Arduino-Marlin configuration.h configuration_adv.h setup delta 3d printer upda
« on September 1st, 2014, 11:42 AM »Last edited on October 12th, 2014, 07:32 PM
Newest version firmware for Arduino @ this time is 1.0.6, here:
http://arduino.cc/en/Main/Software#toc2
Not the newest version firmware for Marlin here:
https://github.com/RichCattell/Marlin/tree/master
But if you want RichCattell's latest then that would be his development branch with auto calibratin here:
https://github.com/RichCattell/Marlin/tree/development
Download which ever one you want, use these downloaded versions to replace the ones in the next download you will need, under the video Russ made, here:
http://open-source-energy.org/?topic=871.0
Unzip this last download, then replace the older versions of Arduino and Marlin to the new versions.
View the video Russ has posted here:
go to 43.44 minutes into the video where Russ starts talking about the frimware-software package, follow his instruction.
Now that you hopefully have all this done correctly you will need to replace two files in the main folder for the delta style 3d printer, if you are not building the delta style printer, say the Medel Max or one of the Prusa style 3d printers, you will not need to change these two files, just leave the folder as is, here's how to change the two files:
 When you open an Arduino sketch for Marlin, look for the "example configuration directory" it should be in the main folder at the top of the listing, same folder as the Marlin pde and ino files would be in.
Click on the  "example configuration directory",  there you will find the "Delta configuration", open it,  copy the new configuration.h and configuration_adv.h files, use these two files to replace the two original configuration.h and configuration_adv.h files found in the main folder, same folder as where the Marlin pde and ino files were/are found. Once this is done, you will be ready to set up your delta style printer, open the sketch Marlin pde, then the configuration.h tab to begin defining your printer.
You can post questions you might have here:
https://groups.google.com/forum/#!forum/deltabot
Hope this helps all who are pulling their hair out trying to get their printers up and running, Jeff. :D
Re: Arduino-Marlin configuration.h configuration_adv.h setup delta 3d printer upda
« Reply #1, on September 1st, 2014, 03:36 PM »
Glad you got it up and going.  :)   Can't wait to see it in action!
« Reply #2, on September 1st, 2014, 03:44 PM »
Well I've got it homing now, I just haven't had much time to do anything else on it at this point, hopefully soon though, thanks. :D
« Reply #3, on September 1st, 2014, 08:43 PM »
i plan on trying to get my delta to self level so i will be upgrading fermwhere. thanks for the info !
« Reply #4, on September 1st, 2014, 08:48 PM »
Auto leveling is included in this same package, so you should be good to go. :cool: :D :P
« Reply #5, on October 21st, 2014, 11:25 AM »
im starting to get scared... lol took me 3 months to calibrate this thing and i feel like its all starting over! lol
been running this thing for over 1.5 years and almost every day/night... man i hp ope this works! lol
guess i can all ways go back to what i had if i need to... :)
« Reply #6, on October 21st, 2014, 03:21 PM »
Just keep your old setup and configuration, incase you have to revert back to it. But it is all worth the effort. You might even have to use some of your old configuration settings for the new configuration, so it would be a good idea to print out your old setup, compair each line of the configuration.h, your old one will not have configuration_adv.h.
