Stans VIC finally reverse engineered and ready to build.
gpssonar
Re: Stans VIC finally reverse engineered and ready to build.
« Reply #50, on December 5th, 2015, 06:42 AM »Last edited on December 5th, 2015, 06:49 AM
Here are several references from the TECH BRIEF and their is many many more from other documents of the Re of water. Re is used in all his formulas to get the total Z impedance. So how can you not use the Re that he gives us to calculate the Z? Reference shows that the Re of the water is a dielectric constant of 78.54 and also shows it in ohms.
nav
« Reply #51, on December 5th, 2015, 06:58 AM »Last edited on December 5th, 2015, 07:01 AM
Take note of the opposite windings on the lower schematic, when differential mode current passes through this core, it cancels the magnetic flux fields. The reference to 78 Ohms is the resistive value that water presents when trying to pass current @ 5Khz and is no reference to self resonance @ 10Khz.
« Reply #52, on December 5th, 2015, 07:26 AM »
Quote from nav on December 5th, 2015, 05:54 AM
The mathematics work perfectly in those charts. From those charts I have worked out that the inductive reactance @ 10Khz needs to be 1.02 million Ohms. It's capacitive reactance is 15.6pf
1. Flat plates: @10Khz
If you have a flat plate 24.2 x 24.2 mm2, a gap of 1mm its inductive reactance is 1.02 million Ohms @ 15.6pf in the plates.
2, Tubes: @10Khz
If you have a pair of tubes 16 inches long then you have 29,450mm2 of surface area per tube set, a gap of 5mm, and 156.6 pf per tube set. This is devided by 10 in a series calculation of 10 tube sets and is 15.6pf and 1.02 million ohms for the entire tube set.
The maths is perfect if you know what you're looking at. If you don't know what your looking at none of it will make sense and you won't be able to scale any of it down to a spark plug sized cell.
Found this online calculator, http://www.daycounter.com/Calculators/Plate-Capacitor-Calculator.phtml
If you enter area 24.2, distance 1 and dielectric constant 73 you'll end up with 15.6 pF, would that be a ball park estimate?
Ris
« Reply #53, on December 5th, 2015, 07:46 AM »
2, Tubes: @10Khz
and that is a problem  You have derive data from Ohm readings     you need to pull data out of something solid such as induction      but I must say you are good you are sharpening my brain.
gpssonar
« Reply #54, on December 5th, 2015, 08:01 AM »Last edited on December 5th, 2015, 08:36 AM
What is the Total Z of this circuit using Stan's formulas? You can work out the Z value of the L1 and L2 along with the capacitance value from the chart below and the formulas from the Tech Brief  Eq 1,8,9. This will be with air core values. I would like to see everyone's answer, this could show how everyone has a different answer. Also notice where the #(10) shows up.
resonance1
« Reply #55, on December 5th, 2015, 08:33 AM »
Thank you gpssonar,
I don't agree that distilled water has a resistive value of 78ohms, that's its dielectric constant, pure distilled water is an insulator with very high ohmic value,
you showed me where the ohmic value for distilled water came from, been scratching my head about that for a while, its much appreciated that you cleared that up.
The reason I cannot use 78ohms resistance in place of a dielectric constant of 78 is dielectric constant and its resultant ability to hold charge is not an ohmic value, it makes no sense to me at this time,
capacitors don't have resistive values they have capacitive reactance values @ a given frequency which is derived from their capacitance calculated from plate area and spacing plus the dielectric constant of the dielectric between them,
the paper only makes sense if you remove ohms from the 78 so I'm lost unless somebody can explain this new law of physics.
Thanks again.
nav
« Reply #56, on December 5th, 2015, 08:36 AM »
Quote from Lynx on December 5th, 2015, 07:26 AM
No the plate area is 24.2x24.2 which is 587mm2 plate area. I never mentioned dielectric values. The dielectric value is for You to decide to get 15.6pf.
« Reply #57, on December 5th, 2015, 08:38 AM »
Quote from resonance1 on December 5th, 2015, 08:33 AM
Thank you gpssonar,
Thanks again.
Because the circuit has two values, one @ resonance which is capacitive and one @ none resonance which is resistive.
resonance1
« Reply #58, on December 5th, 2015, 08:44 AM »Last edited on December 5th, 2015, 08:53 AM
Quote from nav on December 5th, 2015, 08:38 AM
Thanks nav, that makes perfect sense, capacitors have a very high resistive value in ohms but a much lower reactive value also expressed in ohms @ a given frequency such as 5 or 10khz depending on their capacitive value,
not only that but the dielectric constant and resultant capacitive value changes drastically when gas production starts so using 78ohms is a none starter for me,
im always happy to be shown the error in my thinking
Ris
« Reply #59, on December 5th, 2015, 08:52 AM »
total Z =230+785      I would add an additional 10 for the primary
gpssonar
« Reply #60, on December 5th, 2015, 09:00 AM »Last edited on December 5th, 2015, 09:30 AM
Allan(Rav) and I fumbled with the dielectric constant of the water being 78.54 ohms the same way most people are doing also when we were doing our own research on it. I showed references in the post above and like i said they are many more in other documents of his. You can only can come to a conclusion he is not telling the truth, or people don't yet understand how he comes up with it being 78.54 ohms.
