GRAM gravity assisted pulse motor project
GoGravity17
https://youtu.be/jKIWcJiJs04
https://youtu.be/IOdulvy8M7A
https://youtu.be/wBnVWRb1fIA
https://youtu.be/B3dLzZZ5jKQ
Greeting, I am attempting to combined a pulse motor to drive a unbalance wheel that will drive a PMA. If I can get about 300 watts of mechanical power at the output drive shaft then I should be able to generate about 10 amps at 12 volt from the PMA using a Buck converter.
I just started to modify the pulse motor to a rotary gap configuration. I will post results when available.
Cycle
Re: GRAM gravity assisted pulse motor project
« Reply #1,  »Last edited by Cycle
Let's see if I can reverse-engineer your idea. It entails small magnets in a sliding configuration within heads mounted to the ends of arms on an unbalanced wheel. At one side of the machine, a pulse magnet would push those sliding magnets inward, where they would be stuck to a small piece of metal and thus not move against the centrifugal force attempting to fling them outward, and at the other side of the machine, a permanent magnet would pull those sliding magnets outward, where they would be held by centrifugal force.
The physical difference in distance from the center of the wheel of those sliding magnets on each side of the wheel would mean a weight imbalance, causing the wheel to turn, creating a "relay" effect whereby a small input triggers a larger output.
Is that the general idea? If so, here's a few ideas...
1) Put your pulse magnet and permanent magnet at the top and bottom of the wheel to maximize the force imbalance.
2) A joule thief / energy recovery circuit (operating at the resonant frequency equivalent to the wheel RPM times the number of arms), in order to recover that collapsing magnetic field of the pulse magnet and reuse it.
3) Use that centrifugal force! It's attempting to fling the magnets in the arm assemblies outward, so switch your pulse magnet to a "pull" configuration. It'll take less energy to pull them outward with centrifugal force helping than it would to push them inward against that centrifugal force. Let the PM do the work of pushing them back inward.
4) MuMetal shielding around the PM on its approaching side. This will constrict the magnetic field to a narrow band which has an effect only after the arm assembly has approached, lessening the "push-away" effect between the PM and the approaching magnets in the arm assemblies.
5) A conical pulse coil to concentrate magnetic flux.
6) Flux "switching"... check out:
https://www.kjmagnetics.com/blog.asp?p=magswitch
https://www.youtube.com/watch?v=E6idrAEO6W0
https://www.google.com/patents/US20120133466
http://www.cheniere.org/misc/astroboots.htm
https://www.youtube.com/watch?v=Z_UHixEy7xU
If you can rig up a permanent magnet which does most of the 'push/pull' work, and a much smaller coil which merely switches the magnetic flux between two routes (one route is the PM doing work against your wheel, the other route is a magnetic flux 'short circuit'), you could use a much smaller pulse magnet and get a much larger amount of work done on the wheel.
GoGravity17
« Reply #3,  »
https://youtu.be/Zuk9YXycUYQ
The main rotor still requires some more modifications but showing signs of improvement.
« Reply #4,  »
https://youtu.be/SUDzFv_hURA
Making progress. 1 to 9 gear train with PMA mounted.
« Reply #5,  »
A few may already know about these, but for those who don't, here's a nice selection of stators to couple with the permanent magnet rotor:
http://www.windbluepower.com/category_s/27.htm
They are all standard 3-phase outputs.  Supposedly this design is low cogging which will help quite a bit when starting the device.
Project is coming along nicely.  Looking forward to your video when this design appears to accelerate on its own.  Keep a switchable load handy nearby that generator, because it may be the only way you can slow that gizmo down.  :-)
« Reply #6,  »
You may have seen hundreds of these types of devices, but they are interesting to muse over and contemplate:
https://www.youtube.com/watch?v=957CkR7JWYI
Who knows, maybe an idea will spring forth...
GoGravity17
« Reply #7,  »Last edited
https://youtu.be/HSOTGpZVSLk
hi, thanks for the info. maxblue still requires a high rpm.
this is  the second multi stator PMA I made but it requires a custom buck converter with a high voc.
https://youtu.be/4u_QWesfYdA
Apoc4lypse
« Reply #8,  »
One thing I've always wondered is it possible to use gravity to temporarily "store" energy that can then be stepped up using a gear system to help move a gravity based system along.
GoGravity17
« Reply #9,  »Last edited
Hi, I do not know. I am thinking if I can get 300 watts of mechanical power at the output shaft then I can generate 10 amps at 12 volts of electricity. The gear train steals a lot of power as the RPM is increased. The other problem is having a PMA that will produce a lot power at a low RPM. It is looking like I will have to fabricate a PMA with multiple stators and rotors. I should know more in a few days.
. https://youtu.be/gdnsGDhNH4w
early testing of multi stator and rotor PMA.
I can just add more stators and rotors until I get the desired electrical output. It will take some time to fabricate and mag-wire is ordered:)
« Reply #10,  »
https://youtu.be/CEyiflP9U74
another option, the weights shift on the rotor. Start watching at about 2:05.
« Reply #11,  »
https://youtu.be/UlGjr2VBxR0
linear pulse motor fabricated
« Reply #12,  »
https://youtu.be/-Vi4w97YiqE
proceeding to fabricate large pendulum drive and I will use the MPMM to drive the the pendulum
Apoc4lypse
« Reply #13,  »
I love the idea of using the ocean to generate power with the pendulum, I think the ocean could be tapped for so much energy.
GoGravity17
« Reply #14,  »
https://youtu.be/eLq94TdoqxE
Hi, I may have found a better way to drive the project.
« Reply #15,  »
Not sure what I'm seeing here, but the old guys seems convinced he has something.
GoGravity17
« Reply #16,  »
https://youtu.be/A0mCfgsbECo
hi, just quick update
« Reply #17,  »
https://youtu.be/IU8ehKZHRMA
Quote from Matt Watts on July 6th, 2017, 11:54 AM
I will it to push the main rotor.
« Reply #18,  »
https://youtu.be/U_q28sfn-NM
hoping other builders will give it a try
« Reply #23,  »
« Reply #24,  »
Very nice work and I agree, you look to be on the right track.
Keep the posts coming.  Always fun to watch all those pieces/parts come together into some kind of device that we can all learn from.
