Extracting and Regulating Voltage from Water Fuel Cell and Gas Gun?
«  »Last edited
Can we
Extract and Regulate electrons Voltage from Water Fuel Cell  and Gas Gun to power a Load?
Reason
I know we can Get  1 Femto second and Picsecond  autocorrelators
 and switch boards for fast switching Light emitting diodes.
this is  something we know is around  new used or parts they exist .
The faster we switch led the better nm ranges we cover and bands we can knock electrons from
In Stan Meyers Design
We have a requirement for at least 2 led driver
switches like these the mosfed switch is like slow motion  light band may be right but it is far to slow of a scr.
If we have a way to extract and regulate power load from the electrons from hho cells this would help people test alot more use of leds and electron extraction from cells.
1 circuit is needed for the cell  water bath in stans design he had it as a load,
my question is how to  control or tap that power correctly from cell if cell is a capacitor with lets say 1000 volts how do we ground with out effecting the cell that into a 12 volt 24 voltage type circuit
 to power the autocorrelator    is it a voltage regulator which type linear ? I hope this spark some interest to slove this parts of stand puzzel and advance it ,
what would such a circuit look like ,
other 1 is
 for the Gas Processor
  I guess it may be easier or same just connect to power we have and or use same as above extracting from the  extracted electrons into a cap
a simple circuit to put out electrons
from cell and put it to a cap and voltage reg behind a diode?
Can you help on this?
I think it is some thing every person should try so I post it here
BUT  we want to connect them to the Out put from the electron extraction grids or extra anode
Re: Extracting and Regulating Voltage from Water Fuel Cell and Gas Gun?
« Reply #1,  »
max made one but it is not running from cell and the flash rate too slow
for achieving what we need
so we  should  prep the power to run a better picosecond driver
https://www.youtube.com/watch?time_continue=7&v=x4ZhhbkAlV8
« Reply #2,  »
need a simple but very fast opto switch board  separate stand alone circuit
and than a  power board that gather electrons and regulates them to power  led driver and pulse (super fast pico femtosecond)
« Reply #4,  »Last edited
Super Fast High Voltage Switch
« Reply #6,  »
upto  3 mhz  mosfet cooled for electron extraction ? on WFC
