Electric vaporizer 90 mpg
Sulaiman
Re: Electric vaporizer 90 mpg
« Reply #75, on February 11th, 2015, 09:41 AM »Last edited on February 11th, 2015, 09:45 AM by Sulaiman
I think that we are diverting too much from this thread/topic
I think that it would be better to open a new topic if you want to proceed with this discussion.
maybe on your workbench?
and some kind moderator could remove these posts to there?
« Reply #76, on February 11th, 2015, 11:20 AM »
https://www.youtube.com/watch?v=EvMLkbnXRPE#
the water coming out is the wasted fuel. i would like to know the temperature of it. the can now be hit with a glow plug or hcat. to accelerate it even faster.
« Reply #77, on February 12th, 2015, 02:58 AM »Last edited on February 12th, 2015, 03:00 AM
https://www.youtube.com/watch?v=Na9ORhYjvJU#ws
i was looking at it from another point of view. adding a venture can oxygenate the fuels, i would use superheated air conditioned in a tesla turbine.
include a steam chamber. i can vent water, or steam into the cylinder or hho. i can use a hcat to precondition, or a spark gap chamber.
the point is the door is wide open..
a wet sump vent to add water or even hho to the mix. these are my ideas any one can come up with better?
https://www.youtube.com/watch?v=0ZMjDgM3LaU#ws
« Reply #78, on February 12th, 2015, 05:15 AM »Last edited on February 12th, 2015, 05:29 AM
I was thinking, the Geet reactor works on similar principles.
I say i can improve a geet reactor by incorporation super heated steam, or browns gas, or a vapor of gasoline.
i can mix anything i want into the combustion chamber.
what would you incorporate into the chamber? steam? ionized fuel? carbon atoms from smoke?
i think if you added water into the geet reactor by way of venture inlet, then you can mix any preconditioned fuel of your choice.
You want to render the fuel injector useless then add directly oxygen ozone, and hho into the chamber, add a glow plug or hcat to complete, or supersonic traducer to boot, Tesla turbine, spark gap or what ever you can think of. O:-)
so i was thinking about your idea, and basically a work around and is special. . so as you see the epg  works on the same principles, because it is a particle accelerator, and both have the ability to incorporate different fuels,and mixtures. super heated steam or atomized vapors.
https://www.youtube.com/watch?v=Wokswr_KHXQ#
« Reply #79, on February 12th, 2015, 02:40 PM »Last edited on February 12th, 2015, 02:45 PM
What similarity do you see with the Geet reactor compared to a venture T?   i see it do you?
https://www.youtube.com/watch?v=wbEYkKKxG1U#ws
With that you can improve upon a reactor build ,by incorporating what was just learned.
incorporation of second gas into the venturie system is recommended, by way of geet reactor, and venturie inlet tube..
in effect a Tesla turbine may benefit with the same improvements.adding a mix of water and air to run the turbine.
« Reply #80, on February 13th, 2015, 06:15 AM »
one of Townsend Browns inventions explained.  good info if you are building a
E
P
G
or even a charged atomized vapor with a spark gap..
l, adapting it for use with air, steam, mercury vapor, or
those fluids less electrically conductive than water or the
like. Gaseous fluids, like air, steam or mercury vapOl',
which are normally conductive only to a slight degree,
are rendered more conductive by the intense ionization
of the electric arc. In the form of this invention illus
tratcd in FIGURE 2, the high voltage alternating current
causing and maintaining the arc is likewise the excitation
current of the generator. Flat electrones 10, 12 are ad
justable from feed screws 24, 26. The arc formed be
tween these electrodes is initiated and maintained by a
high voltage, making it unnecessary to move the elec
trodes except to oliset their gradual burning away. The
are is formed in a space restricted by high-refractory
plates 28, 30 which, in turn, are held in position by heavy
insulated casing 32 and backe dfor mechanical strength
by the laminated iron core 16, only a portion of which is
shown.
Steam, or other fluent material, passes through the are
chamber in the direction of arrow 34, forcibly fannìng
the arc in the direction of arrow 34. The movement
of the material, together with the transverse current of
the A_C. arc, creates an alternating magnetic field within
coil 18 of FIGURE l.
FIGURE 3 is a combined diagrammatic and schematic
illustration of a complete power unit showing a water
or mercury boiler 35, the vapor-electric generator 36
which includes core 38, coil 40 and electrodes 42, 44,
exciter transformer 46, vapor condenser 48, and electrical
load 37, together with necessary steam lines and electrical
wiring. The steam or other vapor generated in boiler
3S passes through the vapor-electric generator 36 and is
reduced in velocity thereby. Thence, the low proesure
steam ñows in a larger pipe 50 and passes into condenser
' 48, is condensed and returned in liquid state to boiler 35,
wherefrom the cycle is repeated.
