roberto handwerker
roberto handwerker
Roberto Handwerker is an italian from Milano who also (konstantin Meyl also) has worked out the longitudinal tesla energy.
in this pdf he has some experiments reproducing tesla's claims.
he also has the mathematical fundaments for it.
 DELTA Ingegneria - Longitudinal dielectric waves.pdf - 439.34 kB, downloaded 18 times.
Re: roberto handwerker
« Reply #2,  »
thank Namira thats an informative link!
« Reply #4,  »
muy bien gracias namira
that document has a lot of info.
pi/2 as the factor between transvers resonant frequency and longitudinal resonant frequency seems to work for unifilar pancake coils.
but for a bifilar pancake coil its different. why?
« Reply #5,  »
also the presure wave felt by hand from a light bulb and at the same time metal attrection?
these effects are so important to investigate.
but it all requires high voltage.
beautifull to see the spargap can be replaced with a vacuum tube (and extra ring)
« Reply #6,  »Last edited
Quote from evostars on June 6th, 2017, 11:59 AM
Arcs change shape in my vacuum! RIP Tesla Coil :(
https://www.youtube.com/watch?v=WM25pUsrODk
Horror vacui
The term is also used as an analogy to the Aristotelian idea that a physical vacuum is impossible, and therefore the idea must be rejected. This was widely believed up to the time of Rene Descartes.
https://en.wikipedia.org/wiki/Horror_vacui
You could say that the global Industrial Revolution arose because of a 'vacuum motor', because all the early steam engines, especially the pioneering Boulton and Watt engines, operated with almost atmospheric pressure steam.
https://en.wikipedia.org/wiki/Vacuum_engine
The physical constant ε0, commonly called the vacuum permittivity, permittivity of free space or electric constant, is an ideal, (baseline) physical constant, which is the value of the absolute dielectric permittivity of classical vacuum.
https://en.wikipedia.org/wiki/Vacuum_permittivity
In times long past they used to speak of the horror vacui — fear of the void. They meant something quite objective. They meant that space itself always wants to be filled with something. An empty space cannot really be created; Nature has a kind of horror of the void. This belief in the horror vacui first had to disappear from humanity; it had to be possible to create a space in which the air is rarefied, — a space approximately empty. Only then could one proceed with the practical construction of steam-engines. The air had to be eliminated from certain spaces.
Whereas Jehovah pours into man through the warmth, man drives Jehovah away when he creates a space where the air is rarefied. Hence, when the steam-engine is constructed in this way, Ahriman gains the possibility of establishing himself as a demonic being, even in the physical. When we build steam-engines, we provide the opportunity for the incarnation of demons. We need not believe in them if we do not want to; but then we are negatively superstitious. Positive superstition is to see spirits where there are none — negative superstition is to deny them where they are. In the steam-engine, Ahrimanic demons are actually brought to the point of physical embodiment. That is to say, while the cosmos descended with its spiritual content through that which was poured into human evolution, the spirit of the cosmos is driven away with this creation of demons. In other words, the great and admirable progress of modern time has not only brought us a demonology but a demonomagic. Modern technical industry is in many respects demonomagic.
Think now of what I recently told you, what will happen in the future (for it is only now in the initial stages): how by the summation of delicate vibrations great effects will be brought about. On Earth, thank Heaven, this is not yet achieved! Yet this is a beginning. The movement of the Sun and Planets is here imitated. Do you imagine — considering how great is the significance for the Earth of the Sun-and-Planetary movement as it rays down on to the Earth — do you imagine, when we imitate it here on a small scale and let it ray out again into the cosmic spaces, that it is of no significance? It is of very great significance for the cosmos. Here you can see at once: even the vibrations are given to the demon, whereby he may unfold his activity out into the cosmic spaces.
