Gravity-driven, continuous motion energy genrator: Power Multiplier Device.
RE: Gravity-driven, continuous motion energy genrator: Power Multiplier Device.
« Reply #25, on December 9th, 2013, 06:40 PM »
Quote from heatlocke on December 9th, 2013, 05:32 PM
Whats your opinion about the one in post #6 by Rav...Emu. Real or fake, Plausible ? If it real it should be able to pump water.
That could very well be real.  What I find somewhat odd though is the sound.  Makes me wonder if there isn't some hidden pulsing device associated with it somehow.  This is a fairly common trick and is easily hidden in smaller, low-mass devices.
The number one thing to look for in devices like these are asymmetry or broken symmetry as Tom Bearden calls it.  If you can't spot any such thing, it's almost certainly a hoax.  Usually asymmetry shows itself as two or more kinematic equations linked together with dead-spots or non-linear transitions between them.  These transitions must react differently going one way versus the other.  That is what creates the out-of-balance condition whereby you have the potential to harness energy from the vacuum.
It takes some time and experience to recognize hoaxes and I get tripped-up routinely and need a second pair of eyes to look at it.  Your best chance of discovering the trick is to imagine yourself given the task to replicate the video--not create free energy, just replicate what you see and think about how your would do it.  More times than not, you'll walk right into what was actually done to fool the viewer.  If you ever run into a video where you just can't figure out a way to visually reproduce it.  That's one you might want to spend a little more time on, because it could be real.  The sad thing in all this is I'm certain I have dismissed a video or two that was real, but I could see how it could have been faked.  There really are inventors out there that might show somebody what they did and that somebody posted it to YouTube having no real idea what it was or how it worked.  I say keep an open mind and let these things just flow in.  Hopefully sometime, late at night, everything will come together in your minds eye and you'll see the solution clear as day.  That's when you get up and write everything down, maybe even post it here first.
freethisone
« Reply #26, on December 19th, 2013, 08:59 AM »
http://www.thedailystar.net/beta2/news/student-invents-technology-to-produce-worlds-cheapest-power/
Published: Sunday, December 15, 2013
Student invents technology to produce world’s ‘cheapest’ power
Star Business Report
Energy conversion technology that can produce electricity without any fuel. Photo: UltraMax
A Bangladeshi student has developed a system that can produce electricity without any fuel, claiming it to be the world’s cheapest form of power.
The system known as Heavy Circular Moving Object’s Triggering Energy Conversion (HECMOTE) uses round objects moving on a plain exterior, to capture the surface’s gravitational energy to run traditional generators to produce power.
“The technology is about converting gravitational energy into mechanical energy to generate electrical energy. It will not use any fossil fuel and thus, will not release any toxic elements into the atmosphere,” said Shahid Hossain, inventor of the new technology, at a press meet at Dhaka Reporters Unity yesterday.
Gravitational energy is potential energy an object possesses because of its position in a gravitational field.
Hossain, who is studying for a diploma in electrical engineering at a technical college in Uttara, began work on his idea in 2007.
A 100KVA power plant adopting Hossain’s technology was set up on an experimental basis in Tongi in 2011, which has been running successfully since then.
Hossain, 29, said the production cost of a kilowatt-hour of electricity would be Tk 0.2 with his system, whereas it is Tk 14.46 per kwh for a diesel-run plant.
The production cost of a unit of electricity with other renewable energy sources is even higher than that of the fossil fuel-run plants.
The operation and maintenance costs are also much lower; a 100MW HECMOTE power plant will cost Tk 1.5 crore a month against Tk 5 crore of a diesel-run plant.
The diesel-run power plant consumes fuel worth Tk 144,000 an hour whereas the HECMOTE power plant will not use any fuel.
The youth from Dinajpur said he ignored a lucrative offer from a Canadian firm a few years ago that offered to buy all rights of the technology.
Hossain said Bangladesh, an energy-starved nation, would benefit from the invention before it becomes available for others. “I need support from the government to make it commercial, as I will not be able to set up a plant capable of producing 100 megawatts of electricity worth crores of taka on my own.”
His company, UltraMax Power Development Ltd, plans to set up plants that are within a capacity of 5 megawatts and 10 megawatts.
The life-span of the system is 25 to 30 years, said Hossain.
He believes his invention could create a new dimension in solving the world’s present energy crisis.
Lynx
