm tell me the entire diagram.  i am talking about the outer wall as a closed loop system.. can u see it? cheers.
can u see the switch on the left? pos and neg side of the circuit..
« Reply #114, on March 24th, 2014, 12:20 AM »
Looks like the Akula circuit to me. ;)
« Reply #115, on March 24th, 2014, 12:45 AM »
Well I see beer, a bath tub.......
My God, Ed's BBQ.
Good thing there's a repentence corner.
« Reply #116, on March 24th, 2014, 06:19 PM »
wut ever, the altar, and the heart table .the table is a place of, well sacrafice.  his poor sweet 16 left him at the alter..? hmm did she die on that table??
the crown stone is an alter.. http://en.wikipedia.org/wiki/Altar
time to wake up.
« Reply #117, on July 2nd, 2014, 05:06 AM »Last edited on July 2nd, 2014, 05:15 AM
experiments
here is an example of ed lee magnetic work. also early work in epg pump. magneto pump. Russssss.. :P
its a wheel within a wheel  out of phase in 2 directions. hehe.. now what did we do?
« Reply #118, on July 2nd, 2014, 07:47 AM »
It's such a treat to watch the good Professor's clips, they're priceless :thumbsup:
« Reply #119, on July 3rd, 2014, 06:26 AM »
That was an awesome video.  :cool:  Tells me the EPG magnetic gas should have copper or aluminum plated iron nano-particles.  :idea:
« Reply #120, on July 3rd, 2014, 01:45 PM »Last edited on July 3rd, 2014, 01:48 PM
magnetic pull, and magnetic waves.
Quote from firepinto on July 3rd, 2014, 06:26 AM
at 4 min in the movie he talks about adding the magnet, and at 407 do u see what had happened?   to ponder the thought of the foil, and its movement due to the magnetic..property of neo, or such... why did it move? because f an electric field. he has shown that a magnetic component flows away, and a rotation of flux in another direction all together.. this is very important. go back over it..  cheers....
u may say it has both a centripetal force and centrifugal force. a magnet. flow , and electric flow?..
« Reply #121, on July 3rd, 2014, 05:03 PM »
Quote from freethisone on July 3rd, 2014, 01:45 PM
see this movie (The video's owner prevents external embedding)
in this flick you get to see the 2 components of the magnetic river..
kk (The video's owner prevents external embedding)
« Reply #122, on July 3rd, 2014, 06:38 PM »Last edited on July 3rd, 2014, 06:41 PM
Professor Laithwaite was another one of those guys way ahead of his time.  Note:  He worked out a gyroscopic propulsion system quite some time ago:
http://www.rexresearch.com/laithwat/laithw1.htm
I wouldn't be a bit surprised to find out some day he had locked away a truly free energy device as well.
« Reply #123, on July 4th, 2014, 01:50 PM »Last edited on July 4th, 2014, 02:05 PM
Quote from Matt Watts on July 3rd, 2014, 06:38 PM
yea i been watching him.  i have a question for you.  we know now what a wheel in a wheel can do, and how it operates. out of phase ac in opposit directions of the coil within a coil design.. if you had two Rodin coils  wound in that manner compressed, and inside one another. some added steel perhaps as a core, look out..
this is my question if i had made a coil in a coil, and drive them as described out of phase, and in reverse. what would happen?
i say i can in theory use the outer magnetic field with a copper tube. and the inner core on an axial.
i want to drive the tube, over a magnetic river, inside the tube my coils. and as a matter of testing see what could be learned. i want to drive a rotor. like a Faraday disck, attach my outlet at the disk, and shaft. a cap in between this for charging.. to see if a tube of copper can spin as a Faraday disk with its brushes, and connections at the axial bearing, and edge of tube. the larger the radius of the tube the better. 2 coils inside. i want to isolate both charges, and place one on the tube, the other at the shaft..
 :dodgy:  i do want to make a two core coil electro magnet, just like in the patent above. this was described by Ed Lee also.
north pole inside , south pole outside. this is a isolated mono pole. think about what u can do  with a all north pole shaft, as a axial for use with a motor.then i can add a outer, and inner coil on top of that one.
we only need do the experiments. this is true. Henry Cavendish did them, and i followed along ,and did them too. i discovered the air charge accumlator.
when he talks about the pumping of a gas by a magnetic field we learn this fact.
He verify my theory of Tesla. He gives white noise a meaning. its a dipole movement, and it reacts like he shows. It is the  Aether
we can see it now. I know two way how to use it. one with my accumulator. and the second by a change in pressure of that eather caused by  the sun, or additional Mass in the system. pressure of the fluid will go up. it is now proven this is a fact?.
