Correa Tube.
Correa Tube.
The time is now.
Well that's one way to start a thread...
Any how, Here is something i ran across while doing some work with Edwin gray tubes...
The difference between the Correa tubes and Edwin Gray is that the Correa's have extensive data presented in there work. So I'm posting what i found and my current apparatus.
Feed back is welcome and any thoughts are helpful.
on the next post I will put my current setup and data.
Re: Correa Tube.
« Reply #1,  »
Here is my current setup: see attachments.
I am using 6000 series AL right now. I would like to switch to 5052 H34 plates.
My plates are 9" x 2" that's 18 square inches on each plate. ( 457.2 square mm )
using a 2 stage vacuum pump I have been able to achieve Just under 20 microns in the chamber.
I had to sand down and polish off the AL and the glass to get a good seal. Rebuild the seals on the manifold ( Thanks to Jeff for that, he sent it to me 8 years ago or more)
On hand i have helium, argon, and Papp gas...
A live stream of the first test:
https://www.youtube.com/watch?v=F6IDwkpC2ro
more to come. feed back is good.
~Russ Gries
Re: Correa Tube.
« Reply #2,  »
i will post more photos of my system when i get them off my phone :)
Lynx
Re: Correa Tube.
« Reply #3,  »
Is there any short tutorial on what this is?
In the patents I see batteries being used in a circuit which has the tube in it and that which can be made to operate an electric AC motor at various speeds if I understand it correctly and I'm convinced that there's more to this than "merely" being a novel way of powering AC motors, correct?
Good to see you Russ, it's been a while :-)
Re: Correa Tube.
« Reply #6,  »
Quote from Lynx on March 30th, 02:02 AM
Yes. This is way more than just a way to power a motor.
Its a an eletrical genarator.
I highly recommend you read the patant. Mainaly the 5449989. Its verry clear.
Hooe your doing well :)
Re: Correa Tube.
« Reply #7,  »Last edited
Quote from ~Russ on March 30th, 07:53 AM
Yes thank you and you too,
I posted a Video a while back about Tesla vs Meyers ,
it showed side by side Tesla and Meyers
it also showed that electron extraction  happens in the gate with tesla and Meyers ,
 the tesla air ionizer,  psoted on web is a gas processor just add the better extraction materials
it   is the corona effect in the tower that is what
opens the pathway to extract electrons
Welcome to post all patents from these  people great works so we have stuff to read .
AGREED
Re: Correa Tube.
« Reply #8,  »
tesla over came the grounding of the effect  by ambient air with  crazy volt only power ,
we can do small and control with air gate
just a focusing of the technique by meyers, the controlling of the light ways from the corona is also to be noted
as if we  use correct cladding we can maintain the right wave length to continue the  bounce and knocking
not just any coating use barium or magnesium light  wave length coating as you find
in  several sphere resonation technology as posted on other thread ,
 if is exciting  I am sure a Monkey will see and Monkey will do
Thanks for patent ref  making a coffee
Re: Correa Tube.
« Reply #9,  »
ps ionised some helium and make it magnetic epg ref
can find tube of the sealed helium on line  can compress it inside a coil emf as several have tried to do
same time , several have show that newmand may have done both to a degree  - chris that guy from uk tried trasnmutation.
similar to papp
 showing helium magnetic nature  is more important and seamingly  useful for inside the rotor of motor
and epg .
Re: Correa Tube.
« Reply #10,  »
Russ Also I  just watched that live vid of the  running corona contacts ,
can you make 2 electros postive glow like that  than with fast freg gate pull out power  of flowing air?
Re: Correa Tube.
« Reply #11,  »Last edited
Also Do not ask why I was reading yesterday thyristors with in built  hydrogen generator it is very similar
Look up this Very Interesting Back to the Future Term   "Thyratron"  the diagram on paper is very close
Re: Correa Tube.
« Reply #12,  »
Can't find video I saw but basically 6.3 volt into the titanium with dissolve h2  and then 3 kv into the plates gas enter the tube
once hot and maintain the medium for the ionisation  they use as a diode or rectifier  electron sink
we can use for other purpose
We are lucky Tesla and Meyer patented what they did
https://www.youtube.com/watch?v=6_YnejUZCRI
Re: Correa Tube.
« Reply #13,  »
Just some cool photos...
Re: Correa Tube.
« Reply #15,  »
  LOVE THE PICTURES COOL MAN
Lynx
Re: Correa Tube.
« Reply #16,  »
Quote from ~Russ on March 30th, 08:58 PM
Seeing is believing, thanks for sharing :thumbsup:
I could imagine that the shape of the gas itself would virtually speak volumes regarding on how well the tube/circuit performs.
For instance, maybe the gas starts taking on a more shifting/irregular/erratic kind of form inside the tube once it starts "collecting energy", resulting in a overall circuit COP greater than 1.
Then again maybe not, maybe the sign of success is when the gas seems to be rock solid, who knows? :-)
Re: Correa Tube.
« Reply #17,  »Last edited
Still Testing The Vacuum Chamber With My Dad! Oh Boy!
https://www.youtube.com/watch?v=rCkpY19eL1I
Gas discharge phenomenon Ilija Lakicevic
http://teslastyle101.com/wp-content/uploads/2018/05/ATON-TRUE-CELL-ATOM-AND-PARTICLE-CONCEPT-pdf-1.pdf
http://teslastyle101.com/aton-atom-concept/
1 bar magnet under ferrocell
https://www.youtube.com/watch?v=g0YvNMk-Shw
WATER
http://open-source-energy.org/?topic=3023.msg52561#msg52561
Double-slit experiment
https://en.wikipedia.org/wiki/Double-slit_experiment
In Pauli's view it is the number '137', the value of fine structure constant which surpasses the present quantum theory. As Pauli's former assistant Professor Charles P. ENZ formulated, it takes us beyond physics, and, leaving the separate observers behind, transforms the thinking and feeling scientist confronting with former unconscious processes into the active role of the partaking observer.
http://www.greatdreams.com/numbers/444/444.htm
The Wave Theory of Numbers
https://docs.wixstatic.com/ugd/39d6ce_56e9a30646e64df597dbcffa390acf8e.pdf
https://www.facebook.com/robertedwardgrant/photos/a.985040538371539/1010582455817347/
HOLY grail
https://www.facebook.com/robertedwardgrant/posts/1005004823041777?comment_id=1005409423001317&reply_comment_id=1005902659618660&comment_tracking=%7B%22tn%22%3A%22R%22%7D
Re: Correa Tube.
« Reply #18,  »
IS THAT GAS ORGANIZING ITSELF INTO A GAS LATTICE?
OPEN SOURCE
Re: Correa Tube.
« Reply #19,  »
thank you for posting the cone information it is holy stuff, thanks
I would be interested it you can show a magnetic gas , a helium ion magnetisium event and or a copper helium bubble in gaseous form