« Reply #61, on December 5th, 2015, 09:27 AM »
Quote from nav on December 5th, 2015, 08:36 AM
Alrighty then, using the same online calculator with 587 mm2, 1mm spacing and a dielectric constant of 3 gives me 15.6 pF and such a dielectric constant isn't found in either water or air, so I guess that online calculator doesn't quite cut it in this case.
But thanks anyway.
gpssonar
« Reply #62, on December 5th, 2015, 09:32 AM »Last edited on December 5th, 2015, 10:01 AM
Good number for hydrogen and oxygen as the dielectric, I would think.
resonance1
« Reply #63, on December 5th, 2015, 09:51 AM »
I don't think Stan is telling lies at this point but likely misusing the term ohms as a dielectric constant,
it seems obvious that when the cell is producing lots of gas the dielectric value will be much lower than when the cell is only full of water, Stan tells us it changes with gas production in his talk but not in which direction it changes,
I could be wrong but that's how it looks to me.
nav
« Reply #64, on December 5th, 2015, 09:56 AM »
Quote from Lynx on December 5th, 2015, 09:27 AM
But thanks anyway.
3 sounds an excellent number lynx for water that has turned to hydrogen and oxygen :P
gpssonar
« Reply #65, on December 5th, 2015, 10:02 AM »Last edited on December 5th, 2015, 10:17 AM
Quote from resonance1 on December 5th, 2015, 09:51 AM
Good post.  Guy's I am going to throw this out there to you all for what's it worth. Water is not going to be the dielectric in the cell forever. And It looks like a couple of you are catching on now. My deed is done.
« Reply #66, on December 5th, 2015, 10:05 AM »Last edited on December 5th, 2015, 10:09 AM
Quote from nav on December 5th, 2015, 09:56 AM
Good post also Nav, I stated this above your post. If you remember me saying, there is nothing that is of fixed value in the VIC or the CELL.
« Reply #67, on December 5th, 2015, 10:19 AM »
Well, how about that?
Many thanks Gentlemen, clears up atleast one question :thumbsup:
gpssonar
« Reply #68, on December 5th, 2015, 10:30 AM »Last edited on December 5th, 2015, 06:58 PM
Thought it would Lynx.... Took several days to get to this point. Just goes to show how much people still don't understand. I know to most people they think I am blowing smoke up peoples A#$ too. I may not explain things to well, but some of it is due to my promise that i made and I just can't come right out and say the things that needs to be said. But I can use public information that is already in the hands of people to help them. Nothing that I know is any secrete to anyone it's all out there for the person seeking to find it and put it all together. I stated in an above post that someone was saying it's all about Ohms Law. Ohms Law is good for a fixed target it will give you the result. But when you have a moving target like the dielectric, frequency and ect. that is constantly changing in value like is going on in the cell and the VIC, it would be hard to calculate that movement with ohms law now would it not? Just in periods of any given time maybe. But If anyone has such a tool please forward it to me. We had the same man put hydrogen in a EPG and pulse the two coils in one of his videos thinking it would produce electricity. Everything needed to get the EPG working is already on Stan's buggy. Common since if you know anything about electricity and how it is made will tell you how the EPG works with Hydrogen and Oxygen. We also had one man tell us that if we made the magnetic gas it would destroy the world. My advice to this man is don't be making Stan Meyers gas in any form or fashion. This is a discussion for another thread. And I may start one later.
« Reply #69, on December 5th, 2015, 01:53 PM »
I know you can't just give it all away to everyone of us just like that Ronnie and I totaly respect that.
I'm confident it's just a matter of time before that happens and when it does it will be a beautiful day on God's green earth.
After that I truly hope life on Earth as we know it, which is based on the old adage money talks bulls#it walks, will come to an end and that a completely new World will see the light of the day, one that which is free from things such as greed, extorsion, extinction of species, destruction of the environment, etc etc.
But anyway, enough rant, back to topic.
gpssonar
« Reply #70, on December 5th, 2015, 07:14 PM »Last edited on December 5th, 2015, 07:47 PM
Lynx, it will come soon. But just keep in mind people on other forums are watching my every post here. And what has been discussed here the last few day has not only became public knowledge here but on other forums as well. You can bet your boots it is being discussed on one forum as I am typing this. But what the heck, they need something to keep them going to. Their master has run up against ohms law and can't over come it. Even he needs a little encouragement and a push in the right direction from time to time.
« Reply #71, on December 5th, 2015, 11:02 PM »
Quote from gpssonar on December 5th, 2015, 07:14 PM
:-D
nav
« Reply #72, on December 6th, 2015, 01:25 AM »
Quote from Lynx on December 5th, 2015, 01:53 PM
I'm a little different from Ronnie in that I'm more transparant and if I think something i'll say it, if I discover something i'll show it. Ronnie, you've done a lot of hard work regarding this and a lot of it has gradually filtered through the forums and has been helpful but you need to get that monkey off your back, the promise you made to who ever you made it to you need to get it off your back because if you ever walk out of a restaurant choking like Stan did, it will all be gone again.
If you want to truely inspire people then show a video of gas being produced using your VIC, give people a target to aim for that has credance and validity because it just appears that you are stalling for time at the moment and it doesn't inspire.
If you don't have it working properly then be honest and say so but if you do then show the forum it working.
« Reply #73, on December 6th, 2015, 03:30 AM »
OMG i've just realised something. Good Lord.
Ris
« Reply #74, on December 6th, 2015, 03:33 AM »
he made a promise to me ,you have something against that .Losing data is not possible , but before losing data What did You take to prevent Ronnie from choking.
