The Russtic WFC Frequency Generator. True 50% Duty Frequency Generator W Gating.
KevinW_EnhancedLiving
RE: The Russtic WFC Frequency Generator. True 50% Duty Frequency Generator W Gating.
« Reply #51, on September 3rd, 2011, 11:11 AM »
Quote from dirtwill on September 3rd, 2011, 10:18 AM
So Jeff I think your scope comes with a X1 and X10 probe, which lets you read up to 50V
http://www.ebay.ca/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=x1000+probe&_sacat=See-All-Categories
X1000 Probe Lets you read up to 5000V but pricey
Here is a heatsink I found
Ha Will, looks like you almost have it, looks great, and thanks for the heads up on the probe, I might wait on it though, I think they might be coming out with a 10 or a 20k voltage probe which would be worth the wait even though it will cost more i'm sure, thanks Will, Jeff.:D
« Reply #52, on September 3rd, 2011, 03:14 PM »
The Program for my 2090 model only goes up to X1000 Let me know if yours goes higher please :)
« Reply #53, on September 3rd, 2011, 03:24 PM »
Quote from dirtwill on September 3rd, 2011, 03:14 PM
Will they have a 15k for sale now, here is the link,   http://www.ebay.ca/itm/New-High-Voltage-Passive-Probe-X1000-up-15KV-/280126415075?pt=LH_DefaultDomain_0&hash=item4138d5e0e3#ht_2436wt_1013 ,,  weather it will work on the one I ordered or not I do not know yet, 20k would be better though, and they more than likely have a way for it to work on yours I would think, Jeff.
« Reply #54, on September 4th, 2011, 05:27 AM »
Will, the scope I just ordered went up in price $200.00 it was $349.00 now it's $549.00, hopefully they will still ship it at the lower price, because I paid for it before they went up, just to let you know, also did you get the circuit working yesterday,Jeff.
« Reply #55, on September 5th, 2011, 10:01 AM »
Quote from dirtwill on September 2nd, 2011, 04:43 PM
http://www.alldatasheet.com/datasheet-pdf/pdf/32418/TOSHIBA/TLP250.html
Russ there is no opto on the circuit. The U10d I show in my schematic is where is connects to your circuit.
I was told opto wasn't really needed with the IRFP, and is just more switching which can degrade signal.... The IRFP Is suppose to Isolate, but then the resistor conects the two sides...?... There Is this TLP250 I was looking at but my parts store didn't have it. It is entitled inverter, so i would think It can replace that inverter I added maybe.
Russ I sent you a IRFP 264 along with your chips :). Im gunna try and order the TLP250.
Jeff my schematic just attached onto Russ. Were still testing so we cant give you any solid data changes are still happening...  Awesome news about the Oscilloscope, you'll love it :)
TLP250 Transistor Inverter PhotoCoupler
http://www.futurlec.com/LEDOpto.shtml
thanks will, you Da man.
thanks so much will! i got some progress done on the EPG so i will post that over on the EPG page. then i can get back to some electronics some time soon! keep making progress!
thanks
RE: Updates!!!!
« Reply #57, on September 29th, 2011, 05:22 AM »Last edited on September 29th, 2011, 06:38 AM by ~Russ/Rwg42985
Quote from dirtwill on September 28th, 2011, 07:33 PM
I've been hard at it with this circuit, Everything seem to be working great. New PCB board will be assembles and the next few days and tested.
Kevin :)
Kevin, that is looking so sweet!
so the photo paper is the way to go?
ill need to get my circuit back to testing with your hard work here!
sweet! your hard work is paying off my friend! and its fun to build  a circuit like this from nothing! PCB and all! makes you feel good about your ability's do this type of work!
good job! ~Russ
RE: Updates!!!!
« Reply #58, on September 30th, 2011, 06:17 AM »Last edited on October 6th, 2011, 04:39 PM by KevinW_EnhancedLiving
The above files have been updated
Quote from Rwg42985 on September 29th, 2011, 05:22 AM
Yes glossy photo paper seems to work best. I also have an old iron that gets super hot, and I was able to make the paper a toasted brown color. The paper peeled right off the copper, no soaking. I guessing because of the extra heat. I also pressed it very hard for a few mins.
Progress...  :)
The amazing 5 min drill press !!!
Worked like a charm
All components installed
Complete Board
And down I go.. Goodnight everyone. (lol i forgot to push post before sleep, so good morning now too!!)
RE: Updates!!!!
« Reply #59, on September 30th, 2011, 07:19 AM »
Quote from dirtwill on September 30th, 2011, 06:17 AM
Progress...  :)
looks so sweet!!!
fantastic work! also when you post photos for some resin they don't compress so make them smaller before posting :) also attach high-res photos then also.
main reason for that is the links stuff don't display correct... lol i don't know why it dose that!
hows the testing??? lol you did not get there EH? sweet!!!!
H2oplasmaplug
RE: Updates!!!!
« Reply #60, on September 30th, 2011, 08:49 AM »
Kevin that circuit looks beautiful. Great job buddy. I am curious to know can these circuits be used to create extream high voltage. Like for what's required for the 10kv to 40kv for the burning water expariments.