No one can sensibly imagine that this is meant to imply that the steam-engine should be abolished. Many things would then have to be abolished, for the steam-engine is by no means the most demonic. Wherever electricity is applied, and many another thing beside, there is far more of demonomagic; for there we are dealing with many other forces which have still more significance for the cosmos. Needless to say, anyone who understands Spiritual Science will realise that these things are not meant to be abolished. We cannot be reactionary or conservative in the sense of resisting progress. In deed and in truth, this demonomagic is progress, and the Earth will yet undergo more and more of such advances. Man will succeed in unfolding mighty effects into the cosmic spaces. It is not a question of abolition — not even of hostile criticism — for it goes without saying, these things are justified. Yet, if on the one hand these things must emerge in the progress of mankind, it is indeed a question on the other hand of our creating counter-forces to bring about the necessary balance. Compensating forces must be created, and that can only be when humanity understands once more the principle of Christ and finds the way to Christ. For a short space of time mankind has been led away from Christ. Even those who call themselves officially His representatives look only for an Angel in the place of. Christ. But we shall have to find the way of the soul to Christ Himself. For just as with the demons of our machines we work out into the cosmos, even to the physical stars, so must we find the way of the Spirit, out into those worlds where man is between death and a new birth and where the Beings of the Hierarchies are living. What I am now hinting at is connected with what I explained before. I told you on the one hand how men are entering more and more into the karma of their vocations, such as I described it, and how from the other side this karma must be met by that understanding of the Spiritual World which can in turn prepare our finding of a way to Christ Himself.
http://wn.rsarchive.org/Lectures/19161126p01.html
« Reply #7,  »
that video is hilarious. thanks again for sharing.
Apoc4lypse
« Reply #8,  »
I am intrigued by the effects a vacuum has on energy...
« Reply #9,  »
i would love to make a sparkgap in vacuum.
use a glass tube with tungsunrods suck it vacuum and melt the glass to seal it.
« Reply #10,  »Last edited
YES! TESLA Secrets of wireless & efficient high-power transmission are soon to be revealed
https://www.youtube.com/watch?v=Ujti8Xofkwg
Tesla’s first brush with time travel came in March 1895. A reporter for the New York Herald wrote on March 13 that he came across the inventor in a small café, looking shaken after being hit by 3.5 million volts,
"I am afraid," said Tesla, "that you won’t find me a pleasant companion tonight. The fact is I was almost killed today. The spark jumped three feet through the air and struck me here on the right shoulder. If my assistant had not turned off the current instantly in might have been the end of me."
Tesla, on contact with the resonating electromagnetic charge, found himself outside his time-frame reference. He reported that he could see the immediate past, present and future, all at once. But he was paralyzed within the electromagnetic field, unable to help himself. His assistant, by turning off the current, released Tesla before any permanent damage was done. A repeat of this very incident would occur years later during the Philadelphia Experiment. Unfortunately, the sailors involved were left outside their time-frame reference for too long with disastrous results.
http://www.bibliotecapleyades.net/ciencia/time_travel/esp_ciencia_timetravel11.htm
1922 Tesla's favorite pigeon dies. Tesla said a light came from her eyes more intense than he had ever produced by the most powerful lamps in his laboratory. The bird then died and Tesla said that at that same moment, something went out of his life and he knew his life's work was finished.
The 216 Golden Rectangle - A Solution to Tesla's 3 6 9?
http://grahamhancock.com/phorum/read.php?1,336811,336811
https://www.youtube.com/watch?v=lr35MxdTTZ4
369 What did Nikola Tesla mean about the numbers 3, 6 and 9? Are those numbers involved in some sort of mystical universal code? SOURCE CODE is REVEALED... Many people just ignore that statement made by Tesla, saying it is just some random thing he said due to him being “Insane”. Nikola Tesla was not insane, he was just a genius, which made him seem insane. These things he was talking about were so complex and incomprehensible, that it made it seem he was insane to the average person. But the fact is he was even more than a genius. There is even some speculation into whether or not he was even human, due to the complexity of his thoughts, inventions, behavior and mannerisms. Why, it was said he was inhumanly obsessed to the number three. For a good reason though. The man was so incredible he could like up light bulbs, wireless from over 20 miles away, over 100 years ago! A feat man can still not reproduce! I think he was able to do this because he worked with the universe, not against it. He figured out a pattern that if you were to work with it, you could do anything. Just like swimming in a river, if you go against it you probably will move slowly if not at all or even backwards. If you swim with it, it is as if you are not swimming at all. There is most likely pathways throughout everywhere like this, where you can send energy from place to place with ease. So why are we not looking more into this whole 3, 6 and 9 thing that Tesla was talking about? Well, I think it is because people don’t want us too. The elitists want us to be restricted to living in this false reality, and not to excel to the next level in the universe. Still, there are some people out there who are interested in the whole thing. They are just not well known. Here is a website which shows some incredible research into these numbers, by another genius, Marko Rodin. If you go to that site and read it over and let it sink in a bit, what you read on from now will make much more sense.
