Stanley A Meyer Water Resonance waveform Bifilar Inductor
https://youtu.be/OxQddESzVrs
Valentin Petkov /valyonpz/
Earl
Re: Stanley A Meyer Water Resonance waveform Bifilar Inductor
« Reply #1,  »
I was reading Patent 4,394,230 today and he shows the spike that was in video figure 6A in stage discussion.  It occurred when open circuit condition was created by removing water from between plates.  In the stages he talks about the conditioning step that Stanley also references.where water conditioning step.  Interesting he states there are very little bubbles even though gas is being generated and that process stops (Stanley was interested in the ionized gas!)  He also states that increasing power did not cause gas generation to restart. Reversing plate voltage did and also vibration did but that caused voltage spikes.   I also wondered if relaxing time (t3) would allow cycle to be restarted?  It this works it might explain the 11 cells in the car so always one or more cells are outputting gas while other are recycling.  Note: In patent he states not all stages he lists are required.
Nice to see items discussed in patent being recreated
« Reply #2,  »
yes I think this is very true and important
we have
1 gas fuel
2 nano bubble water fuel ( dissolved h2)
Both are important to understand and not ground or give back electrons to,  as + charge build in the water the surface tension goes up
with ph and saturated h2 as the dissolved nano bubbles replace other gases in the water, if no ambient - charged air or - charged surface touch water  fuel or gas fuel
gas stays in there and is GTNT quality
if you reverse polarity well that is ground back electrons  and breaking surface tension and undissolving gases
these are fact to understand master and teach
patrick1
« Reply #4,  »
One Day the Spirits come looking for you you can not escape when they arrive
Please remember that it is a horror that no one likes to speak of .
