Stanley Meyer WFC Dublin University Technology Report
Re: Stanley Meyer WFC Dublin University Technology Report
« Reply #1,  »
Dan,
Watch evostar's latest video and think about a few things he said.  We associate current with a magnetic field, but what if the dielectric transformation happens so quickly, no magnetic field forms?  No field, no current.
Could it be possible Stanley's VIC actually traps and slows down the generation of the magnetic field to a point where the pulse doesn't need to happen very fast at all to get the same effect.  What I'm saying is, maybe we have been looking at this water fuel technology from the wrong perspective.  Maybe we need to view this as a device that doesn't "restrict amps", but instead eliminates the generation of a magnetic field.
What say you?
« Reply #2,  »
I feel that the is a surface tension build up on the dielectric field surface of tube
This surface is unique in the cell, as the h1 h1 keep adding to it
also the water tension increases and more nano bubbles of h1 h2 enter water. the over all charge of the cell is pretty impressive.
As this occurs I feel that the angle of the water contained in the cell changes and it is able to hold more dissolved gas, micro clusters
we know some of the things occuring from the Dublin report. the over all charges change, the water pure water becomes very pure
very dielectric and no conductive
So what are we doing? well based on the gating and knowledge from Petkov Pularich and Stan , we are trying very hard
to use pure water add h1 h2 increase tension with out conductivity and with out dead short,with out amp draw we avoid it and change up cell
 until such time the
surface build up and tensions and charge build up rips water apart the better the dielectric hold capacity the less we allow it to ground back to stable the better ,  avoiding contact with air plays a part,  keeping surface positive earthed plays a part,
extract electrons plays a part.
We know Nature is seeking to give back electrons ground the positives and stop the effect if we work in between the natural balance isolate the abient air isolate the negative earth we should see stable dieelectric voltages and build up , materials and choice of dielectric barrier play a role.
there is alot going on and those skilled in ther art and yes we have some after 20 years, know all the areas to consider it is simple but complex to get right and goals right,  only just now do we seel resonance occuring from petkov.
« Reply #3,  »
FOR THOSE WHO HAVE SKILLS
 Voltrolysis
An Explanation For those who want to know
Electrolysis
 In chemistry and manufacturing, electrolysis is a technique that uses a direct electric current (DC) to drive an otherwise non-spontaneous chemical reaction. Electrolysis is commercially important  as a stage in the separation of elements from naturally occurring sources such as ores using an electrolytic cell. Very Different from Voltrolysis cell Electrolysis uses a variety of salts electrolyte to cause a dielectric breakdown and high amp draw to disassociate chemical bonds creating a exothermic heat in the process.
Voltrolysis
by Stanley Meyer In Chemistry and Ionization and Disassociation of Gas is a technique Using no Electrolyte and uses a a Indirect Voltage Source a Voltage Plasma Field Based on a DC to Cause the Ionic Dissociation
of Chemical Bonds in Liquids and Gas Chemistry. The primary coil is electrically isolated (no electrical connection between primary and secondary coil) to form Voltage Intensifier Circuit Voltage amplitude or voltage potential is increased when secondary coil is wrapped with more turns of wire. Isolated electrical ground (J) prevents electron flow from input circuit ground causing a Charge on Cell Plates  and a Volt Based Plasma Field which acts as a Catalyst to dissociate chemical Bonds. Very Different from Electrolytic cells and Not Electrolysis as no electrolyte. A Low Amp high Voltage Solution Similar to how a Fluro Light Works with a  choke/ballast restricting amps Having a Cold Process with little of no Exothermic Reaction heat as no electrolyte no shorting of cell and no grounding the dissolved gases which makes the water a fuel a carrier.?
So Use Volts not amps and BIngo your alot closer
THERMODYNAMICS THE WATER FUEL CELL AND THE FIRST AND SECOND LAWS OF THERMODYNAMICS
The Water Fuel Cell technology encounters a credibility gap because it appears to run counter to the long established laws governing our interpretation of Nature. In fact, the water Fuel Cell is entirely natural.
It merely demonstrates a new and revolutionary way of harnessing what nature has always had on offer. It does not infringe the two main laws of thermodynamics, i.e.:
THE FIRST LAW: "The total energy of a thermodynamic system remains constant although it may be transformed from one form to another." In the case of Water Fuel Cell technology, the system is global. The energy required to drive the engine comes from the zero-point energy contained in the water, a virtually inexhaustible source. The exhaust from the engine is water vapor which returns to the atmosphere.
 THE SECOND LAW: As originally formulated by R. Clausius in 1865, this law states that "The entropy of the World strives towards a maximum". As recently formulated by Prigogine and Stengers, this law "contains
 two fundamental elements: (1) a negative one that expresses the impossibility of certain processes (e.g. heat flowing from a cold to a hot source) and (2) a positive, constructive one. It is the impossibility of
certain processes that permits us to introduce a function, entropy, which increases uniformly and behaves as an attractor for isolated systems". It is at maximum when the system is in equilibrium. Non-equilibrium is the
source of order and brings order out of chaos. Since Water Fuel Cell technology postulates non-equilibrium, it can be said to be supported by the positive element of this Law.
« Reply #4,  »Last edited
So all that out the way
It is possible that surface tension charge can reach a point if designed right to prevent ground back to neutral of cell surface or water or gas that it continues to rip and gather electrons to surface charges and continue this cycle to infinity.