It is obvious that in starting the generator, the exciter
current must be present before actual generation begins.
For this reason, the exciter 45 must have an independent
source of energy supply 52. However, after the process
is started. the power output may be tapped, as at trans
former 37, for that fraction of the current required to
excite the generator, but certain control devices attached
to and comprising exciter 46 must be employed to main
tain proper frequency and phase relation.
While in the foregoing specification I
« Reply #81, on February 13th, 2015, 06:19 PM »
the find of a life time.. this is not just a how to video, it also proves the concept once and for all.
what i did was prove the super heated gas is real, and a Tesla turbine is ideal, for pulling a vacuum from a flask thereby creating a vapor.
skip to the very end to see the water heated from a turbine.
advancement, adding a venturie tube now would be a huge improvement. i
https://www.youtube.com/watch?v=S1OlhrzJKMY#
« Reply #82, on February 13th, 2015, 11:25 PM »
Quote from freethisone on February 13th, 2015, 06:19 PM
Nice find Free.  Had no idea a Tesla turbine could pull a vacuum.  Sweet!
« Reply #83, on February 17th, 2015, 06:34 AM »
http://inspectapedia.com/water/Water_Tank_Air_Add_Valve.htm
all this stuff goes hand and hand. here i found a way to add water and air together , this would be ideal for Tesla turbine conditioning of fluid to be used as a fuel. the object heat the fluid into a vapor,. use this as fuel. water, and air.  use this with a venture system, use with geet reactor, or other uses.
o
« Reply #84, on February 19th, 2015, 05:42 AM »
https://www.youtube.com/watch?v=f949gpKdCI4#ws
by another means incorporate the magnetic flow meter.into a EPG, or for placing the venturie fl  ow devise directly after the particles are split into there positive, and negative charges, causes the atoms to come back together more forcefully., similar is the principle of the epg were magnetic fluid is split into north and south poles.  Stan Meyer incorporating the permanent magnet principle about the spark gap chamber. now its understood simply as a separation of magnetic fluid into its constituent parts. one other fact uncovered the magnetic fluid moves slowly as Stan had said.
now we understand more about the epg, and how we can use magnetic flow meter as a way to condition the fluid, and accelerate it even further. then it will induce a voltage in a coil, or stretch any fuel to its potential.
brettly
« Reply #85, on March 10th, 2015, 03:58 AM »
I'm not sure if water foggers ( ultrasonic) have been brought up in this thread.
There was a youtube video showing a water fogger in water, with a layer of petrol above the water,
the petrol still got vaporised. It might even work with a layer of thin plastic over the water, with petrol above ( too keep the vaporiser electrically isolated from the petrol) You can of course use the foggers directly in petrol but a bit risky I think.
Lets say you set up a water fogger to vaporise the petrol and allow it to enter via the air intake, on a modern car would the car still run? Assuming the petrol injectors are plugged off, and some method to pump petrol to a vaporiser.
« Reply #86, on March 10th, 2015, 08:43 AM »Last edited on March 10th, 2015, 08:49 AM
Quote from brettly on March 10th, 2015, 03:58 AM
modern cars use mass air. if u want to pipe it into the air inlet , u will need to pipe it in before the mass air unit. otherwise it wont run right,
sequential map sensors are a better choice because its not a lean situation.  mass air sensor recalibration will be needed, calibrations can be made by a qualified center, costs are about 250 dollars.
there is another way. that no carburetor , or spark plug is needed.. just need to look at page 1, find the patent it relates to.
in 1920 mass air was not used yet.   so all was done all tuning was done at the carburetor. air, and fuel  was mixed there.
brettly
« Reply #87, on March 11th, 2015, 03:43 AM »
thnx for that , sounds complex!
« Reply #88, on April 14th, 2015, 02:03 PM »
Six things you should know about the gasoline you buy
Use your key for the next article
Next: The Best Gas Crunch Story I Know
May 30, 2012 8:32 AM MST
    Facebook
    Twitter
    Pinterest
    Linkedin
    Google Plus
Make sure the gasoline you spend your hard-earned money on is working for you, not against you.
K. Munson
Since the Clean Air Act of 1995 took effect, gasoline sold at the pump has not had as high a level of detergent additives as in years prior. Effectively, this leaves your engine more susceptible to carbon and sludge buildup if too low an octane fuel is used.
