Electrolysis Rods
Forum Administrator
Max Hydroxy
RE: Electrolysis Rods
« Reply #1, on August 30th, 2011, 11:19 AM »
 Hey Russ ,
            Ever tried Building a HHO dry Cell with 6inch X 6inch,,30plates  12Volts ,,Na OH electrolyte,,1/2" plexiglass,bolts heat shrink,Rubber Gaskets to compress it all together !! Wondering how long it would take to blow-off at 5-10PsI ...???
Never built a Dry Cell an I need all the Help I can Get !!!
        Regards Max
« Reply #2, on August 30th, 2011, 11:33 AM »
Quote from Max Hydroxy on August 30th, 2011, 11:19 AM
Hey Russ ,
        Regards Max
max,
sounds good!
you say "blow-off"? what do you mean by that?
ill give you any advice i can!
any photos? post here if you do?
cory991
« Reply #3, on May 15th, 2013, 06:28 PM »
Has anyone ever tried using a golf cart controller to power an HHO cell. I ask cause ive seen alot of pwm's rated around 50 amps or less and these pwm controllers are rated for 250 amps plus.
        Thanks
« Reply #4, on May 16th, 2013, 04:40 PM »
Fast Freddy had a brute force cell running on one
« Reply #5, on September 7th, 2013, 02:27 PM »
Quote from securesupplies on May 16th, 2013, 04:40 PM
And his new version is even better.  And get this, I have all the drawings, plus the needed conditioning.
