Spherical Resonant Cavity Replication
Re: Spherical Resonant Cavity Replication
« Reply #26, on March 28th, 2019, 07:49 PM »
Materials
The optical properties of the lining of the sphere greatly affect its accuracy. Different coatings must be used at visible, infrared and ultraviolet wavelengths. High-powered illumination sources may heat or damage the coating, so an integrating sphere will be rated for a maximum level of incident power. Various coating materials are used.
For visible-spectrum light, early experimenters used a deposit of magnesium oxide, and barium sulfate also has a usefully flat reflectance over the visible spectrum. Various proprietary PTFE compounds are also used for visible light measurements. Finely-deposited gold is used for infrared measurements.
An important requirement for the coating material is the absence of fluorescence. Fluorescent materials absorb short-wavelength light and re-emit light at longer wavelengths. Due to the many scatterings this effect is much more pronounced in an integrating sphere than for materials irradiated normally.
https://en.wikipedia.org/wiki/Integrating_sphere
« Reply #27, on March 28th, 2019, 07:50 PM »
A While Back Max Posted some  tests and a 3d printer file I cc it here as it is good work and
important part of the puzzle we now call a proven fact Stanley A Meyer Told the Truth
« Reply #28, on March 28th, 2019, 07:53 PM »
Note from Max
an open sourced, cheap 3D printed integrating sphere.
more pics and video of it soon.
matter hacker black has let me down. first part of the spool looked great, then the middle of it is a different crappy gray funky printing crap. OH WELL! i am painting the sphere anyway.
the inside top of the sphere was a little droopy on the print, so i use a wood burner iron to smooth the plastic out. the iron has a V shape and works well for this. then some sandable primer and clean it up, then the finish in gloss white.
you can see the LED in the one end and there will be a sensor at the other end.
patrick1
« Reply #29, on March 29th, 2019, 09:28 AM »
printing like that is amazing without supports.  no chance on a basic machine without years of experience
« Reply #30, on March 30th, 2019, 05:34 PM »
lol that is a basic machine with no experience lol
it is childs play  look up markforged carbon fibre 3d printing if you want the advanced mans stuff
« Reply #32, on March 6th, 2021, 12:56 AM »
Here is Max Miller showing a Replication unit of the Sphere cell he shows hole in top and hole in bottom for water flow in  and gas out
here show the holes in side for laser injection into sphere the outer tube 43 inch in ball 1 inch
can fit the same  tube as the 9 tube cavity case and lids
All posted to public domain 2019
« Reply #33, on April 4th, 2021, 10:06 PM »Last edited on April 4th, 2021, 10:08 PM
Sphere Cell Stanley A Meyer
found with a simple google search
RIP Stan
thanks for leaving this for us all ,
« Reply #34, on June 24th, 2023, 05:32 PM »Last edited on June 24th, 2023, 05:37 PM
sphere cell replication v.1 By Simon Beausoleil
reposted here for study
here is a replication of Stan Meyer's spherical resonant cavity.
outer sphere is 3 inch diameter 11ga 304l stainless steel, inner sphere is a 1inch 304l solid ball.
a centering jig was 3d printed to use the pre-drilled hole in the outer sphere as a reference point to drill the other hole.
