11 tube WFC Stan Meyers Plans Size Dimensions Water Fuel Cell
Re: 11 tube WFC Stan Meyers Plans Size Dimensions Water Fuel Cell
« Reply #25,  »Last edited
Now post 8 inch 16 inch 18 inch versions with nano bubble tips
« Reply #26,  »
18 in Stan Meyers 11 Cell  Water is Fuel drawings coming Open Source Join in Build your Cell
« Reply #27,  »Last edited
HI Every One here are the design files 11 cell multiple sizes
this means longer tube less voltage needed
Also note the nano water dissolving tips
Size in this Zip 4 inch 8 inch 16 inch 18 inch  11 cells
Put a Led Ultra Sonic Pond fog mist unit in side cell to replace the 11th cell cavitator
If you have a chance please help me find parts for the 8xa project box I need links to volt amp gauges lights toggle switch rotary switch please post there link on mouser or other
GOD SPEED
patrick1
« Reply #28,  »
i will send you that stuff.  i have spares of all that, but it is from ali express. so mabee not the best quality,  but perfectly acceptable for testing.
well i should check first,  what specifically do you need in terms of gauges ?. - and the only rotary knobs i have are for resistor box's,  so 10pole mostly.-     and low wattage cavitators,  --  anyhoo, if you need in a hurry let me know, i can express it ;-)
« Reply #29,  »
Quote from patrick1 on March 3rd, 12:58 AM
HI Patrick1
here is thread, I have the boxes and variacs here
need part number or mouser/digikey links
 for close as possible matches  of these
On off switch
Square red led
Analogue volt meter  0- 150 volt
Analogue amp meter  0 -100 amp
2 position rotary switch
4 position rotary switch
1 round led red chrome seat.
« Reply #30,  »
please post to that thread or pm and I do ,
need to work on this to post these simple parts here
These little parts were used make 10xa 8xa / 9xb 9xa boxes.
« Reply #31,  »Last edited
 Nano Bubble Version
« Reply #32,  »Last edited
hms
Dan, Thanks for sharing some really good drawings. Have you got a price quote to make an 11 cell resonant cavity exactly to Stan's spec?
re prices we are doing individual parts proto type in various sizes we will bulk buy each part  to mass produce in flat  and round 11 cell config
the proto type parts are  between 80 and 100 each  but once done we can make 1 to 50 each
THERE ARE SOME FUN ADVANCES BY DOING IT THIS WAY WE CAN use the release valve on different assemblies
 and tubes in  different config or lay out  and test different caps .
I am making the valve internal delrin so not to pick up charge  I can make it stainless but making delrin
DAN
« Reply #33,  »
this part in 16 inch and 18 inch to 20 inch is rather interesting to drill
the anode and cathode will be machined
any idea on cutting in half  the delrin case for first run can we bond or re joint 2 halve with acrylic panel  fastner ?
patrick1
« Reply #34,  »
hi guys, as you probably know, cody posted a video last night about home production of activated carbon, you should watch !
https://www.youtube.com/watch?v=GNKeps6pIao
includes a facinating burn of the gas's put off by the carbon. and mixed with steam.   its like nasa levels of coolness.
« Reply #35,  »
God work in Mysterious ways , every thing happens for a reason,
You posted this carbon , link I have carbon ceramic tips on cells , we need to ask cody of he can make 60% ceramic 40% carbon porous
block billets  for making nano bubbles we need 2 inch by 1 inch blocks  same as Japanese are making
it would be a very popular video and get millions of hits Ask him please to do this
as every thing happens for a reason
patrick1
« Reply #36,  »
god also rewards those with patience.  im also very glad too be part of this endevour, -
however as it stands, i have no idea about the theoretic gas concentrations i should be aiming for with my generator, -
i have 4 hho cells, - about 15kgs worth of 1mm thick ss... a bunch of water misters ... some fresh brewed alcohol, and a single fuel injector powered by a 555 ;-D.......  but considering there is only 0.1% carbon dioxide, - it wont make much difference, - but could make all the difference in the world if you are using 10% woodgas / methane etc.  - mabee even booze ;-D... il have too look into that one ,  apparently you can get booze power cells aswell (instead of hydrogen)
« Reply #37,  »
Switch to tubes and make 3.75 times the gas increase length of tubes to lower the voltage
required put nano tips on tubes to make nano water fuel
Be aware of the 7 deadly Sins
patrick1
« Reply #38,  »
cheers, actaully yes the best of my cells is a tube cell. however 25cns long round cells x7 . 1mm spacing with tapped threaded nylon rod.  ...  ..quite a contrast too some peoples sewing thimble style round cells.
btw how does the  ceramic tip affect the gas coming off ?
« Reply #39,  »
it make nano bubbles and makes water fuel
patrick1
« Reply #40,  »
cool, who wouldnt want a ceramic tip anyway
