Open - Source - Research => Open-Source Research => HHO / Browns Gas / Hydroxy / Stan Meyer => Topic started by: securesupplies on April 13th, 2019, 10:45 PM
Title: Making EPG Liquid Metals
Post by: securesupplies on April 13th, 2019, 10:45 PM
ON a Recent Factory Tour if Became Apparent
We can use  these metal Alloys Just as Stanley a Meyer Described
We must have learnt this as they use Liquid metals to cool fission reaction
and use magnetic pumps to move them
Secure Supplies is Active and we are supporting those progressing the Stanley A Meyer Technologies
To Start this Thread off  I submit this and attached
Warning Do not mix with HHO water or h2, ideally it would be use
as is in a vaccum or in a agron mix environment
Creating a "Liquid Metal pump with  no moving parts"  where have I heard that before ?
Daniel
Secure Supplies
Title: Re: Making EPG Liquid Metals
Post by: securesupplies on April 13th, 2019, 10:50 PM
Links Found to be Very useful on this subject
A Gallium-Based Magnetocaloric Liquid Metal Ferrofluid
https://pubs.acs.org/doi/abs/10.1021/acs.nanolett.7b04050?src=recsys&journalCode=nalefd
Spontaneous Dispersion and Large-Scale Deformation of Gallium-Based Liquid Metal Induced by Ferric Ions
https://pubs.acs.org/doi/abs/10.1021/acs.jpcb.8b12115
Magnetic Liquid Metals Manipulated in the Three-Dimensional Free Space
https://pubs.acs.org/doi/abs/10.1021/acsami.8b22699
Electric Actuation of Liquid Metal Droplets in Acidified Aqueous Electrolyte
https://pubs.acs.org/doi/abs/10.1021/acs.langmuir.8b03384
Stretchable, Skin-Attachable Electronics with Integrated Energy Storage Devices for Biosignal Monitoring
https://pubs.acs.org/doi/abs/10.1021/acs.accounts.8b00508
A Versatile Approach for Direct Patterning of Liquid Metal Using Magnetic Field
https://doi.org/10.1002/adfm.201901370
Magnetic field dependent thermal conductivity measurements of magnetic nanofluids by 3ω method
https://doi.org/10.1016/j.jmmm.2018.10.142
Liquid Metal-Based Transient Circuits for Flexible and Recyclable Electronics
https://doi.org/10.1002/adfm.201808739
Reflux pretreatment-mediated sonication: A new universal route to obtain 2D quantum dots
https://doi.org/10.1016/j.mattod.2018.06.007
A Liquid-Metal-Based Magnetoactive Slurry for Stimuli-Responsive Mechanically Adaptive Electrodes
https://doi.org/10.1002/adma.201802595
Post by: securesupplies on April 13th, 2019, 11:40 PM
Re this one
we can see this is a separate method not including hho h2 or plasma  as will explode
but liquid metal on its own or  encase or suspended in argon it may only need a  100 mls  and that 100 mls cycles
but or could be solid fill and oscillate back and forth those studied in the epg will know the varying versions this applies too
these metals will react with copper hence pit copper or stain ir silver with corrosion over time
as we see om estate pics
 I am sure stan tested and used a one version this as he knew this from his work cooling industrial transformer and reactors
I past this quote here to speed you reading
. We can impart a Magnet effect to the liquid metal
We demonstrate a magnetocaloric ferrofluid based on a gadolinium saturated liquid metal matrix, using a gallium-based liquid metal alloy as the solvent and suspension medium.
The material is liquid at room temperature, while exhibiting spontaneous magnetization and a large magnetocaloric effect. The magnetic properties were attributed to the formation of gadolinium nanoparticles suspended within the liquid gallium alloy, which acts as a reaction solvent during the nanoparticle synthesis.
High nanoparticle weight fractions exceeding 2% could be suspended within the liquid metal matrix. The liquid metal ferrofluid shows promise for magnetocaloric cooling due to its high thermal conductivity and its liquid nature.
Magnetic and thermoanalytic characterizations reveal that the developed material remains liquid within the temperature window required for domestic refrigeration purposes, which enables future fluidic magnetocaloric devices. Additionally, the observed formation of nanometer-sized metallic particles within the supersaturated liquid metal solution has general implications for chemical synthesis and provides a new synthetic pathway toward metallic nanoparticles based on highly reactive rare earth metals.
Pic attached
Suspensions of ATOMIC  graphene and iron neodymium etc
DD