https://www.youtube.com/user/MarkoRodin?sub_confirmation=1
So, if you had a look at that site, and got an understanding of the whole thing, you will have a look into the importance of the numbers 3, 6 and 9.
Vortex-Based Mathematics
http://www.rexresearch.com/rodin/rodin.htm
Quantum Gravity Research: 3D Printing the Substructure of Spacetime
http://open-source-energy.org/?topic=2972.msg44140#msg44140
Spark gap designs for Tesla coils
https://www.youtube.com/watch?v=av3bfn1c5jY
« Reply #11,  »Last edited
Joule-lenz law
https://www.youtube.com/watch?v=ZuJjy9wj9vU
Negative Resistance Revisited
https://www.youtube.com/watch?v=JWD0Wy_UOEA
http://overunity.com/6123/joule-thief/7275/#.WTvKBNSLTGh
TESLA PANCAKE"UPDATE"
https://www.youtube.com/watch?v=B-CwRAsUDQE
...https://www.youtube.com/watch?v=UPeONJpsuc0
http://www.gabitos.com/DESENMASCARANDO_LAS_FALSAS_DOCTRINAS/template.php?nm=1476541375
37 PRIME 12
73 PRIME 21
12 so above so below 21
The Secret of the Universe
http://www.code144.com/news/the-secret-of-the-universe-slides
The Hamel Free Energy Generator
http://jnaudin.free.fr/html/hfrnrgen.htm
The Square, the Circle and the Golden Proportion:
A New Class of Geometrical Constructions
Janusz KAPUSTA
http://www.scipress.org/journals/forma/pdf/1904/19040293.pdf
A “magnetic field superimposed upon radial lines of force”
was shown in crops near Cambridge during the summer of 2001
http://www.cropcircleconnector.com/anasazi/fringe2012a.html
Marcel Duchamp, Rotorelief, 1935.
https://www.youtube.com/watch?v=wMoYEQFhQoc
Magnetic Vortex Spin Demonstration
Little Knoll, Nr Maiden Bradley, Wiltshire. Reported 9th June.
http://www.cropcircleconnector.com/2017/littleknoll/littleknoll2017a.html
UNIc UrS ALL
http://fiaof.forumandco.com/t51-babalon-project-unicursal-ararita
ChRist
Janusz Kapusta
RODIN COIL
https://www.google.nl/search?q=rodin+coil
« Reply #14,  »
that video of tinselkoala is an excelent example why we need to experiment.
because it can amaze us with new findings.
our minds cant come up with realistic findings.
the mind is based on the facts it nows.
an experiment can suprise us and then we can use our minds to understand it.
if we let the intuition of our wise hearts guide us, reality can suprise our minds in believing there is more to explore and understand.
« Reply #15,  »
man i dont get that... i posted a comment and then the answer was i think you are wrong.
thats it? you dont have a statement or explanation?
just saying "wrong"? man...
ive heard it so much.
I dont mind being wrong. but please enlighten me
with your deep truth of your perception of reality.
wrong...
it wrong to say wrong without the reason why you think its wrong.
I think saying wrong without the deep wisdom is like
saying we all agreed on this so you have to agree to.
follow the leader
dont think for yourself
be a good slave
forget it
it cant
stop
Wrong...
pfff
