H Bridge Designs For Switching electron extract,steam resonator and pwm to vic
H Bridge Designs For Switching electron extract , steam resonator and pwm to vic
here we add some versions of h bridge so builds have a easy access to joining parts
We are working
D
Re: H Bridge Designs For Switching electron extract,steam resonator and pwm to vic
« Reply #1,  »
only 1 thing with there H=bridges
all transistors must be matched for beta
so either we go provide  matched pairs or teach people how to match their transistors
Basicly the matching can be done with a multi meter that has a hfe setting for transistors.
You put it in.
The multimeter says how much hfe (or also known as gain)
You match that hfe to the others and go
Even the same transistors can have different gains
here is a video about this I am sure people will comment on these methods https://youtu.be/JLXKffm7VF4
« Reply #2,  »
Doing this will make the h bridge more reliable.
And gives less change of cross conduction (which you don't want at all as it shorts the hell out of your h bridge)
« Reply #3,  »
Attached
« Reply #4,  »Last edited
here you have the bom
but.....
for r1 to r4 we have to select a good 0.2ohms 5 watt resistor.
all 100 ohm resistors are 2watt
all 1k resistors are 1/2 watts
These items Shared by anonymous group of builders.
it is open source
This can drive steam resonator, electron extract and led
if some one would like to post a faster mosfet version please
feel invited so we  make these things
zooom with switch speed etc
ATTACHED V1 H Bridge
DD
« Reply #5,  »
Version 2 Now done
with screen front back to help with bom speed
« Reply #7,  »
Petlov did this one
« Reply #8,  »
