Edward Leedskalnin TPU
Forum Administrator
fastimports3
RE: Edward Leedskalnin TPU
« Reply #1, on September 8th, 2011, 08:00 PM »Last edited on September 8th, 2011, 08:32 PM by fastimports3
Whatever our resources of primary energy may be in the future, we must, to be rational, obtain it without consumption of any material" Nikola Tesla
                 Magnetic Flux Compression Generator (MFC Gen)
   Capable of generating power levels of multi-terawatts in tens of nanoseconds,
Solid state device similar to Leedskalnin device which used the laws of inertia couple with Magnetic Current and Electron Phase Shift/Standing Wave.
THE FUNDEMENTALS NEEDED
Marko Rodin has discovered the source of the non-decaying spin of the electron. Although scientists know that all electrons in the universe spin, they have never discovered the source of this spin. Rodin has. He has discovered the underpinning geometry of the universe, the fabric of time itself. He has done this by reducing all higher mathematics – calculus, geometry, scalar math – to discrete-number mathematics.
http://vortexmath.webs.com/
                                  Edward LEEDSKALNIN
                                       Magnetic Current
                    http://www.rexresearch.com/leedskal/leedskal.htm
 [/code]
                                             THE  ELECTRON  PHASE  SHIFT
                                   http://glafreniere.com/sa_phaseshift.htm
                                               FLUX COMPRESSION GENERATOR
                             http://reactor1967.fortunecity.com/freenergy.html
High Energy Free Energy Generator - Fcg's being used for free energy. The USA military use this to power its high energy weapons. (Status classified by the USA)
MAGNETIC PULSE COMPRESSION (MPC)
Magnetic pulse compression utilizes reactors in conjunction with capacitors to shape input pulses into narrow output pulses of much higher current . MPC, therefore, allows the designer to use less expensive input switches with lower current ratings. MPC can also extend the lifetime of the input switch. Advanced MPC devices - capable of generating power levels of multi-terawatts in tens of nanoseconds - have been realized utilizing Metglas® cores.
                                                          http://www.metglas.com/products/page5_1_3.htm
This product may require licensing for export outside the United States:
Please visit the U.S. Dept of Commerce website to understand the necessary requirements. ( http://www.bis.doc.gov/licensing/index.htm#factsheets )
Metglas®, Inc. requests that the applications and approval accompany any request for samples, quotations, or purchase orders.
Nothing is impossible, it is only wheather or or not it is probable in my time....
Fastimports3
« Reply #2, on October 24th, 2011, 01:04 PM »Last edited on October 24th, 2011, 01:08 PM by freethisone
 Great Thread.
This must be looked into further. There is a field magnet effect, that must be in motion held by the PMH.
A flowing sine wave of magnets, or pathway of electrical energy, that he tranfered by a wire to his coral blocks?:-/
Sooner or later we will figure it out. Thanks
« Reply #3, on November 1st, 2011, 01:00 PM »Last edited on November 1st, 2011, 01:28 PM by freethisone
Hi Russ, Have you realized  the reason he used a crank shaft encased in quartz crystal? was it to act as an insulator, or a source of energy?
Also have you realized the need for the reciprocation motion of that crank shaft he employed for the generator  devise found in his shed?
My speculation is that he was doing exactly what you are doing in video 1, to establish, and then pull with great force the PMH off the devise as it rotated.
A forceful moment of the magnetic domains in the iron bar. A back emf has a magnetic component i would suppose.  The discovery of  how to use the negative energy created from the back EMF .
Is it the Same magnetic energy acting on my wire to create the self oscillation circuit i had discovered?
What do you think Russ?
Have you any additional information? thanks.
« Reply #4, on November 2nd, 2011, 07:04 AM »
Quote from freethisone on November 1st, 2011, 01:00 PM
good question man! i really don't know. but its very interesting! Sweet 16!
« Reply #6, on January 2nd, 2012, 12:38 PM »
Quote from firepinto on January 1st, 2012, 07:21 PM
I thought this was an interesting theory.  Had to share it.:P
https://www.youtube.com/watch?v=BY0Rn56uAMY&feature=g-all-u&context=G2021703FAAAAAAAALAA
great, sure he is on to something, and can easily be tested..
A wheel in a wheel. I liked the information he has on the pole star.
This must be correct? Why has the truth been hidden? pole star, earth orbit.
looking east. I love a good mystery.   thanks for the link....:)
« Reply #7, on January 3rd, 2012, 11:02 PM »
Quote from freethisone on January 2nd, 2012, 12:38 PM
yep! he is going to test these theory... lets wait and see and some one keep posting his updates here? or invite him over to post here... thanks!!! ~Russ
Blazer
BaronBassman
« Reply #10, on January 22nd, 2012, 08:52 PM »Last edited on January 22nd, 2012, 08:56 PM by BaronBassman
Hey Russ, can you prove a theory to me? If you touch a VOM (or some other measuring device) to the conductors in the coils, does the magnet go back to the 'soft' attractive state? I'm thinking that any chance for that tiny current running in those coils to go to ground (including through a test probe) will basically 'kill' the current flow through the PMH.
Thanks,
Derrick
EDIT: I have the Leedskalnin pamphlets. Interesting reading for sure...
« Reply #11, on March 10th, 2012, 02:26 AM »
Quote from BaronBassman on January 22nd, 2012, 08:52 PM
Thanks,
Derrick
Is mercury, on both an elemental and compound basis, a material that could be magnetized?
- Natalie
Florida, USA
A:
At room temperature, the element mercury is not very magnetic at all. It has a very small, negative magnetic susceptibility, meaning that when you put mercury in a magnetic field, it magnetizes just a little tiny bit in the opposite direction. We say that mercury is a weakly diamagnetic substance at room temperature.