With gasoline hovering around $4 per gallon, knowing some basic facts about the gasoline we buy will help you get the most out of it, and keep your car in better health…
1. WHAT OCTANE RATING MEANS AND WHAT YOUR CAR REQUIRES IS IMPORTANT TO KNOW
We all know higher octane gas costs a bit more. But why? The higher the octane number, the more a fuel can be compressed before detonating. In short, fuels with a higher octane rating are needed in higher compression engines that generate high horsepower for their size.
For example, Mercedes-Benz and other German carmakers recommend 91 octane fuel in almost all newer vehicles. Porsche owner manuals specify 93 octane gas. In the words of a Porsche spokesperson on the decree, “It does not indicate any exceptions.” Because 91 or higher octane gas can’t be found sometimes, Mercedes’ advice is to use regular in a pinch — but no more than half a tank — until locating a station that sells premium. Good advice.
2. USING LOWER OCTANE GAS THAN RECOMMENDED BY THE MANUFACTURER CAN HURT YOU
On newer cars, using lower octane gas than the car is tuned for will result in fewer miles per tankful than you expect. (Photo credit: My English Club)
First, fuels with higher octane content are more stable, and resist premature detonation of fuel when it first enters the combustion chamber. If fuel octane measurement isn’t high enough for your vehicle’s engine pressure, that premature detonation causes harmful “knocking” of pistons, connecting rods, and intake/exhaust valve parts. Furthermore, more fuel is left unburned at the end of the combustion stroke which causes a number of ill effects.
Most newer cars have knock sensors that when alerted, signal the car’s engine computer to adjust engine timing so lower combustion pressures result. The end effect is sluggish performance and noticeably lower fuel economy. Any monetary gains that come from buying low octane gas are fully offset by the reduced mileage.
Second, in the shop I regularly see check engine lights that will not stay off due to multiple misfires (often too slight to notice) resulting from carbon and sludge buildup on fuel injectors, intake manifolds, pistons, and cylinder walls. The fix for this is labor intensive – a technician must disassemble the top part of the engine and literally scrub the carbon off engine parts for the car to run right. Unless resulting from another specific problem, this is caused by unburned/low quality fuel 19 times out of 20.
Third, increased amounts of unburned gas going out the exhaust system will, over time, foul oxygen sensors and the catalytic converter(s) your exhaust pipes are equipped with. Catalytic converters are very expensive. In my experience, if an engine is kept in good running condition and good quality gas is always used, there’s no reason a catalytic converter shouldn’t last well over 100,000 miles if not the life of the car.
3. ETHANOL “E10” FUEL ADDITIVE – BOTH A PLUS AND A MINUS
In the EPA’s quest for cleaner air, it mandated in 1992 that reformulated gasoline with 10% additive content be sold during winter months to reduce ground level smog and ozone. Because the methyl tert-butyl ether oxygenate mixed into the gasoline (MTBE) contaminated groundwater significantly when underground storage tanks leaked, this additive was banned and “oxygenated gas” passed into history.
Replacing MTBE as a fuel additive was ethanol, also known as “E10” for the 10% maximum content of it allowed by law. Essentially grain alchohol, it does not have negative environmental effects. However, it is a possible source of grief in your engine.
E10 reduces fuel mileage by 4 to 5% due to its lower b.t.u. heat output per gallon (84,000 vs. 115,000 for gasoline). Mainly, increased amounts of ethanol in standard combustion engines cause incomplete combustion and the ills that result from it.
Many gas stations illegally water down their gasoline with more ethanol than the law allows to stretch profits. Those that are on the level often don’t check the ethanol levels in their tanks, and can just as easily receive a poorly-mixed batch of gasoline from an incompetent or unethical refiner.
I know this happens for a fact. In the shop when a customer’s German car is running poorly and no specific problems can be found, we use a test kit to determine the percent of ethanol in the car’s gasoline. Usually test results show ethanol levels in the sick car between 15% to 20% – much higher than the 10% allowed by law.
Of note: a government-funded study by Mercury Marine Company showed a blend of 15 percent ethanol and gasoline caused such extensive damage to boat engines that the test was ended early.
4. “TOP-TIER” GAS BRANDS
Since minimum gasoline additive performance standards were first established by the EPA Clean Air Act of 1995, most gasoline marketers have since reduced the concentration level of detergent additives by as much as 50%. This has made it tougher for engines to run clean and maintain stringent Tier 2 emission standards.
