Stanley Meyer and Invisible Micro Nano Bubbles
«  »Last edited
It has Become Apparent that the Right Frequency and right Ph and Water Temp and Purity will
Propagate Micro nano bubbles right into solution and keep them there for up to 2 years and create a water fuel .
There are some techniques and accessories that are becoming available to aid this process.
We Can thank all the Builders and scientists for constantly publishing researching and sharing what they found and had hunches on.
The List is Long Immediate list include
Mr Anzai Kantetsu Nano Bubbles
Moray king for he micro cluster nano bubble works
Joe Cell on his polarity charge of gas and water works.
and countless others in the thousand of home builder levels. it would not be fair to mention names and list is way long
Needless to say it is global at this point
Attached are some new slide specific to this topic understanding  and study on Stanley Meyers Water Fuel.
Stanley Meyer
Mentioned as Brettly Pointed out IN the Environmental Tape 3
position 2.08  " we even have more advanced technology than
that, we can purify this water without converting to gas"
I hoe you find it interesting enough to get up off you chair and do a little water fuel dance.
Builders are working hard and more support info being found and made the good news is there is tons of
science and data now on these items reflected in the attached slides.
Summary
is no matter the method of releasing or making h2 whether Stan's Voltrolysis extremely efficient and now proven.
or just nano bubbling positive charged hho h1 h2 or electron removed gas into ddh20 water during cavitation or resonance vibration
you can reprogram the water and gasses held in it,
if it is cold and ddh20 double distilled or even distilled.
 if positive charged
it will gather the nano bubbles into micro clusters and hold them there in solution
 and the ph will rise along with the held charge as a capcitor does.
 Making what science is yet to realize a stronger surface charge with out salts or electrolytes or contaminates.
pure water with positive charge and high surface tension. Holy water ? seams so. it is already being used in medecine and cures
and to reverse addictions with out brain acidosis  also .
This Fuel Mix which we can meter mix with o1 o2 or other non combustible gases can stay in solution for up to 2 years and be used as a inject able fuel as Ohmasa showed and proved running a engine.
Merry Christmas and Happy New Year 2019    2020 is water fuel Year
Re: Stanley Meyer and Invisible Micro Nano Bubbles
« Reply #1,  »
Further insight
If you can La ice Water with Nano Bubbles increasing surface tension
using charges of +coarse and avoid grounding to help gas dissolved or suspended for up to 2 years
you can Lattice a gas the same way positive charged with out grounding
Stan Was a Smart Man