Many compounds containing mercury are also weak diamagnets, but some are a little stronger than mercury itself. It probably is possible to make an alloy of iron and mercury which is magnetizable, but that wouldn't be the mercury's doing.
Mercury is much more interesting magnetically at very low temperatures. At temperatures below about 4 degrees Kelvin, elemental mercury becomes a superconductor. In fact, superconductivity was discovered by Kamerlingh Onnes in 1911 by studying mercury at low temperatures.
Superconductors generally expel magnetic fields, so you could say that below 4 K, mercury is a perfect diamagnet. To expel a magnetic field from a material, a canceling field must be created by that material with currents flowing on the surface. These currents flow with no resistance in superconductors.
You can also make a permanent magnet out of a loop of superconducting mercury. Simply cool down a loop of mercury in an external magnetic field (the temperature at which the mercury will superconduct will get lower as the applied field gets stronger). After the mercury becomes superconducting, it locks in the total magnetic flux through the loop. Switch off the external magnetic field, and a persistent current will flow around the mercury loop, making a permanent magnetic field.
Blazer
« Reply #12, on March 10th, 2012, 10:58 AM »Last edited on March 10th, 2012, 06:47 PM by Blazer
Quote from securesupplies on March 10th, 2012, 02:26 AM
Thanks,
Derrick
- Natalie
Florida, USA
A:
Dan Winter says plasma is fractal and Jason says vortexs are absent of heat at the end in other words absolute zero then is it possible to charge mercury with a plasma?  I wonder if Stan used any mercury in the center of his inside tube? I wonder if Stan used a mercury vapor as his magnetic gas?  I wonder if he could have vortexed them in opposite directions thru the tubes till they met each other?
logos
« Reply #14, on August 22nd, 2012, 11:40 AM »
Quote from ~Russ/Rwg42985 on August 22nd, 2012, 12:49 AM
Well after 2 years it's finally time!
Here is the 2 year test of the PMH
https://www.youtube.com/watch?v=832qz3s1M-s
Enjoy! ~Russ
hey russ... great work.  and this is a very nice forum you have hear.
i put up a few comments on your pmh work on youtube.  there is a lot more i'd like to share as well, especially if people here are trying to replicate ed's work.  i've done some very intense research into trying to sift through most of the misinfrmation on the net about ed...
keep up the great work brother!
Bless
element 119
« Reply #15, on August 22nd, 2012, 12:03 PM »
Hey Russ
2 years and still holds and lights is awesome! :D
If you are interested I was wondering what would happen if instead of the LEDs maybe hook up a volt meter. I would be curious if 9 volt was put into the coils then how much voltage would be recovered when you brake the metal connection.
Same volts in and same volts out would interesting but what if more volts out then put in?
If your V meter has it then data hold for testing.
element 119
Darenzo
« Reply #16, on August 22nd, 2012, 02:24 PM »
Quote from element 119 on August 22nd, 2012, 12:03 PM
Hey Russ
element 119
Hey Russ Great thread and thanks for the link to jason verbelli's channel he's nearly as inspirational as you :)
I too would like to know what voltage and current you are getting out if you feed in 9 volts... Also if there is an energy flowing round the PMH with no power connected is it inducing anything in the coils ?? can you test this with a DVM/Scope etc ??
I can see a PMH/EPG hybrid here ...You just charge it and it runs for 2 years....... or more!
 Great work  Russ i cant wait for the next video .
IDDQD
« Reply #17, on August 22nd, 2012, 08:03 PM »
Today I watched Russ's video on his P.M.H. and I was inspired to build one myself. I found a 5/16 u bolt  and welded 4 washers to it to wrap my coils between . I used telephone hookup wire, each coil has 189 wraps , both coils measure .8 ohms. I used a piece of old motor shaft key stock for the metal to bridge the gap in u bolt. After I figured out which end of either coil needed to be connected I charged the other 2 coil leads with a fresh 9v and it works great. I can't wait to run some tests.
  The first thing I noticed was once charged and the metal is pulled off giving the coil the same polarity charge seems to result in a weaker hold as opposed to reversing the battery polarity every time I energize the coil. I plan on confirming this and running a few other tests. I made a trip to Ed's Coral Castle a few years back  and I am fascinated at his work. Here is a pic of my build, later guys.
« Reply #18, on August 22nd, 2012, 09:15 PM »
Quote from logos on August 22nd, 2012, 11:40 AM
Enjoy! ~Russ
Bless
hey yeas. please do share and we all can learn! thats what its about!!!
also, if me and Jason can get with you and chat that would be cool as well!
send me a PM.
do post your thoughts here for all to see! and discuss!
Thanks! ~Russ
« Reply #19, on August 22nd, 2012, 09:17 PM »
Hey Russ
element 119
check the old videos... already did that one. see first post.
also. its less... posting a video on this now... thanks! ~Russ
« Reply #20, on August 22nd, 2012, 09:19 PM »
Quote from Darenzo on August 22nd, 2012, 02:24 PM
Hey Russ
element 119
yes. i did some small tests with the other small PMH. but now i wall do some much bigger and better stuff with the big one! :)
PS>
he is more... :) check all his videos and you will see that that man is brilliant!
« Reply #21, on August 22nd, 2012, 09:22 PM »
Quote from IDDQD on August 22nd, 2012, 08:03 PM
some fine work there bro! looks good! i will do some more invective tests with voltages and such too...
 uploading a video now that will be worth a watch.
thanks for posting! hope it inspires others to try it! ~Russ
HHO4Life
« Reply #24, on August 23rd, 2012, 03:59 AM »
guys, will some one with an energeticforum log in please get these files attached to the posts:
http://www.energeticforum.com/124363-post222.html
and the next 3 posts.
I'm not sure if there the correct PDF's om looking for but i cant download them...
thanks!