BMW, General Motors, Honda, Toyota and Volkswagen/Audi have all recognized that the current EPA minimum detergent requirements don’t cut it on today’s higher compression engines. As a result, an unofficial industry standard of rating the highest quality of fuel as “Top Tier” is specifically recommended to customers by them.
New England area chain gasoline brands named on the list that consistently, as a whole deliver fuel of Top Tier quality are Chevron, Conoco, Exxon, Mobil, 76, Phillips 66, Shell, and Texaco. Others on the list throughout the country are Aloha Petroleum, Quiktrip, Rebel Oil, Road Ranger, Country Mark, Severson Oil, Entec Stations, Kwik Star, Break Time, Mileage Stations, Tri-Par Oil and Turkey Hill Mini Markets. Manufacturers are adamant in their beliefs about fuel quality. Since they have no big oil interests, they would have no reason to fudge results.
After interviewing customers in the shop about which brands of gas they purchased before experiencing high ethanol problems, I do not question the Top Tier list.
5. OVER-THE-COUNTER GAS ADDITIVES AREN’T ALWAYS HELPFUL:
Because mostly what’s inside a can of fuel additive are chemicals to boost octane levels, you really don’t need it if you’re buying gasoline with the proper octane rating in the first place.
Fuel additives can sometimes cause problems instead when mixed with E10 gas. Many fuel additives claim to restore “E10” back to its pre-ethanol state, but according to many chemists it is not possible.
Check the ingredients in that container of fuel additive before you buy it. Using alcohol-based and strong solvent additives in fresh E10 gasoline is not recommended, since this may serve to raise ethanol content even higherwill only increase water absorption, parts corrosion, and may also raise ethanol content over the recommended 10% maximum.
Products that contain strong solvents, emulsifiers and water-absorbing agents should not be used with E10 gasoline either. Strong emulsifiers will not only force alcohol and water back into gasoline, they may also solidify engine lubricating oils and additives in gasoline. Clogging, gelling and gunk can build up in the engine.
Fuel additives can be helpful in a situation where too much water has gotten into a fuel tank due to a disconnected hose or other open entry in fuel lines. Usually those problems are repairable without too much difficulty, but in the meantime look for a lubricating fuel conditioner that delays “phase separation”. Or for a fuel stabilizer that claims to break down water molecules. If rusting of engine parts is a worry, look for a fuel additive that specializes in corrosion inhibiting.
6. BAD AND DEGRADED GAS – HOW IT HAPPENS
Alongside water condensation in fuel tanks, gasoline degrades naturally over time causing chemical breakdown of ingredients into a thicker more varnish-like substance. (Photo credit: M. Stevens)
Sometimes it’s already partially degraded when you buy it from the gas station. Unlike crude oil, gasoline is a highly refined product brewed to a certain chemical composition with very specific characteristics. One characteristic of gas is volatility, a term used to describe how easily and under what conditions the gas vaporizes so it can be efficiently burned in your car’s engine.
The most highly volatile components in gasoline also tend to evaporate over time. As they do, fuel’s volatility and ability to combust decreases. The less volatile the fuel, the less effectively it burns in your engine. Diminished engine performance and minor misfiring may result.
Oxidation of Fuel
Over time, hydrocarbons in the gas react with oxygen to produce new compounds that eventually change the chemical composition of the fuel. This leads to gum and varnish deposits in the fuel system. These deposits and impurities can clog up gas lines, filters, carburetor channels, and tiny fuel injector orifices.
Water Contamination
Condensation can form naturally inside your gas tank and lines from hot-and-cold temperature changes. Water contamination can be a problem at gas stations with light traffic due to a slightly different kind of heat cycling.
Underground storage tanks experience increases and decreases in temperature which can cause moisture to form and contaminate the fuel. When you fill up at such a station, you’re pumping in already-waterlogged gas. Such low-traffic stations may also have rust contaminating their storage tanks. Avoid these light traffic fuel stations whenever possible.
Water will cause hard starting and rough running until it’s purged out of the fuel system. It can also contribute to internal rusting of the gas lines and tank. Resultant scale and small particles can create a nightmare – in extreme cases replacement of the gas lines and tank are required.
Traditional wisdom says you can reduce the chances of water contamination by keeping the gas tank as close to full as possible, especially if the vehicle is going to be left idle for an extended period. However I always leave a little extra room for adding fresh gas the moment I take the car out again in the future.