RE: Updates!!!!
« Reply #61, on September 30th, 2011, 09:20 AM »
Quote from H2oplasmaplug on September 30th, 2011, 08:49 AM
Connect it to the transformer of some kind like your microwave transformer, or even a ignition coil. This would give you a nice controller for the adjustable frequency. and sense its 50/50 it will work excellent! or, as we are doing, build a VIC Coil! but that will come as we progress!
H2oplasmaplug
RE: Updates!!!!
« Reply #62, on September 30th, 2011, 01:05 PM »
I would be willing to make it. A few members in Tony woodsides group were discussing the 6 coil Vic. I think Tony has actually replicated one but I am unsure what his results. Would you have to have a multi tapped coil to have a variable voltage. Do you already have a Vic thread.
« Reply #63, on September 30th, 2011, 02:41 PM »
« Reply #64, on October 4th, 2011, 07:06 PM »Last edited on October 6th, 2011, 04:46 PM by KevinW_EnhancedLiving
« Reply #65, on October 9th, 2011, 09:27 AM »Last edited on October 11th, 2011, 03:36 AM by ~Russ/Rwg42985
some fine work Kevin!
now. how is the progress? are you happy with it?
whats the update????
thanks!!!!!!!!!!!!!! ~Russ
« Reply #66, on October 9th, 2011, 09:52 AM »Last edited on October 11th, 2011, 03:37 AM by ~Russ/Rwg42985
Quote from Rwg42985 on October 9th, 2011, 09:27 AM
That's some nice work Kevin, I wish I had the time to get back to building this circuit as well, the 3d printer build is taking all my spare time right now, but I'll get there eventually, thanks for posting your pictures.
Muxar
« Reply #67, on October 11th, 2011, 01:17 AM »Last edited on October 11th, 2011, 03:37 AM by ~Russ/Rwg42985
Quote from Jeff Nading on October 9th, 2011, 09:52 AM
Thank everyone! you are awesome!i have not much idea about electronics but i´ll try to replicate it to drive my stan´s cell replication. Thanks from spain!!
« Reply #68, on October 11th, 2011, 03:38 AM »
[/quote]Thank everyone! you are awesome!i have not much idea about electronics but i´ll try to replicate it to drive my stan´s cell replication. Thanks from spain!![/quote]indeed! welcome to the forms!
« Reply #69, on October 11th, 2011, 06:35 AM »
Im really happy with it right now. Nice clean output signal with sharp on/off pulses.
Changes: I had to re route the output signal so it wasn't going threw the inverter. It seems to have worked both ways, so I made the board easy to change. You just cutt a trace and connect to the inverter, Once we build one or two more we'll know for sure. I marked the trace in purple on the board im sending you.
Thanks,
Kevin
Muxar
« Reply #70, on October 15th, 2011, 02:41 AM »
Quote from dirtwill on October 11th, 2011, 06:35 AM
Thanks,
Kevin
Hello Kevin!
I´m happy to hear that! you are doing a great job!congratulations!
I´d love to use your circuit to drive a toroidal vic transformer that i´m building. could you share with us the final schematic?i´d really apreciatte it!
 I´ll share my results driving my replication of stan´s cell:
https://www.youtube.com/watch?v=kSrPOFFFEnc
 It´s 20 amps 12v brute force for now
I also have a 1.3 hyundai engine only for testing with hho but my knowlegde of electronics is not the best,i´m actually an spanish mechanic.
Thanks,
Ander
« Reply #71, on October 16th, 2011, 01:13 PM »
Pedro
« Reply #72, on November 1st, 2011, 07:38 AM »
Alguien habla español???
Hola, hace un tiempo vengo experimentando con HHO y las patentes de Stanley Meyer, quisiera hacer algunas preguntas antes de replicar el circuito electronico de Russtic.
mi ingles es muy malo y la traduccion de Google no se adapta al ingles tecnico.
disculpen las molestias.
« Reply #73, on November 1st, 2011, 08:07 PM »
Quote from Pedro on November 1st, 2011, 07:38 AM
Translation:
Anyone speak Spanish???
Hello, I came some time experimenting with and HHO Stanley Meyer patents, I would like to ask some questions before replying Russtic Electronic circuit.
my English is very bad and the translation of Google is not adapted to technical English.
Sorry for the inconvenience.
Sorry, I don't speak spanish.
I was able to translate with google translator. If you can translate into english someone here might be able to help you...
Lo sentimos, no hablo español.
Yo era capaz de traducir con el traductor google. Si alguien puede traducir en Inglés aquí podría ser capaz de ayudarle ...
Muxar
« Reply #74, on November 2nd, 2011, 02:06 AM »
Buenas Pedro! Yo soy español y tambien estoy haciendo una replica del circuito de stanley gracias al buen trabajo que estan realizando en este foro. Pregunta tus dudas,asi los proximos españoles que entren en el foro lo tendran mas facil para hacer su propio prototipo.
Un saludo.