I believe Stan Realized this and saw un believe amounts of power to be tapped so much so he tried to run it through epg. to extract it.
rather the ferrite gathers should be around the actual cell .
Well you asked I answered? may be a bit crazy but lets work on it show some tests
one pic is from a Builder in another forum,
comment on it here
I Like this design Please Consider making the Outter tubes plates from ferrite
 it can suck in and store the electronsWe need to consider meyers design and your
 design, meyer was trying to hold in voltage to the outter tube and may have used
quartz sleves, your way may work to hold voltage , material choice is very important,
 Ferrtie would hold a crap load of voltage if used in your design and could create a
super cap cell which sucks out electronssame as this but we slide it down around the actual
 cell Flacking mind crazy Enjoy, this way you have a insane power source change that galvanized
 tube to stainless steel and use your design as a 11 cell voltrolysis unitover coming the
 voltage reduction by actually increasing it rather than length we do by diameter see this
chart as you reduce length of tube the yeild goes down , meyer raised voltage to compensate,
 we can too with better material and diameter , becareful though it may have to sit in oil
or some thign as voltage is going to be very high 10 kv upso not just gas processor but on the cell its self this way cell can be reduced in size again !change that galvanized tube to stainless steel and use your design as a 11 cell voltrolysis unit
« Reply #5,  »Last edited
Yes it is possible with control and understanding of maintaining it once it hits that state. meaning it is so strong state of magnetisium it is self sustaining so violent in side for the water it cascade constantly. but still from a external input point of view the center of the magnetic storm  is not a good place if your a water molecule.
moves bond angle and changes and cascades, plasmoid nano implosion  rib h2o bonds instantly  yes possible, and I gues pretty dangerous
we know there is alot of power and i guess stan moved away from that to mini injector to avoid some of that power resource over powering him.
it sounds wild and crazy because it is  high technology and methods here.  it is possible that that in balance can continually drawing in electrons to try and re balance but if you understand not to let it I guess you could continually extract them
not sure if that is sucking the life out of what ever is next to it though got to what that. .................
SafeDog
« Reply #6,  »
Securesupplies when do you stop from steal other's work and publish your own?
Next time you publish other's work mention the name or link, stop from collecting data everywhere to monetize it with your stupid site.
You are only scapping money from the others work.
Do something useful AND BY YOUR OWN.
« Reply #7,  »Last edited
Peace and love to you Post some thing to contribute ok  stop trying to sew divisions your about 20 years too late to do that,
We share and protect in every conceivable way and 1000's of people build at home we have all learnt paid and un paid must all be done to get exposure and preserve data please feel free to share and post and contribute and re post aggressively in your  complimenting way .
Do not pollute the air more with your trolling it is a waste of every ones energy including your own.
if you would like to call me + 1 520 848 1659  I will be pleased to discuss with you how you can contribute in a free or getting paid manner , the global force for good is well established on this one you might have more luck at a pre school with your bullying attempts to identify suppress and divide.
2 men who work together can do the work of 100 individual men working on their own
Together as a global industry spread out group with no address or specific individual we all win we all know that as their is no specific individual  to attack it is a global movement of home builders in garages  I am just one of many messengers your right I don't show any thing for a reason it is all a diversion, same as 99% of builders "Hydrogen Hot Rodders" want to remain out of spot light and anonymous except for known friends of friends to which you have credibility of only 30 days every post is a troll post so far from you.
So
Remember God has a purpose for every one I am a messenger ,others do back channel communication and others do gradual  replication and testing all by garage builders building it all and sharing by non traditional communications it  is key even Stan said that , the people are bringing in the technology
We are all adults so I invite your call my phone it is on for you if you feel it is some other way.
Sorry if your upset  move on, The world needs every ones help and clean air, no matter if the climate is hot or cold we still need a end to toxic carbon based fuel emissions and an end to poisonous emissions into air from diesels and badly designed fuel products etc
The Tax base incomes are  the same or even better income from green fuels for local communities and governments and possibly more on h2  fuels , all  cities and countries. All  communities do is change products to clean green ones suggest you do the same at your earliest convenience .
Thousands of People Study Build and Work in Small cells and Teams daily on Stanley Meyers Technologies.
Even I do not know them things just come and go to the forums and other platforms of communication
anonymously. Just as you choose to be anonymous. God Bless
« Reply #8,  »Last edited
The advanced works which parallel the Dublin report   https://youtu.be/lWapc6pkshI
Source from Daniel Secure Supplies
SafeDog
« Reply #9,  »
You make me laugh man.
Considering ev0ery piece of nonsense as klnowledge, every TALKER as a doer...
Nobody till today has replicated SUCESSFULLY Meyer work, you are throwing sand to the newbie's eyes (not for me) and trying to get money to access to all info you got for free, idiot.
« Reply #10,  »Last edited
Yes nothing to gain from me.
I am sure you can find every thing very easily on google or forums
God knows we have invested time for your to do that easily.
If your looking for the fast train to free fuel town
no one is going to hand that ticket over it has been discussed a lot online and as you invest days and days reading and watching what the global community has done you will see why.
Thanks for the input but to be honest we have a lot to do and no time for distraction I hope you cheer up.
I invite those of you scrolling to visit the Secure Supplies website and Secure Supplies youtube to catch up on things that you may have missed.
Links in my Signature below , Water is Fuel and the Hydrogen Hot Rodders Movement has Spread Globally to every home builder..