Identifying bad gas
One way is to eyeball it. Oxidized fuel often turns darker over time and may even smell sour. You can check stored gasoline by pouring some into a clear glass container and comparing it side-by-side with known fresh gasoline. If your old sample looks noticeably darker than the fresh gas, you have strong evidence the gas has gone bad.
« Reply #89, on April 14th, 2015, 02:06 PM »Last edited on April 14th, 2015, 02:13 PM
Quote from brettly on March 11th, 2015, 03:43 AM
making a car run on water is not a easy task if the motor is not designed for that.
now that you know 20 % ethanol in cars, and a lot of water too is already in your fuel, a vaporizer will do a better job than any of Stan myers stuff.
i outlined key features and advancements to do just that. run the car on superheated steam. but instead i simply use it as a converter, and choose to run the car on electric.
its easy to see how a small electrical motor, or in our case super heated steam turbine,or better yes superheated steam injection.
for practical purposes..
Cycle
« Reply #90, on April 17th, 2015, 07:46 PM »Last edited on April 17th, 2015, 07:48 PM by Cycle
Quote from freethisone on April 14th, 2015, 02:03 PM
No need to go to such extremes... a thick fog of water vapor directed into the intake to loosen carbon deposits, along with 2 oz/10 gal of acetone in your gas to burn the carbon deposits and loosen the sludge buildup, along with a good high speed run will blow the carbon and sludge right out.
« Reply #91, on April 17th, 2015, 09:25 PM »Last edited on April 17th, 2015, 09:27 PM
Quote from Cycle on April 17th, 2015, 07:46 PM
As of 2014 i found many new improved experimenters dealing with this application, over the geet reactor. but still i say i can do far better with a tesla turbine...
this is how far we past the geet reactor..  this is how simple as it gets.
 for cheap homemade proposal., as u see this can be advanced in any number of ways and is a practical application on the cheap...
so here you go 2 more simple ways to do what was done in `the 1920 s
https://www.youtube.com/watch?v=TWstiuK9bqk#
https://www.youtube.com/watch?v=58IkmPK6ikc#
« Reply #93, on April 18th, 2015, 02:24 PM »Last edited on April 18th, 2015, 02:32 PM
https://www.youtube.com/watch?v=dW0moXn9y9U#
https://www.youtube.com/watch?v=GrtyTXNyIbk#
just as a proof of concept i concluded there is a possibility of a closed loop, as stated. but this is a older movie.
i can do much better with Tesla. 500 mph plus i claim i can achieve based on all that has been learned, including my advancements...
ps ball valves are the worst valve to use for this application...
a dollar is more gooder lol..
Now i say Mr teselonian can have his new refinery based on smoke in carbon atoms. in other words MR T can achieve directly from fire to fuel vapors in one step, from wood stove to the refinement process, and then directly into a engine
as he stated, the ball valve is all wrong for this application.. As i claim the Tesla turbine will win the battle in the end. we are talking heat....
Enrg4life
« Reply #94, on April 19th, 2015, 06:34 PM »
Has any one ever tried running a second engine off of the fumes of a first engine?
kenssurplus
« Reply #95, on April 19th, 2015, 06:48 PM »
Yeah, I heard from one of the principals involved in the geet drama that there were tests done linking several car engines together (exhaust from one to the intake of the next) with all but the first one sucessfully running off of nothing but exhaust from the previous one.  I think the first one was just a regular gasoline fed engine and not modified with a geet reactor If I recall correctly.  (been a number of years).
Enrg4life
« Reply #96, on April 20th, 2015, 05:57 AM »
I think i'm going to try this today. Maybe my truck could run my garden tractor then my 10 hp generator. That would be pretty cool. Or my Prius hybrid  exhaust could run a generator to recharge the battery bank faster to   run the electric motor more. We will see what happens.
« Reply #97, on April 20th, 2015, 06:10 PM »
I was not able to get the garden tractor or the generator to run on exhaust fumes from other engines. How ever i did get them to run on gasoline fumes quite easily. All i had to do was  remove the gas line feeding the carburetor and put the gas can nozzle about an inch away from the air intake, the generator and the garden tractor ran quite well that way for a couple hours each
« Reply #98, on April 20th, 2015, 06:37 PM »
Now try that with gasoline that has been sitting around for a couple of years.  It will still smell like gasoline, but it won't burn.  Do the same thing with alcohol and it won't matter how long it sits.  That should tell you something.  It did me.
« Reply #99, on April 21st, 2015, 07:34 AM »Last edited on April 21st, 2015, 07:36 AM
Quote from Enrg4life on April 20th, 2015, 06:10 PM
thanks for the test and feed back.
its an interesting test
